Is all gases are lighter than air? - Computers & Internet
  • 624 Answers
Hello and Welcome to FixYa!
NO, not all the gases are lighter than air.
Neon, Hydrogen fluoride, Water (steam), Carbon monoxide, Ammonia, Nitrogen, Hydrogen cyanide, Methane, Ethylene, Acetylene, Methllithium, Diborane,Helium,Hydrogen are Lighter than air.
While; Arsine AsH3, Nitrogen dioxide NO2, Carbon dioxide CO2, Chlorine Cl, Fluorine F are Heavier.
Posted on Jul 29, 2010
Why does my air conditioner keep shutting off?
This can happen for a number of reasons, but make sure the condensing coils are clean and not obstructed by any improvements or natural things such as trees or bushes. The hot gases produced by the compressor must be cooled (condensed) by the pulling in of the ambient air to cool these hot gases and dissipate them in order to reduce the head pressure and condense the hot gases to a liquid. The appliance is designed to shut down whenever the head pressure reaches a pre determined level (to protect the equipment).
May 13, 2014 | LG LW1211ER 12,000 BTU WINDOW AIR...
Is air weightless?
Just because something's invisible doesn't mean it's weightless. So, no, air is not weightless.
As a matter of fact, all gases have mass, and therefore they have weight. Air, a combination of gases, is fairly heavy.
Good thing, too, ?the weight of the air around us and the force it exerts on our bodies pushes on us, and that is what keeps us from exploding. The pressure inside our bodies, in turn, keeps the air pressure from squishing us flat.
Air weighs about .07 pounds per cubic foot.
And believe it or not, each square inch of our bodies is under about 14.7 pounds of air pressure.
Feb 22, 2014 | Scientific Explorer My First Chemistry Kit
Vw polo overheats
a cold hose indicates an air lock in the cooling system, if this is the case have it bled to remove the air lock. it could also be combustion gases leaking into your cooling system indicating a possible head gasket failure, your anti freeze can be tested for traces of combustion gases.
Nov 28, 2013 | Volkswagen Polo Cars & Trucks
Blowing hot air when on ..volume of air is fine..started weaking and finally no cold air
If the it is still blowing air yet not cooling the air, you may have to check that your air conditioning unit may need re-gasing. Heres a video which demostrates how the (genaric) re-gasing would work.
Jul 28, 2011 | Air Conditioning and Heat for Kia Amanti
1983 Blazer with 6.2L diesel. 132k I have had muffler shop check for exhaust leak and found none. The only item to be leaking anything is the CDR. It is emitting a small amount of vapor from a small...
According to Chilton's manual on page 159 under "Diesel Engine Emissions Controls" A Crankcase Depression Regulator Valve (CDRV) is used to regulate (meter) the flow of crankcase gases back into the engine to be burned. The CDRV is designed to limit vacuum in the crankcase as the gases are drawn from the valve covers through the CDRV and into the intake manifold.
Fresh air enters the engine through the combination filter, check valve, and oil fill cap. The fresh air mixes with blow-by gases and enters both valve covers. The gases pass through a filter installed on the valve covers and are drawn into the connecting tubing.
Intake manifold vacuum acts against a spring loaded diaphragm to control the flow of crankcase gases. Higher intake vacuum levels pull the diaphragm closer to the top of the the outlet tube. This reduces the amount of gases being drawn from the crankcase and decreases the vacuum level in the crankcase. As the intake vacuum decreases, the spring pushes the diaphragm away from the top of the outlet tube allowing more gases to flow to the intake manifold. NOTE: Do not allow any solvent to come in contact with the diaphragm of the CDRV because the diaphragm will fail.
It sounds like your CDR valve has been compromised. Time for a new one or at least a functioning used one.
Credit to - 82Chev @ http://www.dieselplace.com/forum/63-gm-diesel-engines/20-6-2l-diesel-engine/444625-cdr-valve-question.html
Jul 21, 2017 | Chevrolet Blazer Cars & Trucks
Hello! I need to charge my home A/C.The label right that need r407c freon type. Can i use r507 freon insteed of r407c? I am asking that because i already have a gase with r507 gas. Thank you very...
No.... they are totally different gases and if you mix them you are really in trouble.... only use the specified gas and NEVER mix gases!!
heatman101
Aug 27, 2010 | Whirlwind FH-778 Air Conditioner
What is emission system
THE EMISSION SYSTEM IS DESIGNED TO TRAP AND STORE FUEL VAPORS THAT EVAPORATE FROM THE FUEL TANK.THROTTLE BODY AND INTAKE MANIFOLD DURING NON OPERATION OR IDLING STORE THEM IN THE CHARCOAL CANISTER AND THEN ROUTE THEM INTO THE COMBUSTION CHAMBER TO BE BURNED DURING ENGINE OPERATION.THE PCV VALVE ITS PART OF THE EMISSION SYSTEM.IT SCAVENGING CRANKCASE VAPORS IT DOES THIS BY CIRCULATING FRESH AIR FROM THE AIR CLEANER THROUGH THE CRANKCASE WHERE IT MIXES WITH BLOW BY GASES AND IS THEN REROUTED THROUGH A PCV VALVE TO THE INTAKE MANIFOLD.THE CATALYTIC CONVERTER IS PART OF THE EMISSION SYSTEM IT REDUCE POLLUTANTS FROM THE EXHAUST GAS STREAM IT LOWERS LEVELS OF OXIDES OF NITROGEN AS WELL AS HYDROCARBONS AND CARBON MONOXIDE.THE EGR VALVE PART OF EMISSION SYSTEM IT LOWER OXIDES OF NITROGEN EMISSION LEVELS CAUSED BY HIGH COMBUSTION TEMPERATURES.THE EGR VALVE RECIRCULATES A SMALL AMOUNT OF EXHAUST GASES INTO INTAKE MANIFOLD.SMOG PUMP IS ALSO EMISSION CONTROL COMPONENT IT INJECTING AIR INTO THE EXHAUST DOWNSTREAM FROM THE EXHAUST PORTS TO HELP COMPLETE THE COMBUSTION OF ANY UNBURNED GASES AFTER THEY LEAVE THE COMBUSTION CHAMBER.
Aug 13, 2010 | 2001 Ford Windstar
Oil leaking from air filter is there an overflow 2008 suzuki boluvarde 1800
at all engines there is a hose from the engine which goes to the air filter with gases from the carter. Usually, on that hose is mounted a little filter which stop the oil taken by gases. If the filter is full, the oil could get in the air filter.
I recomend to download the manual to identify the parts.
Apr 13, 2010 | 2005 Suzuki Boulevard C50T
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Air condition re gasing
Hi, nazarw
You don't say whereabouts in the world you are, and neither does your profile.
I am actually based in the United Kingdom, and therefor if you too are based here, then I can help you no problem.
I look forward to your response.
Very best regards
Geordie
Jun 16, 2008 | 2002 Audi A4
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
