I am trying to install windows 7 through usb but its doesn't pick at start-up. my usb is in NTFS format.
  • shaanishaah Jul 29, 2010
    i have tried it. its boots from usb but when there is time to pick the setup files then it gives an error.
  • 808 Answers
Chek ur boot menu and change it on usb or removable media any of 1 presnt there then try again
Posted on Jul 29, 2010
  • Suuny Kohn
    Suuny Kohn Jul 29, 2010
    Then it the error in the copy of ur windowx file
Format windows 7 and install windows xp
Use the XP install disk to format the drive during the install process with NTFS file system. Then install XP.
If the disk does not allow you to go backwards to an older OS you need to format the existing drive in your laptop with external software on a usb or cd rom, etc. Then do the xp install. Before doing the deed make sure you download the drivers needed for the XP install on a usb stick or something.
Feb 12, 2016 | Computers & Internet
Tip
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of...
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br /> <br /> <br /> Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br /> <br /> or <br /> <br /> <br /> <span style="text-decoration: underline;">Please follow the steps below</span><br /> <br /> </b> <b>Required:</b><br /> <ul> <li>USB Flash Drive (4GB+)</li> <li>Microsoft OS Disk (Vista / Windows 7)</li> <li>A computer running Vista / Windows 7</li></ul> <b>Step 1: Format the Drive<br /> </b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br /> <ol> <li>Plug in your USB Flash Drive</li> <li>Open a command prompt as administrator (Right click on Start &gt; All Programs &gt; Accessories &gt; Command Prompt and select "Run as administrator"</li> <li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br /> <span>diskpart<br /> list disk</span><br /> The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li> <li>Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.<br /> <span>select disk 1<br /> clean<br /> create partition primary<br /> select partition 1<br /> active<br /> format fs=NTFS<br /> assign<br /> exit<br /> </span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol> <b>Step 2: Make the Drive Bootable <br /> </b>Next we'll use the <i>bootsect</i> utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:<br /> <ol> <li>Insert your Windows Vista / 7 DVD into your drive.</li> <li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br /> <span>d:<br /> cd d:\boot</span></li> <li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:<br /> <span>bootsect /nt60 g:</span></li> <li>You can now close the command prompt window, we're done here.</li></ol> <b>Step 3: Copy the installation DVD to the USB drive<br /> </b>The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.<br /> <b>Step 4: Set your BIOS to boot from USB<br /> </b>This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.<br /> <br />
on May 19, 2011 | Computers & Internet
Tip
How to install windows 7 from pen drive
Its very difficult to install windows 7 if you are not having a DVD drive, Especially when you are planning to upgrade your windows xp system you would like to see how vista looks. So you need to install it and see. Requirements: USB pen drive 4GB or more
Windows 7 DVD
Step 1: Download HP USB storage format tool from here and install on your computer.
Step 2: Once you finish installation, double click on HP USB storage format tool and format your pen drive in NTFS
For this, select NTFS from File system option and Check quick format option and click on start.
While doing the format the data stored on your Pendrive will be lost. You keep a back if needed. Press YES on the warning message
Once the format finished you will get a message with the details and Click
on OK
Now insert Windows 7 DVD in to DVD Drive and go to command prompt.
For that go to start -> RUN and type CMD and press enter or OK
You will see the command prompt with black back ground
Now you need to change the directory to your DVD drive where you put the windows vista DVD.
For that type G: and press enter (here I am using G because in my system DVD drive letter is G. So you need to check your DVD drive letter and type accordingly)
So the directory will change to G:>
Now type cd boot and press enter
Now the interface will be like G:boot>
Then type bootsect.exe /nt60 h: (where h is the drive letter of your pen drive)
Now you will get a successful message like below
Now you can close the command prompt and copy all the contents from the windows 7 DVD to the pen drive
It will start copying now
Once it’s finished, you need to restart your pc and access the bios of your system and make first boot device as USB pen drive.
