Question about RIM BlackBerry Curve 8310 Smartphone
My Blackberry is hanging on the Memory cleaning application. The front screen shows only the ''Timer''. When the phone is reset and the sim card removed the phone keeps going back to the same screen. Please help as nothing is working?
  • 85 Answers
Dear user,
This type of problem came by the downloading of third party software which is not compatible with your device or Blackberry .
You have to delete some application form your device , which is not compatible of your device.
Or you have to reset/format your device .
How to delete third party application :
1 in screen menu è press “Option”
2 press “Advance Option”
3 press “Applications”
4 select third party application (which is in bold letter)
5 press the “Menu” key and Delete.
Please follow the below instruction “How to wipe the device”
2 Press “Security Options”
3 Press “General Setting”
4 Press the track wheel and select “Wipe Handset”
5 If you like to include the third party software , please check mark on “include third party application” then press “continue”
6 Type “blackberry” then press the track wheel and select OK
Your device is formatting now >>>>>>>
Posted on Jul 30, 2010
  • mishravishal Jan 26, 2011
    format the device and the memory card as well
MY BLACKBERRY CLASSIC HAS FROZEN,PLS HELP
Frozen how? You can't open it ? Blackberry can do this sometimes if you drain the battery completely.. you must leave it plugged in until opens. Or, you can try a hard reset doing this:
  1. Perform a hard reset to wipe all data from the BlackBerry Classic.
  2. Open BlackBerry Link on your computer.
  3. Connect the device to your computer using the USB cable.
  4. Select your device on the left pane.
  5. Go to "Back Up & Restore" > "Factory Reset" (Windows) or "BlackBerry Link" > "Preferences" > "Reload" > "Reload" (Mac OSX).
Jan 16, 2017 | Blackberry Cell Phones
How to hard reset blackbrry curve 8520
The blackberry does not use buttons conbinations to reset like other phones but if you manage to get it running, onto the phone. Select "Options" from the Home screen, click "Security Options" and select "General Settings." Hit your "Menu" key and opt to "Wipe Handheld." Select all check boxes (Third Party Applications, Email, etc.) and "Continue" to completely clean up your BlackBerry. Type "blackberry" (no quotes) to complete the factory reset. Allow your BlackBerry to reset itself. Note: This can take up to an hour, so be patient.
Try booting without sd card if it takes too long.
Nov 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
Kandar98kmy mobile have been hanged and not showing memory card and mobile did not restoring when i command for restoe it show password but i dont know password
hi there!
if you're not the one who set the password for the phone, there's no way of resetting it then. though there are some local technicians who do phone reset but its paid. its also not safe to flash the phone if you get/download softwares from the internet. if its also not showing the memory card, try the card to other phones, if its recognize by other phones then the card is working fine. turn off, remove battery from phone and sim and memory card, leave it like that for 2mins, then put everything back in, if its still not seeing the memory card, the gold contact on the memory card slot may need cleaning (just wipe with water damped cotton balls). if all else fails, you may need a technician to open up the unit and clean, fix it from the inside.
Apr 07, 2011 | Nokia 7210
My black berry phone shows app error 523 with white screen and keeps rebooting what do i do it is giving concern
(IGNORE THE SIM STEPS IF ITS STILL ON VERIZON PLEASE)i had the same issue on my 9700!!! its either the sim or the software on the phone. DO NOT SELECT RESET YOU WILL LOSE ALL YOUR INFO!!! take out the battery with the phone on and take out your sim card. replace the battery without your sim card and see if the error still shows up. if it doesnt its your sim, super quick and easy most carriers will provide you a new one free of charge! if its does appear without your sim its the software. still fixable but not as quick. replace the sim & battery & power your phone on. you'll need a computer and the desktop manager which you can down load if you dont have it already from blackberry.com for free. then run the app loader. the storm has the blackberry 5.0 software and you want to make sure your desktop manager matches. follow the steps from http://www.blackberryforums.com.au/forums/bis-blackberry-desktop-manager/734-use-blackberry-application-loader-load-blackberry-device-software.html and you'll be set!!!
Use BlackBerry Application Loader to load BlackBerry Device Software
Doc ID : KB03621
Last Modified : 2007-05-18
Document Type : How To
Environment
  • BlackBerry® Desktop Software 3.6 and later
  • BlackBerry Device Software
  • BlackBerry device
Warning: You should not install BlackBerry Device Software that is older than the version installed on the BlackBerry device. Doing so could cause the BlackBerry device to malfunction.
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
  1. Install the BlackBerry Device Software on your computer.
  2. Open BlackBerry Desktop Manager.
  3. Connect the BlackBerry device to the computer.
  4. If prompted, type your BlackBerry device password and click OK.
  5. Complete one of the following steps:
    • If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
    • If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
  6. Click Next.
  7. If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
  8. Select the check box for the BlackBerry Device Software.
  9. Click Next.
  10. If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
  11. Click Finish to begin loading the BlackBerry Device Software.
  12. Click Close when the software is finished loading.
Dec 24, 2010 | RIM BlackBerry Storm 9530 Smartphone
Have a blackberry pearl and want to transfer the pictures on that sim card(1 GB)to the new blackberry torch phone
you can insert the memory card in blackberry torch, then go to file explorer in application and copy all the stuff in memory card to internal drive and paste it, or i suggest you leave the card in phone itself.
memory card is always a safer storage device than internal.
Dec 23, 2010 | RIM BlackBerry Torch Cell Phone
Blackberry Pearl 8120 - sms, email and call log being deleted
On the Status screen of the BlackBerry smartphone, the File Free field indicates low ,if the device memory is full then these things will happen on your device,so to never have this problem delete unwanted applications.To delete run desktop manager and select application loader,select the applications that are not frequently used and remove them.Also keep the messages for a month or two because these mails will be there in your mail box.
Jul 20, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Describe your RIM BlackBerry® Curve? 8330 Cellular Phone Problem Red light will not stop blinking
I own a Blackberry 8120. Have you tried a hard reset by pulling the battery and then restarting the phone? Also, events get caught in the phones memory process as well, causing reminder LED's to not clear after clearing the event. Go to options>security options>memory cleaning and enable the memory cleaning function. Set the icon setting to show on the home screen, memory cleaning is a function that many blackberry users under-utilize...the memory must be cleared just like a desktop PC, the rapid logging of events causes some to hang up. I believe one of these 2 solutions will help you out.
Jun 07, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Unlocked 8700c blackberry sim card info not showing
Yes, the blackberry and SIM memory are different.
You will need to copy all contacts onto the BB memory to make full use of its features.
You can do this by going to address book /Options/ SIM Contacts and Copy All to address book.
May 27, 2009 | RIM BlackBerry 8700c Cellular Phone
I have 4 missed calls icon on main screen. Will not go away.
I have seen where you can reset this by pulling out the sim card, booting up the device without the SIM card and lettign it error out the pulling the battery and replacing the SIM card and battery and letting the OS load.  Who is your carrier?
Mar 26, 2009 | Cell Phones
RIM BlackBerry Curve 8310 Smartphone Logo
324 people viewed this question
Top RIM Computers & Internet Experts
ismael castillo
David
Jerry Greenberg
Jerry Greenberg
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
