Question about Linksys Wireless-G WRT54GS Router (e125894)
Everything is connected my laptop was able to find the name of my wireless but was not able to connect. I'm using windows 7 on the laptop. Any idea of what i should do to fix the problem. Everything was working fine until now.
  • 3,530 Answers
Hi. First issue why your laptop cant connect to your router is regarding witht the password. Make sure that you are typing in the correct password of your router. Check the type of authentication used e.g WPA, WEP etc. Second issue, is this the first time you used windows 7 OS in connecting to your router. There are issues in linkys routers that is not compatible with windows 7 and you need firmware upgrade for your router. You can also try to test the connectivity using a wired conncetion (LAN cable) conncet directly to your router nd se if you were able to get an internet concetion using a wired connection.
Have a good one!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jul 29, 2010
Tip
How to configure the wireless connection ?
Configuring the Wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
on Jan 22, 2010 | Computers & Internet
Hi I am trying to fix a freinds laptop which has some network issues. It will not connect either with an ethernet cable or wireless. I know the router is working as my own laptop/PC connect okay. I have...
Hi there. My guess is it's the drivers. Sometimes windows update doesn't use the best driver for the product. I would find out what wireless and wired network cards he has and then search the original manufacturers website for the driver. You can find out about the name and manufacturer through device manager. Alex
Jul 13, 2011 | Linksys Wireless-G WRT54GS Router...
Newly purchased Belkin Surf N300 wireless router. connected my wife's Windows 7 laptop just fine - quick and easy (in fact using it now). Went to connect my XP netbook - connects wirelessly to router...
There will be a lot of possible reasons on that, might be the wireless settings of your computer , you may try to remove all the old networks saved in your laptop and try connecting to it again,heres how 1. locate the wireless icon at the lower right hand corner of your laptop 2. Click on View available wireless settings 3. Click on Change advance Settings on the left side 4. You will have a small window with 3 tabs, one is general but just look for wireless tab 5. Box below you will see the list of the wireless name that was saved . 6. Delete everything, then make sure you apply it if there is or clicking on OK will do 7.Then try connecting again and make sure your password is correct.
or it might be your security application, try checking it and see if there's need to change especially if you got norton installed in your computer, try uninstalling and reinstalling it.
Jul 03, 2011 | Belkin Surf N300 Wireless N Router
Trendnet router will not give a wireless signal, Wi-fi on laptop is enabled, direct connection from modem to laptop will give internet connection. Tryed unplugging everything, resetting it. Nothing I know...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop/desktop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Apr 13, 2011 | Trendware TRENDnet TEW 632BRP wireless...
I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
Here is the link ..
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
Dec 26, 2010 | Computers & Internet
I need help connecting a second computer to a Intellinet 5-port fast ethernet office switch. I have one computer up and running by setting up a new connection, how do i connect a second or third computer...
1.Log into router. Using either 192.168.0.1 ot 192.168.1.1 in a browser window that is ( internet Explorer or firefox)
7. try to log on to the internet.
Aug 26, 2010 | Computers & Internet
Does not provide reliable wireless connection for my laptop
1.Log into router. Using either 192.168.0.1 or 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
7. Move the laptop about 20ft away and try to log on to the internet.
Aug 19, 2010 | D-Link AirPlus DI-614+ Wireless Router
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router (192.168.0.1) user name "admin
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
Wireless unable to connect
Windows 7 is not best suited yet for wireless connectivity, but broadcom wireless cards/dongles are about the only ones that work favourably with this Microsoft offering. Anything to do with non working hardware IS A DRIVER ISSUE AND IF IT IS NOT IN THE UPDATE SITE YOU WILL HAVE TO DOWNLOAD DRIVERS FROM THE VENDOR OF YOUR PARTICULAR HARDWARE. MOST HARDWARE THAT WORKS IN VISTA WILL WORK IN WINDOWS 7.
Dec 23, 2009 | HP Pavilion dv9000z Notebook
Linksys Wireless-G WRT54GS Router (e125894) Logo
93 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
