Question about GPS
I dont know how to put my x sport bth 10 into pairing mode! help please!!
5 Suggested Answers
  • 3 Answers
SOURCE: how do I put my bluetooth into pairing mode?
What kind of phone do you have?
Posted on Nov 24, 2008
SOURCE: Need help with Case Logic bluetooth ear piece model BTH-10
The generic PIN for that bluetooth is : 1234
Good luck
Posted on Dec 12, 2008
  • 4 Answers
SOURCE: Bascially i have an Icon Universal Bt4517t
Once switched on, pair up by holding in both volume controls + and -, pairing code should be 1234.
cheers
Ray
Posted on Jun 23, 2010
casouzaj
  • 1118 Answers
SOURCE: Dont know how to put jabra bluetooth earpiece it
Start with your headset turned off. Then, press and hold the answer/end button, until the indicator light is steadily lit in blue. It is in paring mode now. Then, make the bluetooth application on the device you want to pair your headset with, search for new devices. After a while, the BT350 headset should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user manual happens to be missing, feel free to download it from this location.
Hope it works for you.
Regards, Carlos
Posted on Jul 10, 2010
Im having trouble with my bluetooth device model BD-03 (argos MK9 2NW) my vista lappy cant find device and i dont have a disc for it please can you help me thank you
Hi there, Try putting the device in pairing mode. Normally this can be accomplished by turning the device off and then holding the power button for about 10 seconds. The device needs to power up and you need to continue to hold down the power button. It will alert you when it is in pairing mode. Once in pairing mode, try and have your laptop find it. It should work then!
Alex
Jun 06, 2011 | Computers & Internet
After i paired the blootooth device to my ps3 i deleted the information that it was linked to the ps3 and now i wanna pair it again but it doesnt want to go to pairing mode
To put your device into pairing mode you hold the power button down for 6 to 10 seconds when turning it on, a solid light should go on,thus letting you know it is in discovery mode,then you will need a pin pairing code,most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999, glad to be of assistance ,i hope this helps
Feb 26, 2011 | Jabra BT4051 Bluetooth Headset
Forgot passcode and cant find manual so i cannot pair it with my new phone
iIf you know how to put ur device into pairing mode then most pass codes or pins\pairing codes are as follows 0000,9999,1111,or 1234 most blue toth manufactures from north america use 0000 i hope this helps but you need to know how to put ur blue tooth device into pairing mode ,usually you hold the power button on for 6 to 10 second untik u have a solid light or tone depending on the device u have..once again i hope this helps
Feb 21, 2011 | Anycom HCC-250 Bluetooth Headset
I have a samsung behold T919 & I am trying to pair my Emerson EM228WM Bluetooth Headset to my phone but it wont find the signal please someone help me! Thanx :)
hello ,now most blue tooth devices have to be put into a discovery mode,if you dont have your owners manual to follow the procuders most of the time you just hold the power button while turning the bt device on for 6 to 10 seconds and that turns it into discovery mode usually a solid light is on then when the device is found it will ask for a pin or pairing code,this is a 4 digit code,most manufactures use the following codes,0000,1234,9999,1111, hope this helps you out.
Feb 21, 2011 | Southern Telecom Emerson Bluetooth Headset...
Dont know how to set it up
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make the phone's bluetooth application search for new devices. After a little while, your headset should appear on your phone' screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros) on your phone. If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds).
By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
Feb 02, 2011 | Emerson EM227 Bluetooth Headset
I switch out my phone for a different phone im trying to set my bluetooth to my new phone and its asking for my passcode i dont remember it. please help
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds). By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
Dec 27, 2010 | Emerson EM227 Bluetooth Headset
I cant get my headset to pair with my samsung gravity T669, i dont know how to put a password into my headset ? how do i connect?
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on your phone' screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds). By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
Sep 06, 2010 | Emerson EM227 Bluetooth Headset
Lost manual for BTH-03B1 where can i get a copy as need the factory setting pass code to use it again as will not register again
The headset has two buttons, one big (MFB) which does multifunctions inc volume + and one small which does volume -
To pair start with headset OFF and have your handset within 1 metre.
Press and hold the MFB for 8 seconds until the headset LED flashes red and blue. Its now ready for pairing.
Activate your mobile Bluetooth function to find and select BTH-03B1 from the list.
Enter the passkey "0000" when asked
When pairing is completed the LED will flash blue every 3 secs in standby mode.
To operate in use use the MFB to increase volume. You also use this to answer calls by press for 1 sec. or end call by pressing for 3 secs.
You can do headset to handset/headset and use the small button by pressing 3 secs to transfer.
Feb 06, 2010 | Radio Communications
LG HBM 300 Bluetooth headset
Hey make sure your headset is in pairing mode before you search for it. You might have to hold the on/off button for 5 to 10 sec. Then your 0000 will work.
Aug 01, 2008 | LG HBM-550 Wireless Headset
GPS Logo
60 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
