Pitco Frialator SG14 Deep Fryer Logo
Posted on Jul 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pitco frialator chips fryer diplaying CFG error
Any time a put on my electic pitco frilator chips fryer , the alarme coming up and displaying CFG error, i dont know what that code means can up help please
Angel Joseph Jr.
Level 2:
  • Pitco Frialator Expert 685 Answers
  • Posted on Jun 06, 2011
Angel Joseph Jr.
Level 2:
Answers
685
Questions
0
Helped
219417
Points
932
CFG error on controller board can be cleared by resetting the controller back to factory setting and by doing this, all program added after the factory setting will be erased so you have to reprogram them again.
Programming guides are downloadable at PITCO site on http://www.middleby.com
Pitco fryer showing heat failure even when the pilot light is on?
Question moved from Misc
HEAT FAILURE - This means the heating system has failed to respond, which can occur because a high temperature limit switch has been tripped and needs resetting. On gas deep fryers, "HEAT FAILURE" may display if the pilot fails to light or if the pilot flame is too weak as detected by the ignition module.
Pitco Fryer Error Codes and What They Mean - Parts Town
How do i turn up the temperature on my pitco frilator
Hi there!
You can download owner's manual with programming guide for Pitco Frialator at www.pitco.com
Regards.
Our church has a Pitco Frialator Model #14UFMS 110,000 BTU. Do you have a manual?
Hi there.
You can download Pitco Fryer Owner's Manual at
http://www.pitco.com
Regards.
Why does my Pitco Frialator not heat to 350?
If your fryer has computer controller (the one with 8 product buttons and left, right arrow), check the display when you turn off the computer board, it should display "gas 2". If not, you have to change the gas configuration by accessing the programming mode.
Pitco Fryer is displaying CHECK SUM FAILURE - in almost 10 years, I have never seen this display - what is it????
Check sum failure is an error on the configuration of the computer board. You have to reset the computer board to factory setting to get rid of this error (if check sum failure appears every now and then on the display). Make sure that you have the list of your cooking parameters before you reset the board to factory setting. Any settings made prior to a factory reset will be lost. Details on how to reset the board to factory setting can be downloaded at pitco website on www.middleby.com.
2helpful
2answers
My pitco gas frialator oil leak in tank .how can
You need to identify where the leak is coming.
If the leak is on the fry tank, best way to address it is to replace the oil tank.
Check the serial number of the unit with leak on fry tank, verify if it is still under warranty at PITCO web on http://www.middleby.com.
4helpful
Frilator pilot will light but fryer wont fire up
The thermocouple or thermopile is your culprit. If it is not sending the correct millivolt signal to the main part of the gas valve telling it to open then, the burners will not light. This is the cheapest part to start with. If after changing this out & you have the same problem then, you have a bad gas valve.
Frialator will not turn on
diaphram possibly ripped or burned replace the valve assembly
Top Pitco Frialator Kitchen Appliances - Others Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
