Question about Lexmark X75 All-In-One InkJet Printer
I just installed a new cartridge black 17 for the Lexmark 505 and now it does not print anymore. I get error 126
  • 2072 Answers
SOURCE: Lexmark X1185 won't Print Color
On your printer, there is a clean print head adjustment,it is in your menus on the printer itself, It should also be on your print driver in properties. I would try running that up to 5 times before proceding to anything else.
Check and be sure the cartridge expiration date is not exceded. The liquid ink cartridges have an expiration dates. Even though the cartridge is new, Do not rule out a bad or for some reason dryed out cartridge or blocked port at the bottom. If it is indeed brand new and you have the receipt, I honetsly would suspect the cartridge itself.
Ok now, we tried the print head cleaning, and a second cartridge.
Next, I would remove the cartridge, turn the printer off and lightly, very lightly dampn a dusfree cloth with some alcohol, and where the cartridge is located, clean those contacts. reinsert the cartridge and see what happens.
Lastly, you can unplug the printer, remove the cartridges, and place a paper towel under the area where the cardtidge latches in, and dribble in a soapy cleaner, like fantastic, because those inks will dry out in the ports and not allow the ink to flow properly, If you do that, wipe all the excess cleaner up and leave the printer off for an hour or two to allow any remaining liquid to evaporate. Don't use a lot, but trickle it in until you see the ink start to wash out and all the ink is removed.
Take your time, and go from easiest to more difficult. I think that is the process I presented.
Posted on Feb 22, 2008
IB4G2008
  • 3587 Answers
SOURCE: Lexmark 1200 does not recognize black ink
that's good..after replacing a cartridge, it's highly recommend to do a clean and re calibrate...you can do this from front panel.
Posted on Mar 09, 2008
SOURCE: Lexmark 2500
me too.
Posted on Apr 04, 2008
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
Posted on Aug 19, 2008
SOURCE: Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Posted on Sep 12, 2008
I am having trouble with my printer its a Lexmark Z605 Z600 Series I bought a new Black Cartridge16 and it wont print out clearly it come out very faded i had a 17 Black in before this one.Cheers Bev.
Are you sure your new cartridge compatible with your printer....
A faded print image is normally the result of one of three conditions: The printer is getting low on toner, the print density is set too low, or Economode printing is turned on.
If you need any kind of technical assistance then you can contact support cell at http://vtechsquad.com/printer-support/
Sep 05, 2012 | Lexmark Office Equipment & Supplies
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
There was a burning smell when printing and the black cartridge seem to be burnt at the bottom and then the error 1203 showed up. What can I do?
1203 error indicates a defective cartridge is detected. It would be best not to use your burnt black cartridge anymore to prevent further damage to the printer. Try to replace it with a new genuine cartridge. However, if error continues even with a new cartridge, please contact Lexmark technical support for additional assistance. Thanks.
Feb 18, 2011 | Lexmark X4270 All-In-One InkJet Printer
Cartridge Error message on our Lexmark X5150
The Lexmark machines are designed to kick out anything it suspects may be refilled. If your old cartridge has bad print nozzles this may be tripping the error. Printers are typically for sensitive with their color cartridges anyway because the manufacturers make more money on the color ones. You can try looking around the settings on the machine and in the printer preferences to see if you can tell it to ignore the ink levels and see if you can continue to print.
Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
I've just installed a new black cartridge (no 17) into my Lexmark printer X1170 but keep getting the message Print Cartridge missing Install a cartridge to continue printing What can I do? Many...
It seems the cartridge you have changed is not accepted by your printer.
Make sure you have changed the same no cartridge.
pull out the cartridge and and fix it again make sure after placing at will no shaking in printer.
May this will help you.
Nov 20, 2008 | Lexmark Office Equipment & Supplies
Lexmark printer
Lexmark technical support should be able to help resolve this problem, assuming the cartridges were Lexmark branded. Contact information is on www.lexmark.com.
Feb 13, 2008 | Lexmark International Z611 Printer
Lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Nov 08, 2007 | Lexmark Inkjet Z517 Photo Printer
Lexmark X75 All-In-One InkJet Printer Logo
144 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
