Question about Car Audio & Video
Dont now what colour the speaker wires are - Car Audio & Video
  • 6,993 Answers
the color if the speak wire is Black and Red.
Good luck.
Posted on Jul 29, 2010
Speakers
Could you specify the model of the Sanyo speakers?
Jun 11, 2013 | Audio Players & Recorders
I need to wire my sony cd player into my fiat cinquencento but I have no idea how to wire it in I just spent 23 on a wire for the stereo an it only cost me a tenner for the actual stereo I dont want to...
most car stereos are simple to wire, especially sony!
Main power cable colours are:..
RED = LIVE (+)
BLACK = NEGATIVE (-)
YELLOW = MEMORY/SWITCH LIVE it will be next to the red and black cables
ORANGE AND WHITE = ELECTRIC ARIAL (IF FITTED)
BLUE = REMOTE WIRE (FOR AMP CONTROL IF USING)
You should now be left with a couple of audio out jacks and speaker cables,
the speaker cables are straightforward, most have a twin, ...E.G if you have a grey wire, this should be next to a grey and white (or grey and black, depends on model) wich is classed as its PAIR/TWIN.............
an so forth,...green, purple, white, brown.....ect ect
each colour havin a twin as stated ealier!! (they are twinned, as the solid colour is usually the negative speaker, and the solid colour with a stripe through it is usually the posative speaker connection (eg..single solid colour is (-)...and...solid colour with stripe is posetive (+)...)
Apr 30, 2011 | Car Audio & Video
Hi ive inherited a problem....x reg rover 45 with no stereo in it (there was once tho) and the wires have all been cut (still got enough length to sort out tho) Basically i need to no the colour coding for...
dont know the colour codes as i am colour blind but use a multi meter to find thte 12v permant feed for the memory then the 12v switchable from the ignition ,earth wire is their as well ,the speakers use the same colour wire per speaker and one has a stripe in it .forget the electric aerial as it doesnt have one shouldnt take more than half an hour to wire in
Feb 10, 2011 | Car Audio & Video
Dont know what colour wiring is what
what do you mean by what colour wiring, different speaker headsets are different but basic wire colour if it helps red or brown is the live and blue or black is the neutral
Jan 30, 2011 | Car Audio & Video
I have been given an old Sharp music center but dont know how to connect the speakers to the amplifier sockets on back of amplifier look like this L I I R but I dont know how to put...
l means left r means right connect speaker wires by phono sockets or if no phono sockets then the wires go direct into the colour sockets red to red etc
Jun 08, 2010 | Sharp SX9860 2-Channel Amplifier
I have a 1995 f250 it had a tape factory player and trying to put a single factory cd player that came from a 1996 ford areastar van but the wiring is diffeent is this possible?
yes. more that likely if you look at the stereo it will give you a colour code as to what colour wires do what. if they dont then a simple google search for a stereo wiring diagram for each vehicle will be even better. if its just your speakers that are messed up then a neat trick to remember is if you take a AA battery and put the + side of the battery to the + side of a speaker wire and the - to the - then that speaker will come out. If the poles are backwards then the speaker will go in. good luck
Nov 23, 2009 | Buck Ford F250 F350 2002 02 Radio/stereo...
I need step by step on how to connect a stereo to my 2001 f-150
radio wires red= key live yellow=battery live. black= grd. The rest are speakers. totalling 8 (others are illumination normally orange. blue and white is aerial antenna. not required) Car colours all vary. Advise getting tester. to test for lives. Check key live by turning on and off key while testing lives. ground is normally always black. Lives are normally alot thicker than rest of wires as is ground. once lives connected you can test speakers by balancing left and right fade rear and front to connect these. As for + - on a loom these are normally hard to distinguish as a speaker can run in reverse. in just sounds alot better when ran properly. But each pair are normally the same colour although one will have a different colour line running down it. Chek out this site for car wiring colours. http://www.caraudiohelp.com/car_alarm_install_guides/car_alarm_install_guides.htm
Apr 30, 2009 | Car Audio & Video
Need help with speaker wire colours
if i read that right.. just leave the wires in place and run new wires through the door and into the dash behind the deck.
speakers only have 2 wires a (+) and ( - ) the positive and negative can be hooked up backwards at the speaker and you will still get sound just fine.
many audio installers i know dont even bother looking at what wire is what as long as 2 wires are running to the speakers
if you want to TEST a possibly bad wire use a Multi meter and check Continuity through the wire.
Mar 16, 2009 | Car Audio & Video
Colour code for speaker wires.dont know + from -
I am guessing the cable is figure 8 two cores attached to form a single cable. The core with the line down it is very often the - and the plain the + however it is irrelevant, as long as the cable that is connected to the source, CD, or whatever, the colour that goes to + there, must go to + at the speaker terminals, likewise the - must be connected in the same way neg to neg. This follows for ALL the speakers connected to the system as if you get a pos+ connected to a neg- it will cause the speakers to be "Out of Phase" and could cause sound distortion. Rule of thumb, without any stripes or line black, is usually negative -
Feb 10, 2018 | 2003 BMW M3
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Car Audio & Video Logo
16 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