That’s it, now you can see installation starts from the USB pen drive.
on Mar 02, 2010 | Computers & Internet
My cd/dvd drive G:\ (hl dt st rw dvd gcc h21n version.1.00) does not reads windows 7 dvd .. and it only reads cd-r/cd-rw.... plzzz help i want to install windows 7... plzz help...
It sounds like your drive is having issues, you can always install windows 7 from a flash drive (so long as your computer supports booting to one). Instructions on setting this up are here: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/ You will need to do this from a computer with a working DVD drive to transfer the info to a flash drive.
Jun 28, 2011 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
How to boot my laptop into usb drive
You have not specified your operating system. However I will explain how to do it with windows 7. First you have to create a bootable flash drive. Do it as follows
Format USB flash drive to NTFS format(For Win XP only. Vista users can directly format the USB drive to NTFS format) In your Windows, go to Control panel -> system -> hardware -> Device manager.
Under the disk drives section, right click on the USB storage drive and select Properties.
device-properties.pngGo to the Policies tab, select optimize for performance. Click OK.
device-policy.pngOpen your Windows Explorer, you should see the USB storage drive in the inventory. Right click and select Format. Select NTFS from the drop down bar. Click Start.
format-ntfs.pngFor Windows XP,
Download MBRWizard. Extract the zipped files to your desktop.
Open a command prompt (Start -> Program -> Accessories -> Command Prompt).
cd Desktop/MBRWiz2.0/
MBRWiz /list
Record the USB flash drive disk number
mbrwiz-list.pngMake the USB drive active.
mbrwiz /disk=X /active=1
For Windows Vista,
On the Start menu, navigate to the command prompt entry. Right-click and select Run as administrator.
vista-command-prompt.pngType
diskpart
list disk
Record the disk number of your USB flash drive.
vista-diskpart.pngSelect the USB disk.
select disk X (X is the drive number of the USB flash drive)
List the current partition. Record the partition number.
list partition
Select the current partition and make it active.
select partition Y (Y is the partition number of the USB flash drive)
active
list-partition-vista.png Creating bootable USB flash driveDownload Windows 7 iso (32-bit) file to your desktop (The download link is no longer valid).
Download and install WinRAR.
Right-click on the Windows 7 iso file and select Extract files. Extract the files to a folder (you can name the folder any name you want, but for illustration purpose, I name it win-7) in your desktop.
extract-win-7.pngIn your command prompt, cd to the windows 7 folder.
cd Desktop/win-7 (Change the destination to the folder that you have extracted)
cd boot
bootsect /nt60 X: (X is the drive latter of your USB drive )
bootsect-success.pngNow, copy all the files from the Windows 7 folder to the USB flash drive.
Reboot the computer. Remember to change the first boot device to your USB drive in the BIOS.
You should be able to install Windows 7 from your USB flash drive now.
Apr 26, 2011 | Sony Vaio Pcg-Z505N/Bp...
I have a 32GB sandisk cruzer stick. I've used what is called diskpart in Windows 7 to select and format the stick in fat32. I'll take it to a Windows XP box and try to drop a substantial size file to...
Sorry but you wont be able to put a file larger than 4gb due to file format limitation since you used fat32. only NTFS supports files larger than 4gb. if you want to use it with large files you need to format again using NTFS. hope that helps!
Mar 23, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I am trying to install windows 7 on my eeeboc pc. When I come to choice of installation place the error message says that windows can only be installed on a ntfs disk. There are two partitions defined...
during windows 7 installation it asks " which type of installation do you want" select "custom (advanced)" option. after " compatibility report" window, next option is " where do you want to install windows" in this window, select or click on the partiotion where do you want to install. after clicking it shows the option's below like " refresh" " delete" format" etc select " format" . format the drive with ntfs . its simple .... thank you . keep smiling aaarwind_1.jpgaaarwind_2.jpgaaarwind_3.jpg
Jan 14, 2011 | ASUS Computers & Internet
Massstorage
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Jan 23, 2009 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
