Question about Kitchen Ranges
Zanussi zcg 7690 cooker main oven won't work. the clock says auto and can't change it. the time is stuck on zero and won't chane.
  • Anonymous Mar 28, 2009
    I have the same problem with my ZCG 7690. The clock just flashes 0:00 and the auto light flashes and you cannot set the time as per instruction manual.
    I onlywanted to time a hard boiled egg and its broke!
  • 1462 Answers
SOURCE: Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
Posted on May 04, 2007
SOURCE: cooker stuck on auto
Comes on like this when switched on, hold down the left 2 buttons on the clock controls then whilst still holding them pres the right hand button
or manuals available here...
http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Posted on Dec 10, 2007
  • 1314 Answers
SOURCE: stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Posted on Mar 15, 2008
SOURCE: zanussi zce 7690 main oven
Thought someone may find this helpful. We bought our Zanussi ZCG7690XN just 4 yrs ago. For nearly 2 yrs the main oven control stopped working. Never got round to replacing the timer controls- ~£80 or so. Read through some threads and thankfully found a few helpful. What I found difficult after accessing the control unit was recognising the correct wires to connect so as to isolate(over ride) the timer unit. Finally sorted this and presto it worked. The same process may help those who wish to replace their unit with a new one.
For those who will try, take safety precautions. If the spark generator works, there is likely power to the timer unit (and oven). If not check fuse, confirm mains supply.
The control unit is accessed first by unscrewing top oven front plates to gain enough room. Then with a flat screw or similar tool, take off the two small clock knobs and the two adjacent burner dials. you would then need to undo four little screws two on each of the burner dials. You can now gently extract the controls from below -can be tricky, (may or may not require using a plier to bend a bit of metal). With the unit out, turn it upside down and you would be looking at the rear of the circuit board with a blue wire, two brown wires connected to the relays and a red wire feeding back to the main oven dial(beside the spark generator). A green earthing is attached to the side . Leave this alone. All you need to do is to join the red wire to the nearby second brown(live)wire. I did this using connectors. Any other sensible means should be fine. The blue wiring returns to the light bulb and back with the others to electrics at the back. I took this off the timer as well.
I previously had recurrent problems with the grill spark unit connection- burnt off. Sorted this out by fixing the connection (access from the front top oven, unscrew a small metal protecting plate to reach it).
I do apologise if some find this too lengthy. Any questions are welcomed.
Posted on Dec 26, 2008
  • 5 Answers
SOURCE: I have a zanussi gas cooker. we had a power cut
There should a symbol of a hand on one of the switches or buttons, press or turn and then it should set to manual.
Posted on Oct 11, 2009
Oven wont heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 06, 2011 | Zanussi Ovens
Oven will not heat up
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Zannussi Gas cooker
May 04, 2007 | Zanussi ZCG7550 Gas Kitchen Range
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
