Question about Norelco 3405 LC Electric Shaver
What is the amount of volt that comes throuh thecord for this model
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 43 Answers
I have holden jackaroo 1996 check trans light comes on and flash ...and the battery volt indicator goes from around 12 up to 16 when it flashes and lose power. .. help please...
check the output of the alternator as the regulator should be set at 14.5 volts max 16 volts is way to much for the electronics and amounts to a power surge.
Dec 25, 2014 | Cars & Trucks
Fuse for Mitsubishi fuel pump
It is critically important for turbocharged models that the fuel pump receive the maximum amount of voltage available from the charging and wiring system. The alternator will try to maintain about 13.5 volts into the system. Resistive losses along the current path to the pump will reduce the voltage at the pump to something less than 13.5. If there are less than 12 volts at the pump, the amount of fuel flowing may be much less than expected and perhaps enough less to create lean air-fuel mixtures under heavy boost.
The instructions below show you how to bypass the resistor and relay that the turbocharged 3S models use to reduce voltage to the pump at idle. Please read through the instructions and look at the pictures before attempting this procedure. Before I did this relay/resistor bypass I measured the voltage at the pump using the method shown on my web page 2-fuelpumpvoltage.htm. At idle the pump was receiving about 6.7 to 7.0 volts. I saw from 10.6 to 10.8 volts as boost began to build and then watched that number drop to 10.2 to 10.3 volts as boost hit 15 psi or so and RPM approached redline. After performing the relay/resistor bypass I remeasured the voltage at the fuel pump with the following results.
Cold idle: 11 volts
Warm idle: ~10.6 volts
Warm idle after radiator fan kicked in: 10.35 - 10.55 volts
Acceleration and boost: ~10.5 volts
Feb 02, 2012 | 2000 Mitsubishi Galant
Replaced the touchpad and put it all back together. It now heats, but the oven light doesn't come on and the turntable doesn't rotate. Do you think there's a loose wire?
First check is the main fuse of the unit. On countertopunits, you will need to take the shell off. The fuse will be close to where thecord comes through into the unit. OTR units, this main fuse is usually behindthe control panel or possibly behind the vent. Usually the fuse is obvious ifblown, otherwise test with an OHM meter, if open, replace fuse. Some brands will also have a thermal cut-off fuse in theincoming voltage line to the control board. This thermostat looking fuse isusually above the oven cavity somewhere under the outside shell. Sometimes youcan get to it through the vent of OTR models. Test with an OHM meter, replaceif open. Forturntable: First, make sure the turntable coupler under the glass dish is notbroken. Second, on the control board, find the turntable relay and test forvoltage. Some turntable motors are 24 volts DC, so make sure you're testing thecorrect voltage. If no voltage from the control board, then replace the controlboard. Otherwise head towards the turntable motor. On OTR models, you can get to the motor by un-screwing thebottom panel on the microwave. On countertop models, there will either be aknockout or screw on access panel. Check for voltage at the motor. If novoltage, check the wiring back towards the control. If voltage, then replacethe turntable motor. Hope this will help you. Good Luck.
Sep 03, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
How to back up the phone data to PC
If your phone came with a USB data cable, plug thecord to your phone and connect to your PC via the USB port and backup your phone. It will show on your PC as a removable drive. Then you can transfer your files to your system.
Best regards
Aug 03, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Have a Sansui VCR/DVD player/recorder. I'm trying to record a VHS to a DVD. Lost the manual. Can you walk me throuh it?
Google the term "Sansui/the model number/manual." A lot of hits will come back, likely a number will have a free downloadable copy of the owners manual.
Jan 28, 2010 | Sansui VRDVD4005 DVD Player/VCR
Car won't turn over and it's not battery.
Motor cool!!!!!!!!!!!!!!!!!!I just turn the starter until it comes throuh the hole. Easy way to pull motor. lot more room
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_541ceb86d69e7743
Dec 06, 2009 | 1999 Oldsmobile Intrigue
Also looking for remote codes, model number in details
well i have looked throuh my remote codes book and none are listed for this brand. i hasve never heard of it either, where is it made India?
Jul 31, 2009 | Sova DSV32P112 32 in. LCD Television
Power cord purchased from after market company
I am sorry I have not! forgotten you my T.V. is hanging from the ceiling between two beams in my kitchen I was waiting for my husband to get in so he move it so I can get the information for you he's a trucker and will be in Wed around 5:00 pm. sorry I have not! forgotten you If i can get one of my neighbors to get for me I will carol
Sep 01, 2008 | Televison & Video
Norelco 3405 LC Electric Shaver Logo
128 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
