Question about Siemens Gigaset 4000 Phone
Iam using gigaset AL280 ,but now when i connect to the telephone line it showing only BASE indication
CORDLESSGURU
  • 106 Answers
SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Posted on Jun 16, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: siemens gigaset A410 problem with some hardware
Your unit got hit by a lighting strike, but it is fixable. Go to www.cordlessrepair.com
Posted on Jul 04, 2008
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 105 Answers
SOURCE: cordless GE 26928GE2-B
there should be some problem with the connection antenna
Posted on Sep 02, 2008
ginko
  • 19396 Answers
SOURCE: We have a 3+1 Uniden
Hi.
Try using the procedure below to reset the phone:
  • Disconnect all power adapter cables from wall sockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handset (or handsets) to cradle. I wrote at plural because the phone system may have more than one cradle/handset.
If that does not work, then the phone is defective.In that case you will need to replace/repair the faulty handset or the whole system.
If there is no communication with base, then either in cradle or handset can be defective. In that case contact Uniden.
See:
Contact - Uniden ' A World Without Wires
customer service phone numbers and support
UNIDEN.COM.AU
First try the reset procedure described above.
Regards.
Ginko
Posted on May 18, 2011
How do I fix my siemens landline phone?
well lightening does do bad things to telephones . that are always plugged in to electric and phone lines
Feb 25, 2015 | Siemens Gigaset A58H DECT 6.0 Digital...
Siemens gigaset problems
I would try powering the base station off and back on. That may fix it.
Sep 03, 2014 | Siemens Gigaset C610A IP Phone
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
I would like a users' manual for a Gigaset AL270 in English. I have only got one in Spanish an Portuguese
your model is uniqe to the area where you live.
Therefore there is no English guide.
I enclose a line whice very similare model (al280).
probably most of the function is similar.
http://gigaset.com/hq/en/cms/PageCustomerServicesDownloadsManuals.html
Mar 03, 2011 | Siemens Gigaset 4210 Cordless Phone
Phones show line in use. Can not find a phone where this is the case. What do I do?
This indicates an off hook condition of the telephone line, to test it you could disconnect the telephone cable from your wireless system base and connect to it a standard wired phone, if you have dial tone and can make and receive calls, the line is OK and the failure is at the base of your wireless telephone system, if you don't have dial tone with the stardard telephone there's a telephone network failure (the telephone wall plate, internal or external cables, etc) and this should be reported to your phone company to be fixed.
Mar 01, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Jun 15, 2008 | Lands Phones
My siemens gigaset 4215 and 4000 don't work and need some kind of code whats the code?
Hello, Almost never is it the handset that is bad when those symptoms occur. It sounds as if your base has gotten hit by a power surge and won't boot (the handset now can't "talk to" the base and its always searching for it). Most people report this after a storm has passed through their area. You can try re-registering the handset to the base, but unfortunately it probably won't work, sorry. You can order the base only and register your handset to the replacement base when you get it. To order a replacement base using google, search for Siemens Cordless Repair and click the first non sponsored link. Good Luck
Dec 08, 2007 | Siemens Gigaset 4000 Phone
Siemens gigaset A410 problem with some hardware
Oct 31, 2007 | Siemens Gigaset 4000 Phone
Answering machine
Unfortunately the 4010 model does not have a built in answering machine but does have features to work with your local telephone companies voice mail. If you want to keep your same phones and get a base with a built in answering machine you will need to replace your 4010 base with a 4015 base (up to three handsets), or a 4215 base (up to four handsets). But don't toss out your old base, you can use it to extend your range if you ever use a 4200 series handset that will allow you to register each handset to up to four seperate bases simultaneously to extend the range. You can buy the 4015 or 4215 base only and save yourself some money. You can google Siemens cordless repair or go to the Siemens website to find a few options.
Aug 12, 2007 | Siemens Gigaset 4010 Cordless Phone
Siemens Gigaset 4000 Phone Logo
213 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
