Question about Motorola Mobility W230 Phone US with Warranty
W 230 display problem
I bought a w 230 motorola 2 yrs ago. But, at present there is a problem in the display while switching on the phone display is not coming.And after trying for a hundred times it comes but again it vanishes
I have this same problem with my motorola w230.. Mine will be two years old in another 10 days.. I have this problem since today.. Googled for some help and found this page.. Will be taking it to a service center tomorrow..
Posted on Sep 29, 2010
Hello, I installed a T104 timer switch following the directions on the manual. I connected supply lines to terminals 1 & 3 and the load wires going to the pool motor on terminals 2 & 4. The clock...
It doesn't sound like you are getting a true 230 volts to the timer. Measure from terminal 1 to terminal 3. You should read 230 volts. If you are getting 230 volts between 1 and 3, return the timer, it's defective. If you are not getting 230 between 1 and 3, then you'll have to have a look inside the electric panel to see what has been miswired. There should be a 2 pole breaker with a white and a black wire connected to it that goes out to the timer.
May 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
A couple of days ago I found the only way i could talk out or hear incoming was to switch to speakerphone
It seems that some early batches of this phone are more prone to present this issue. It's a hardware problem. Some posts around state that it might be caused by usage of the wired headset. Motorola is aware of this problem, and they seem to be either fixing faulty phones or replacing them for new ones. So, you must send yours to be repaired, under warranty. Contact either the seller you bought your phone from, or Motorola, for further details
Anyway, a possible workaround for this issue is to use a bluetooth headset for phone calls.
Really hope you are able to have your phone fully funcioning pretty soon. This phone is pretty amazing!
Regards, Carlos
Apr 04, 2011 | Motorola Mobility Defy Cell Phone
My tracfone is dead will not come on at all. It is not the battery for I have checked it. serial no. 012111002103886 motorola H270 it occurs when I turn it on it does not come on. Nothing I do not know...
hello,two things could warrant your phone not to power on,
1.bad battery,which you said you checked and does not seem to be the problem.
2.a bad power switch,so i will advice you check the power switch if not faulty,but if it is you will have to replace it.you can get it at a mobile phone accessories store,
take care.
Aug 11, 2010 | Motorola Mobility TracFone® V170 Cellular...
Big problem for my motorola
have you ever got the phone wet?? Try taking the battery out. that usually resets it
Sep 01, 2009 | Motorola Mobility V360 Cellular Phone
NEED A PUK CODE & DOESNT HAVE A LANDLINE
HI,
The only way to get the PUK code is to contact your service provider.Only they can help you with this issue.
Feb 10, 2009 | Motorola Mobility W220 Cellular Phone
W230 my w230 fon does not switch phone memory to memory card
go to music library.. click the menu button and select "Switch storage device " option.. then select memory card ...The files on the memory card will be displayed..To switch to phone memory again..follow the same steps and select phone memory option....
Jan 23, 2009 | Motorola Mobility W230 Phone US with...
External display
you can try and do a master reset and master clear that should fix the issue.
Jan 08, 2008 | Motorola Mobility RAZR V3
W375 is acting weird
I have motorola w375 mobile but in this mobile How use data cable or usd drive on this mobile
Aug 28, 2007 | Motorola Mobility W375 Cellular Phone
Motorola Mobility W230 Phone  US with Warranty Logo
71 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
