Question about HP Compaq ProLiant ML530 Server
I have a dead 34.6 GB drive in my ml 370 raid disk array. AND i have a spare BUT I dont know what on it., if i swap it out will the operating system automatically over rwrie what on it??? or do i have to format it ,, and how?? itrken@verizon.net
  • itrken Jul 29, 2010
    the server accepted the solution and is back up. Thank you
  • HP Master
  • 11,800 Answers
When you replace a disk in an RAID array everything that's on the new disk gets erased. If you still need that then put it in another pc and make a backup of that data.
Unless you are using a RAID 1 configuration (in which case when a disk has died everything on that server has been lost) you don't have to do anything after you replace the disk - all will be done automatically.
Posted on Jul 29, 2010
  • Azrael SRL Jul 29, 2010
    BTW if a disk has died from what appears to be old age, then the others can't be far behind. Make a full backup and if the another disk dies then replace them all.
Operating system corrupted how to recover the data
RAID is only to protect data in case of hard drive failure. Data is only recoverable from backup.
However, if you have a separate arrays for the OS and data. Meaning two arrays, you can swap arrays onto an identical server with same array configuration. Drive positions (bay /slot) are critical.
Oct 01, 2012 | IBM x3400 Server
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
I have got a 3 disk raid5 IBM xseries Server which does not boot. How can I resque data from these disks?
I'm going to go out on a limb and assume that you don't have a good backup of the data on your RAID array. So, generally speaking, the operating system is probably installed on a separate disk from your raid array (not a guarantee). But if this is so then you should be able to reinstall your operating system and drivers (esp RAID controller) to that (separate) disk and you're off to the races (replace this system disk if necessary). -OR- Depending on the make of your RAID controller you may be able to transplant your RAID controller into another machine and all the original drives along with it, so long as it has a battery backup and you place all the drives in their original order. If there is no battery backup on your RAID controller then DON'T PULL THE PLUG ON THE ORIGINAL MACHINE AND DON'T EVEN CONSIDER removing the RAID controller in any way. If you have any doubts, whatsoever, have someone with experience in RAID arrays do the work for you. It will be well worth it! (RAID arrays aren't for the faint of heart)...
Aug 24, 2011 | IBM eServer xSeries 225
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
A DRIVE RAID 0 VOLUME IS FAILING GENERATION 2
> RAID
Rapid Array of Independent Disks
RAID logically combines several identical disk-drives for better performance or for better reliability.
For better performance, one RAID configuration "stripes" the data, i.e., when you write a block of data, the block is split into "stripes", and each stripe is written to a different disk-drive.
Since each stripe is smaller than the whole block, it is faster to transfer the data in "parallel".
For better reliability, another RAID configuration writes each block of data _identically_ to multiple disk-drives. Thus, if one disk-drive fails, your data still exists on the other disk-drives.
You can then replace the "bad" disk in the array, and use software to "rebuild" this "mirroring" of your data, by copying all the data from one of the "good" disks onto the "new" disk.
So, in your case, one of the disks in your array is failing. Identify it. Replace it. Rebuild your array.
Sep 26, 2010 | Dell 500 GB 7200 RPM SATA Internal for...
MY fdf12072S WAS WORKING FINE ON MY COMPAC BEFORE. bUT THE COMPUTER WAS GETTING SLOW AND SO AFTER REFORMATTING THE DESKTOP AND REINSTALLING SOME OF THE VARIOUS SOFTWARES I WAS ASET TO TRANFER THE...
did you change operating systems? windows doesnt recognize EXT2 formats there may be an issue there.
was the other drive part of a raid array before the retooling? if it was part of a raid array you may need to rebuild the array before accessing the files.
next insure there are no special drivers required to access the drives nothing wierd like scsi interface or PCI card controller?
if there is no wierd issues try useing the setup disk as a boot disk drop to DOS and access the drive that way.
Jun 10, 2010 | Fantom Drives FDU12072S 120 GB Hard Drive
CAn I disable RAID on a DEll powervault 770n server
Its called the JBOD RAID option - just a bunch of discs.
I don't know of any system that makes a RAID array an operational imperative, I would say the answer to your question is yes.
RTFM.
Oct 04, 2009 | Dell PowerEdge 2600 Server
Help please to restore the failed raid
Well if your data is gone at this point, you mines well just proceed with rebuilding a new RAID 5 set with your replacement drive. Even if one drive fails in a RAID 5 set, your logical drive should still be accessible. Goodluck.
Jun 14, 2007 | Quantum Guardian 4400 120 GB Hard Drive...
HP Compaq ProLiant ML530 Server Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
