Question about Dometic Rooftop RV Air Conditioner
I have a Puma 30DBSS travel trailer with a 30 amp service and would like to install a second rooftop a/c since the one cannot keep up with the high humidty and heat. Stand alone unit or ducted into the current ducts?
Dometic air on a puma turns off and on
Posted on Aug 23, 2011
  • Dometic Master
  • 6,674 Answers
As "Icemelts" has stated, unless your unit is already set-up for 2 units, it will require a lot of work to do it properly. even if you go with ceiling discharge instead of running in to the duct work, you still have to get a supply cable there for 120VAC. Although you have 30 amp service, you will not be able to run both units at same time, unless you have a generator running to power one or the other separately. Both units will draw 13-15amps when running, and up to 17-18 amps when compressor kicks in, so when you add that to a fridge that's running, as well as converter, coffee maker, toaster , or any other appliance you have to use, your main breaker will be tripping constantly, if it doesn't trip constantly with just the 2 AC units running. I'd watch for one of those portables on sale, and use it where you need it the most. Their easy to discharge out a window. Tinted windows, shade on roof would also be a little help as well, but I wouldn't go through the hassle of installing another rooftop unit when you'll only be a able to run 1 at a time. Even with a portable, you'll have to juggle power, such as making sure it's off when you need to coffee, or to use microwave etc. Run fridge and any other accessories on propane if that option is available, to reduce power needs in trailer.
Posted on Aug 01, 2010
    Novelist:
    Champion:
  • 246 Answers
I'm from East Texas and me and my wife are full-time Rv'ers (since May 2010 when we both retired), so your question is an interesting one especially since we spent 2 weeks (1-15 July) in East Texas in some brutal heat/humidity.
I must say that when I bought my 5th wheel (38' Open Road) - I suspected that my AC unit (1 on the roof) would not work well in the hot Texas 'sun,' and it .... did not. But, in any event - like I mentioned - I "was not" surprised.
My idea was to stay out of the hot summers down here - which we plan to do from now on - but - because of a 'family reunion' we had promised to attend - we did - as I mentioned above - spend a couple of weeks in the heat. The best I could do was to hold the inside temp to 82-84 degrees and that was by making sure 'everything' - pressures, amps, freon charge, coils being clean' - was operating at maximum effienctly.
Like I said - we don't plan on being here (East Texas) during the brutal Texas summers in the future - but - if I was going to be - I would do the following.
#1 Fix - 'if I was not "moving" the RV and it was staying in one place and was likely to stay in that one place for a long time - I would install a 8 to 10,000 Btu window unit in my bedroom. In the winter I would probably leave it in the window (although removing it would be an option) and just 'cover' it with plastic of some sort to keep the cold out.
#2 Fix - if I was planning on 'moving' the RV in the future - and especially if I was planning on moving it 'often AND - staying in "hot weather country" - I would have a "stand alone unit" installed on my roof - right over - the bedroom. As for size I think I wouldn't put anything bigger than a 10,000 Btu unit in, and might even opt for a 8000 Btu.
The main reason I would stay away from using the existing duct in combination with the air I am adding - is that the duct system on a RV is fragile/troublesome to begin with and I would hesitate to 'add' to the load on it - or - to put all my eggs in one basket so to speak.
Again, the window unit (in the window) is the best and the cheapest option you have and if I wasn't planning on moving it - that is what I'd do. Here's a thought - since we've been in Wisconsin visiting my wife's sister (average daytime temp around 80 degrees) our AC has been 'freezing' us out - working like a charm. So.. if you 'are planning' to move and think you'll be able to stay out of the 'really hot weather' (like Texas/Oklahoma in June/July/August) - then the window unit (Fix #1) is by far the best option because when you leave you can take it out - restore your window to it's normal condition - sell the AC for a few bucks and be on your way.
Note: Since you have a 30 amp service - I would highly advise you to check with an electrician/Air Conditioning Service Tech about the "added amp draw" you will have and be sure - that your RV will handle the "extra electrical load" - any - modification you make will cause.
hope this has helped
Posted on Jul 29, 2010
Wiring diagram for coachmen 30 RLS travel trailer wiring diagram for coachmen rls 30 travel trailer
You might try calling Coachmen direct, or contacting them through their website. You could also describe the actual issue you are having here.
Jun 02, 2016 | RVs
I have a 2000 forest river 31 bhss. I was looking to find out what the correct weight of it .
go to a transfer station and weigh it,we r fixya,not your scale
Jul 24, 2015 | RVs
Hooking up electric power from house to travel trailer
At yr breaker box if there is room add either a new 120v or 220 breaker and wire frm there. You need to check how much voltega and amp. Yr travel trailer needs. Plus how far away breaker box is frm trailer and get the correct size wire if needed. Make sure you have neut. And ground correct. Please doulble check. What iv offerd. For yr solution
Nov 17, 2013 | Palomino 2013 Puma 31-DBTS
Travel trailer electric hook up
Most all travel trailers are set up for 30 amp single pole service which means 110 volts. Always check with your service manual and make sure, if you hook it up wrong you will burn up/smoke some electronics and it can be a costly problem. Also, a 30 amp service for travel trailers are not like a regular receptacle, it takes a special type of recept. Most any good electrical supply store can lead you in the right direction but you MUST know how to wire it up to code in your area! If your not a licensed electrician or at least know what I am talking about, I wouldn't recommend you doing this! It may have to be done in GFI and/or waterproof connections.
Nov 17, 2013 | Palomino 2013 Puma 30-DBSS
2007 dometic Rooftop AC "high-lo" switch. What does it do?
YES WITH OUT A DOUBT .. DO NOT TRY TO RUN IT ON HIGH IT MAY DAMAGE YOUR GEN SET ... HELP ? PLEASE VOT
May 28, 2010 | Dometic Rooftop RV Air Conditioner
What size tow ball needed, 2 or 2 1/4,
If you look at the tongue of the trailer it will say what size it needs. I would think you will need a 2 5/16" ball but check to make sure by looking at the tongue.
Subikid90
Mar 03, 2010 | 2007 Ford F-150 Harley Davidson
THE BREAKER CUTS OUT ON LOW AND HIGH
Current draw to high....BREAKER COULD BE WEAK..
Aug 18, 2009 | Dometic Rooftop RV Air Conditioner
Install a second DuoTherm A/C in a fifth wheel travel trailer.
You do not without removing wall board. You can do a nice neat job of white conduit on the outside of the wall and ceiling. I have done it and my customers are happy with it.
www.coachtech.info
Mar 19, 2009 | Dometic Rooftop RV Air Conditioner
1998 Sonnybrook travel trailer
Did it just start to do this, or has it always been that way? Are you original owner? Did it work fine before? Make, model# of AC unit & thermostat would be of help too.
Aug 22, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
479 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
