Question about Whirlpool GD5SHAX Side by Side Refrigerator
In between doors on side by side fridge is hot. Whirlpool GD5phax
In between doors on side by side fridge is hot. I check fan next to comp and its not blowing. Can I put an external fan on comp to keep it working until I can get the correct fan motor?
    President:
  • 1,891 Answers
You need to fix the fan down by compressor as it cools the cond coils and causes proper orp of cmpressor . if it not running the comp runs too hot and does not pump the refergent and may be shutting of on overload . the high tempt between the doors will be less with fan working . but some warm tempt is normal .. mm
Posted on Jul 29, 2010
  • brianhend461 Sep 15, 2010
    I had the same problem and replaced the fan motor and it worked for a few minutes but now it seems hot again and the fan wont come back on? Any other suggestions?
Hot between door side by side
Check your coils underneath first and make sure they are clean, next pull out the fridge and check the fan in the back next to the compressor. See if anything is blocking/binding it. If it is not running (while fridge is running) and not obstructed GET A FAN and put it behind the fridge to blow air across the coils under the fridge until you get a replacement fan or a service tech over.
Jun 17, 2010 | Whirlpool ED5SHAXM Side by Side...
Hello, we have a whirlpool side by side (estate...between the doors is very hot the compressor is so hot you'd have to have pot holders to remove it. the fan is running fine the fridge and freezer are both...
Check the condensor coils and clean them. The condensor fan may be running slower than normal. It is working hard to move the heat. The area between the doors has a line there purposely to keep it warm so moisture that condenses there when the doors are opened evaporates and doesn't cause mold.
eric
Oct 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fbb36af20/2 fridge freezer frame of front fridge freezer getting hot, fan at bottom back stoped working replaced fan but when you plug in new fan it starts to work but when you fully push the fan...
Hot frame is mullion heaters. Keeps moisture from forming on door and causing rust. Sounds like the connector is defective, remove connectors and wire direct. If fan won't run then you need to call a qualified service tech.
Sep 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The strip between freezer and fridge is very hot
sounds as if you either need to clean the coils under the unit,they are clogged and unable to disapate correct amount of heat, or your fan mounted behind the unit, next tothe compressor has failed..YOUR UNIT IS WORKING EXTRA HARD TO GET RID OF HEAT.check those 2 places
Jun 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fan on my fridge is working, but its not cold. Everything thawed out. Do you know wht this could be?
There are a couple things to check and do.. 1st check if your compressor is hot.. (pull fridge out, back bottom area remove to get to comp) if comp is hot possible refrigerate leak.. the other is capacitor (or hard start kit is needed)... unplug fridge and let sit for a few hours (like 5hrs).. plug back in.. you should feel cloud in the freezer area in 15min.. if not then, your possible problems I mention 1st.. hope that well do.. good luck.. mike
Jan 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge & wont get cold wont get cold, fans is on motor gets hot
check to see if compressor is running if not replace relay also make sure ur condenser motor is running
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Front metal piece that the seal goes against - between freezer and fridge
ED5VHGXMQ10 Whirlpool Fridge
I have the same problem. Too hot to touch between the freezer and refrigerator door. Is
this normal?
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
145 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
