Question about Sony Playstation 3 (PS3) Console
I can not connect to internet with y ps3..error code 8013082 keep coming up..what shall i do
  • 36 Answers
SOURCE: internet connection
the Ps3 should connect fine, if you have your wired router set up right to automatically assign ip addresses...(DHCP)..in otherwords, anyone who comes over with a computer from anywhere..even me..should be able to plug a lan cable in to your router and it should connect without changing any settings. If this is true, then you should be able to go into your settings menu, select wired connection type, hook up your lan cable...then select auto and east for the settings for ethernet. this should work, if any pc works. If not, you may have to call AOL for info on how to properly configure your router and PS3. The network issue is most likely a AOL issue, and not a PS3 issue.
Posted on Jan 05, 2008
maklean
  • 1665 Answers
SOURCE: PS3 WIRELESS CONNECTION
This code (80711008) is not reffered error code list
Try first to establish a success connection at a nearer distance. Your signal strength might not be strong enough to have a lasting connection
Posted on Jan 10, 2008
SOURCE: PS3 internet connection problem
if wireless you have got to go to the router and un plug the ethernet cables and the power cable then plug them back in then it works i have had this problem
Posted on Apr 09, 2008
SOURCE: PS3 Network troubleshootiing
How to connect a PS3 to the internet
Posted on May 15, 2008
  • 110 Answers
SOURCE: i carnt connect to the internet by my dsi error
Im going to guess that your wireless router is a "wireless-n". If it is then you will have to go into your router settings and change it to either G and N or just G as the DSi does not support the wireless-n configuration.
If thats not your issue then give me a message and I will do my best to help you out.
Regards,
SOD69
Posted on Feb 09, 2010
8013082 error code ps3, how can i fix it?
First, reset your router/modem (please look up how to do so with your manufacturer). Try connecting again. If this doesn't work, use an ethernet cable to connect directly to the modem.
Jun 17, 2011 | Video Game Consoles & Games
8013082 i got this error for 5 days, what can i do?
I assume this is an error for the PS3 and an issue connecting to the internet. First, reset your router/modem (please look up how to do so with your manufacturer). Try connecting again. If this doesn't work, use an ethernet cable to connect directly to the modem.
Mar 14, 2011 | Video Game Consoles & Games
I accidently took of my internet connection while dowloading black ops and I cant download it again! help please.. error (80710101) comes out.
PS3 Error Code 80710101 This error is caused by an issue with the Playstation 3 not being able to connect to the internet or website
To solve this error :
Ensure your internet connection is up and running.
Reboot your playstation 3 and router.
Ensure your network connection information is correct.
Try creating a new connection on the by accessing the Network Settings menu option on the PS3.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
I bought ps3 in cash converties second hand im tryiny to connect to wireless interent but error code is keep coming up
The internet signal is probably to weak. Connect your PS3 to the internet by using a Ethernet cable
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
I can't connect to the Playstation network. I keep getting a list of possible errors that i have tried and error code 80710092? My PS3 is connected via ethernet and my modem is working. The PS3 can go on...
well when settings up the internet connection do it all manually and ps3 will only accept wpa security code to connect to the internet and turn prozy server off and then it should connect
Jan 09, 2011 | Video Game Consoles & Games
80028E02 (this error keeps coming on my ps3 and it doesnt make me sign in online! please help
ps3 error 80028e02 can be caused by different source of networkshowcase270.jpgblockages. If you happened to be in a filtered network, that's your most probable reason why your ps3 is unable to connect online. For example, if you're in a school campus, there's a high chance that the IT network administrator has placed some restrictions to prevent hackers and other malicious online activities. You can refer to the campus IT department to find out if you need to access their local page for some clearance in order for your ps3 to connect online.
If you have your own internet connection, the next probable cause is a router. Placing restrictions on some IP address or net services may have accidentally include your ps3 in it. You can change some settings within the router to grant your ps3 full access online, while at the same time maintaining other restrictions that are already in place.
Another possible remedy is have your pc internet connection shared, and use your ps3 to use that shared connection to go online. These solutions are sure fire methods of keeping ps3 80028e02 away from your console.
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
How do I fix DNS error code (80710102) on a ps3?
http://www.gamepro.com/article/news/214223/update-psn-connection-problems-continue/#
Sony is working on a fix internal clock error
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
Cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
Online play for ps3
reset your router and modem, then go through your ps3 settings and do it on easy. this should work. if not try connecting it directly to your modem and see if that works.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Internet connection failed but IP address obtained.
OK IF YOU HAVE PS3, and you get the ERROR DNS while trying to login into PSN, all u need to do is, shutdown the console, then restart it by holding down the ON button on the PS# not the controller till you hear 2 beeps, then try to login again, should work.
Nov 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
377 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
