I have DFW-100i firewall and i dont the ip address of that firewall.i want to see the ip address of that firewall.if there any default ip address for that firewall.i connected the firewall to windows machine and i dont know how to access that firewall. please help...
  • 84 Answers
SOURCE: factory settings for a Linksys RV042
connect your router your computer via LAN cable
click start on windows
click run and type CMD
On the DOS command prompt type IPCONFIG/ALL
look for the gateway address, that is the IP Adress of your router
Posted on Feb 11, 2008
SOURCE: ICMP blocked automatically
return, cut this configuration, but put route the her isp´s.
You can ping after this?
Can´t ping you has other problem.
Posted on Mar 28, 2008
ggomez
  • 4 Answers
SOURCE: cant access my netgear router config screen
I have found my own solution to this problem. A cheap Lynksys wireless. I have found that it is fruitless trying to talk to netgear or Apple reps, one never gets to talk to someone really knowledgeable, and it is too frustrating having to step through their scripted questionaire. In addition there are a lot of well-intentioned people that can send you in a wild chase. No worth the waste of time when a $40 or less Lynsys would solve the problem. Good luck to the ones who still have the problem and still want to pursue a solution. Thank you to those who tried to help.
Posted on May 07, 2008
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Posted on Aug 10, 2008
efs_perpends
  • 1996 Answers
SOURCE: how do i configure my ip address manually for 2nd
Have you tried simply running the Network Connection Wizard from control panel? Here is a link to a basic guide. I'm not sure I understand whether there's an issue with the connecting computer or if you want to set up a host/client shared connection. If the latter see here. Does this apply to your situation?
Take a look at this post, and also see the FAQ sections of the same site for endless help.
You can also access 2wire tech support here.
If you think there may be some corruption in the 2nd computer, run chkdsk according to instructions here and here.
You might also have a look in the Device Manager and make sure the network adapter is working properly. It will show an exclamation point or question mark if it's having problems.
Your connection is behind the 2wire firewall, which should be turned on. If you mean your system firewall, OK for now...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 25, 2009
How do i reset my routers ip address
Are you talking about Firewall on Windows or on Router or you have a another firewall?
To reset routers Ip address just reset your router to default settings.
But doing that will no solve anything.
If you mean changing your public IP address then switch of your router and keep it switched off for sometime.
Once you switch it on it should have new ip address.
Oct 01, 2014 | NetGear WGR614 Wireless Router
Tip
Firewall Configuration
A firewall is a type of security mechanism used for preventing security threat in both incoming and outgoing computer traffic. It protects your computer system and/or the private network from intrusions.
It acts as a barrier, which checks all the incoming and outgoing information to and from your computer or a network based on the firewall settings. Firewalls can be customized according to the level of security required. It filters the messages based on some conditions, such as the IP address, ports, protocols, domain names etc.
These can be implemented in the hardware, software or sometimes both and scan the entire messages passing through it and veriy whether each block or packet of the message meets the specified security criteria.
Some operating systems like Microsoft Windows offers built-in firewalls, which are by default turned on to block incoming threats from the Internet. You can also look for any third-party software or hardware firewall to replace the default Windows firewall.
Types of firewall
There are various types of firewalls like:
1. Packet filtering firewall
2. Application-level gateways
3. Circuit-level gateways
4. Hybrid firewall
The role of packet filtering firewall is to examine the information available in the header of the message packets. The Application-level gateway firewall works on the application layer of the protocol stack. It works in a more intelligent way as compared to the packet filtering firewall.
Mentioned below are some of the conditions, which help in adding or removing the filters from the firewall:
1. IP address: Every machine connected to Internet has a unique IP address. You can customize the firewall to block any IP address, if it seems to show an uneven or unauthorized attempt or nature.
2. Protocols: You can decide which protocols to be included in your firewall’s filters. Some of the commonly used protocols, which can be included in the firewall are: IP, HTTP, TCP, FTP, SMTP etc.
3. Ports: You can configure the firewall to allow or block any port number.
Similarly, there are various other conditions which can be used to configure the firewall.
on Jan 27, 2010 | Computers & Internet
How do i unblock netgear firewall?
Sir to access the router, go to your browser then type in 192.168.1.1 then type in Under the Username field enter “admin” and Under the password field enter “password”. After this you are now in it and you can now configure the firewall to be in unblock mode. Before doing this sir, i suggest that you unplug any cable in the WAN slot and just leave the PC you are using to it.
Jul 19, 2009 | NetGear ProSafe FVG318 (606449041668)...
I can'yt open the firewall
if you are using windows xp go to the start button and in "run" box type "cmd" - a black window will open. then type in "ipconfig" you will then get a screen of information. then look for the ip address of your "Default Gateway". this is the ip address of your route... then go to a web browser and type this address in. you will then be taken to the web admin interface of your router.
Apr 28, 2009 | 3Com OFFICECONNECT VPN Firewall
Fire wall
you need to find out the ip address of your default gateway.. you can do this by going to Start then Run and typing in cmd. then in the black screen type in ipconfig... you will see somewhere on the screen your "Default Gateway" ip address... go back to a web browser and enter this address you will then be taken to the admin screens of your router where you can administer the firewall
Mar 02, 2009 | ON-Q Home 8-PORT Internet Firewall Route...
Can't connect
it might probably a security issue , can u remember from which machine and from what ip you access the firewall before ??
Try to assign the ip from which you have last accessed your firewall
Good luck
Nov 20, 2007 | SonicWALL PRO 100 Firewall
How do I open a range of ports on my VDI-604 or VDI-624 using firewall rules?
Step 1 You will need the IP address of the computer that you want to open ports to. How do I find the IP address of my computer? Step 2 Open a web browser and type the IP address of the VDI-604 or VDI-624 in the address bar (default is 192.168.0.1). Press Enter. Step 3 The default username and password is listed below for your version of firmware: VDI-604 firmware 1.05F/VDI-624 firmware 2.39DDM - The default username is admin and the default password is blank (nothing). VDI-604 firmware 1.07 Build 28/VDI-624 firmware 2.43 Build 12 - The default username is admin and the default password is password. Click OK. Step 4 Click the Advanced tab at the top and then click Firewall on the left. Step 5 Select Enabled and configure the following: Name - Enter a name to identify the rule Action - Select Allow Source Interface - Select WAN Source IP Range Start - Enter an IP address or * to allow this rule to apply to all incoming IP addresses. If you are opening this rule to a series of IP addresses, enter the first IP address in the range. Source IP Range End - If you are opening this rule to a series of IP addresses, enter the last IP address in the range. Destination Interface - Select LAN Destination IP Range Start - Enter the IP address that you obtained in Step 1 Protocol - Select the protocol (TCP, UDP, or Both) Port Range - Enter the starting and ending ports that you want to open Schedule - Select Always to apply this rule all the time or Schedule to specify a schedule Step 6 Click Apply and then click Continue to apply the new rule.
Feb 16, 2006 | D-Link AirPlus Xtreme Super-G DI-624...
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Can´t I access the web-based configuration
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration.
Computers & Internet Logo
75 people viewed this question
Alun Cox
David Payne
David Payne
