After driving for while and i step on the brake to slow down my nissan march (2005 model) it start to produce a beep sound,sometime it go off after a few beep but sometime it will carried on until I start to drive off again. What's the problems?
    Brigadier General:
  • 4,090 Answers
You are asking this under a website listing Try the automotive section
Posted on Jul 29, 2010
2006 Nissan Sentra. Belts squeaks and stop seeking when you step on brakes.
If I understand this, your fan and other belts driving components in the engine bay stop squeaking when stepping on the brake? Your belts may need some adjustment to tighten. But it may be a vacuum hose leaking around the power brake chamber, or it is leaking, and sounds like the squeeking you describe. I would temporarily confirm the belt squeak by using a "Belt dressing spray" from your auto parts store, to see if it really is the belt or a possible vacuum leak. My belts squeak sometimes after the first start of the day in cold weather since the alternator is working very hard to recharge the battery after the start. It will be quieter when the engine is slowed down as in your braking scenario.
Mar 24, 2015 | Nissan Cars & Trucks
Beeping sound in 2005 nissan murano
Mine did the same thing. I had the battery replaced on the controller.and it still beeped. Then I took my key and put it in the ignition, without turning the key and took it out. Did this like 6 times and the long beep finally stopped.
Apr 07, 2013 | 2005 Nissan Murano
Hyundai accent 2005 when starting up the vechile and driving there is a constant ugly sound coming from the front passenger side wheel and when applying the brakes on there is a high pitch squeel
That screeching sound is a warning that your brake pads are worn down to the point where they should be immediately replaced. If you do not replace the pads, you'll score the rotor and incur an additional expense. Remember to replace the brake pads on both sides, i.e., driver and passenger side.
May 01, 2012 | 2005 Hyundai Accent
My 2005 Nissan Armada Reverse sensor system is not working. The button stays in the "OFF" position no matter how many times I press the button. Also, periodically when driving, the brake light on the...
I have the same problem. I have a 2005 armada. I just went to Gillman Nissan in Rosenburg Texas today with the same thing, When you turn the vehicle off and turn it on again the problem goes away. I paid $241.00 to reset the VDC computer and I still have the problem. Also my backup camera just stopped working. This is my last Nissan auto. I am pissed!!
Aug 24, 2010 | Nissan Armada Cars & Trucks
For an auto car driving at medium to high speed
2) Could be a wheel bearing going bad.
Apr 02, 2010 | 2005 Nissan Sentra
Nissan 2005 All 4 wheels binding
This is not regular wear and tear. There is a defect in the braking system. Since the problem is with all 4 brakes it would be rare that all 4 calipers would seize at the same time on such a new vehicle. For some reason the fluid line pressure is remaining constant after you let off the brake, keeping the piston in the calipers push out. It's possible you may have a defective Master Cylinder or Power Brake Booster.
Jul 13, 2009 | 2005 Nissan Altima
Driver's side visor on 2006
Check this out. Your vehicle may be covered at no charge to you.
2006-2007MY SONATA SUN VISOR
REPLACEMENT (SERVICE CAMPAIGN T64)
CAMPAIGN APPLIES TO VEHICLES LOCATED IN THE WESTERN, PC, AND SOUTHERN REGIONS ONLY. THIS WOULD INCLUDE
THE STATES AL, AR, AZ, CA, CO, FL, GA, HI, KS, LA, MS, NC, NM, NV, OK, OR, SC, TN, TX UT, AND WA.
VEHICLES AFFECTED:
Model: 2006-2007MY Sonata (NF)
Applicable vehicle production date range:
• NFA: Produced from March 31, 2005 to March 31, 2007 (Alabama built - HMMA)
• NF: Produced from March 21, 2005 to December 23, 2005 (Korea built - HMC)
Applicable VIN range:
• NFA: Produced from Job#1 to 5NPET46C47H297390
• NF: Produced from KMHET46C06A062020 to KMHET46C86A185600
SERVICE PROCEDURE:
NOTE: Before conducting procedure, confirm vehicle is within the affected VIN
range.
Jun 06, 2009 | 2000 Hyundai Sonata
I have a 1988 4x4 Nissan Pathfinder that makes a squeaking noise when I let my foot off the accelerator. I'm not stepping on the break either, just freewheeling. It sounds like a steady squeak with each...
I'm guessing either a belt getting worn, or a little rust build up on brake rotors, or warning tabs on brakes rubbing on rotors. Have someone walk along both sides, of the vehicle while you drive slow down the street, or laneway, they should be able to pinpoint it better for you that way.
Jan 10, 2009 | Nissan Pathfinder Cars & Trucks
Front End Noise in 2005 Nissan, Maxima
it would not hurt to check rear tire wear due to misalignment
cupped tires will cause a faulty bearing type noise or humming.
Jun 15, 2008 | 2005 Nissan Maxima
Computers & Internet Logo
169 people viewed this question
Alun Cox
David Payne
David Payne
