Question about Microsoft Xbox 360 Console
Xbox 360 plug damaged (chris)
Ive checked the xbox 360 plug for damage,but i couldent see anything,how do u check to see if the fuse is blown?
thanks chris
  • chris michaels Apr 25, 2008
    2 pin plug U.S 110 volt,i cant see anything visually around the plug,,,
  • 38 Answers
Http://www.360-hq.com/xbox-tutorials-23.html
Go here to answer you questions.
Billy D
Posted on Apr 27, 2008
    Genius:
  • 1,019 Answers
Hi Chris,
the fuse is located Within The plug.
I,m not sure what part of the world your From Or what your Power Outlet Supply Voltage Is ?
Do you Have A 3 Pin Plug ( live/neutral/Earth ) Or 2 Pin Plug. Live/Neutral ?
regards Mike @ compurepair.
Posted on Apr 25, 2008
What is the1993 mitsubishi lancer charging system picture?
OK, the problem appears to be the alternator is not charging. With a multimeter, check on the alternator output lug for around 14Vdc when the engine is running. This same voltage should appear on the battery +ive terminal. If not,
1. Check that the multiwire plug in the alternator does not have any damaged wires. If so repair the damage.
2. The 5mm wire from the alternator to the battery runs under the radiator, and can get damaged. This wire runs into the main fuse box on the RHS engine bay. There's also an 80A fuse (BOLTED in place) in the fuse box. Check this fuse is not blown, replace if needed.
Jan 07, 2014 | 1993 Mitsubishi Lancer
Plugged it in turned it on nothing av 1,2 ,3 4 nothing
if there Is no light on the power-Brick. Orange/Green.
You could check The Plug fuse ( replace with same Rating 5 Or 13 Amp et,c )
If the power brick remains Orange, Would suggest Motherboard Damaged.
Mike @ compurepair.
Nov 05, 2009 | Microsoft Xbox 360 Console
My xbox 360 dvd tray keeps opening
Determine whether the disc is dirty or damagedDiscs that are smudged, scratched or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or the bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
Note Scratches that follow the curve of the disc are very damaging and prevent a disc from being read. If you see that your disc has even one of these types of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: a. Use a soft, clean, dry, chemical-free cloth to clean the disc. b. Lightly wipe from the center of the disc outward. 3. After cleaning the disc, try to load it in the Xbox 360 console. If the disc still won't load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • If you think that the disc was already damaged when you bought it, try to exchange it. • If you have a damaged Microsoft Xbox 360 game disc and would like to order a new one, please visit the following Web site: http://support.xbox.com/support/en/us/xbox360/gamesandmedia/games/discreplacement/DiscReplacementPlan.aspx (http://support.xbox.com/support/en/us/xbox360/gamesandmedia/games/discreplacement/DiscReplacementPlan.aspx) • If the game is a non-Microsoft Xbox 360 game disc and was damaged because of misuse of some type, such as not storing the disc properly in its case, the only thing you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contactIf the disk is bad or damaged your unit will open when trying to read it. Hope this information helps, let me know if I can help you with anything else.
JimmyC
Oct 04, 2009 | Microsoft Xbox 360 Console
No input from my xbox helpppp
My best sugestion would be to make sure the wires are fine and then check the ports in your tv to make sure that they are not damaged. In the end you might just have to get a new av cables for your xbox 360
Aug 19, 2009 | Microsoft Xbox 360 Console
Hi i have xbox 360. it was on 110volt some on plugged into 220v. it seems it has blown the power supply. can anybody help me to to fix this problem. any reply will be highly appreciated. thanks
Hi, the power brick on your 360 is designed to "blow" in the event of a power surge or in this case to much power. Take your power brick and try to plug it in to someone else's 360 and see if it works. If it doesn't then you need to buy a new power brick ( a cheap alternative to replacing the 360). But, if it still works then you may have totally burned your 360 since they don't have an internal fuse. At that point I would take it to a repair shop and let them look at it to see the extent of the damage and give you an idea as how much it is to repair.
Aug 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 wn't play sega superstar tennis
Is the disk clean. check the back of the disk to see if there is damage. If the 360 wont do anything i suggest you bring it to get fixed. (try other games to see if the xbox360 loads them)
Dec 28, 2008 | Microsoft Xbox 360 Console
Chris 360 issue
Hi Chris,
If it,s just the power brick, it,ll be cheaper to just have a new one shipped to you. out of curiosity have you checked the plug to see if the fuse has Blown ?
Mike @ compurepair.
Apr 17, 2008 | Microsoft Xbox 360 Console
Xbox 360
The tray could be out of rail track and need to be realign. You need to open the case and see for any damaging to the tray track. Since you put the heavy impact onto it so it is derailed and some connected wires may be broken. If you can, you need to open the case or ask someone who has done this before to open the case and check these items: 1) The conditon of the tray with any broken part 2) How serious is the derailed condition and see whether you can realign it back to right track. 3) Check wires for broken or disconnected one YOU DON'T NEED TO POWER ON IN STEPS 1 AND 2. BUT FOR CHECKING ANY ELECTRICAL MALFUNCTION IN STEP 3, YOU NEED TO PLUG THE CORD BACH AND CHECK FOR ANY BROKEN WIRE AND TRY TO RECONNECT IT BACK. Do it yourself if you have confidence or else send it to the store. This is not hard to repair. Good Luck
May 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
749 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
