Question about Brand Remote Start/keyless/car Alarm Very Sleek
Installed a new battery to the remote yesterday now system is going bananas need help to reset just bought car have no manuel
MY 1998 Dodge Dakotas power door locks click on and off as I'm driving down the road. any thoughts on what could be causing this problem?
Hi Robert:
We've been going bananas with the same problem on both aN Aztek and the Buick Terraza. GM shops are telling us to look at $350 to ??????????? as desperately complicated.
HERE'S SOMETHING THAT CAN BE THE CAUSE:
CHANGE THE BATTERY IN YOUR REMOTE.
IT CURED THE BUICK YESTERDAY.
Haven't tried the Aztek yet.
Jun 05, 2015 | 1998 Dodge Dakota
Car alarm disabled starter?
You might have blown a fuse check your fuse box in your car, or disconnect your battery and let it sit for at lease a hour and then try to put the battery back on your car.
Dec 30, 2012 | Hyundai Motor 2004 Sonata
99 AEROSTAR VAN HOW DO I BYPASS THE ANTITHIEFT TO GET MY CAR TO START BATTERY JST INSTALLED AND WHERE IS THE FUSE AT IN WHAT SLOT I DONT HAVE OWNERS MANUEL
You do not need a remote to deactivate the factory system, it is deactivated when you insert the correct Key to open the door and start eh van.
Jul 02, 2012 | Ford Windstar Cars & Trucks
New battery -alarm sounds- have to disconnect the battery-
The sounding alarm maybe a security system installed by in the truck. Disconnecting the battery will only temporarily solve your problem, but will resume once you reconnect the battery for electrical power.
You must find the keychain/remote of the security system and disable it. If you are unable to locate this, you can have it disconnected by a qualified automotive electrician.
Word of caution though, if you are using the keyless entry system with the security system, this will be disabled until you install a receiver with such function.
Hope this helps.
Jun 29, 2009 | 1999 Nissan Pathfinder
Remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
Mar 01, 2009 | DEI Python 1400XP Remote Start/Keyless...
System Low Battery
Response 1 is correct. If you plugged the transformer into an outlet before connecting the battery the system wont see the battery and give you that error. Should be a simple fix however. Unplug the battery and then the transformer, then reverse the process. Plug in the battery and your Simon should power up, then plug in the transformer. If this doesn't help then you should replace the battery. Did you buy the system from a dealer and have it professionally installed or did you do-it-yourself? If it was professionally installed have your technician come back out to diagnose/replace the battery if needed. Good Luck.
Feb 10, 2008 | GE Security Simon 3 Wireless Home Security...
Got a Defective remote.
It sounds like weak batteries. Have you replaced them?
Feb 02, 2008 | Philips PM-8FS LCD Touchscreen Remote...
Remote stopped working
already tried a new remote and new batteries. bose says the ir bulbs need replacement so i'm taking it in. shucks.
Dec 23, 2007 | Bose (321GS) System
Brand Remote Start/keyless/car Alarm Very Sleek Logo
15 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
David Burbee
David Burbee
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
