Question about HP Pavilion a1710n (RK573AA#ABA) PC Desktop
What kind of CPU coolers are compatible with HP Pavilion a1710n?
  • HP Master
  • 5,660 Answers
The HP Pavilion a1710n desktop computer, comes with an AMD Athlon 64 X2 processor.
(4200+ is the Model Number.
At full capacity it operates at 2.2GigaHertz.
2.2GHz
Giga = Approximately 1 Billion
Hertz stands for Cycles per Second
The 4200+ can operate up to a frequency rate, of 2.2 Billion Cycles per Second )
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00835807&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3340227
This AMD Athlon processor uses an AM2 processor socket.
Socket AM2,
http://en.wikipedia.org/wiki/Socket_Am2
When buying a CPU cooler, look at what processor socket it is for, first.
Then if processors are listed, make sure the Processor in your computer is compatible, with what is listed.
Finally see if the Height of the CPU cooler is listed. If not, suggest you perform a search on the internet for that cooler, and see if the specifications are listed.
The motherboard rests sideways in the computer case. The Width of the computer case is taken into account, for comparing the Height of the CPU cooler, and determining if it will fit.
When looking at the high-end CPU coolers, you also have to take into account the circumference of the CPU cooler.
Make sure there are no hardware components nearby the processor socket, that will interfere with mounting that cooler.
If you are just looking for a replacement CPU cooler, and not a high-end aftermarket unit, this is one example for stock replacement,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2604150&CatId=2545
This is another example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4557678&CatId=2545
Also recommend that you replace the Thermal Paste compound.
To cheap in cost not to replace, and is always added insurance.
An example of Thermal Paste (Grease) compound,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3522883&CatId=503
The top of the Processor's case must be thoroughly cleaned, before applying new thermal compound.
There is a tried, and true method I use, and would be happy to pass it on. (Post in a Comment for guidance)
CAUTION!!
Always follow Anti-Static Precautions, BEFORE you reach inside your unplugged from power computer.
A Processor, is the Most susceptible computer hardware component, to Static shock!
Posted on Aug 01, 2010
    Novelist:
  • 145 Answers
That's a hard question to answer, you need to fine out what CPU you have inside and then look up CPU coolers for that CPU style. Since your using a pre assembled machine you may have a specialized hole pattern making an aftermarket cooler hard to find. and use.
How do I fix an overheated hp pavilion all in one?
Check CPU cooler, remove it and clean it, make sure that the CPU fan cooler is in good working condition.
Jun 18, 2014 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
What CPU 'chips' can be fitted to the HP Pavilion slimline magnetite motherboards ?
according to HP's compatibility list..
CeleronM 420 (Y) 1.6 GHz
  • 533 MHz front side bus
  • Socket 479
    May 25, 2014 | Washing Machines
    Hp pavilion a1710n doesn't send to printer. Goes through every step,doesnt send. My laptop workds with the printer.
    A few things come to mind. Are you sure the printer isn't a D4160??? The C4160 was sold in England. Anyways...
    First, when you hit print a box opens up. On the top of that box make sure your printer is the one selected. It will have a green checkmark by it.
    Second. Make sure the USB cable is connected between computer and printer. The Hp pavilion a1710n doesn't have a wireless network chip so it will need the USB cable connected for it to print.
    I assume your laptop prints wirelessly and that is why it works and the HP does not.
    Good Luck
    Dec 07, 2013 | HP Pavilion Computers & Internet
    Best cpu upgrade for HP pavilion MS214 AIO PC
    This sounds like a good idea, I would go for the upgrade, since I don't and very rarely have had an AMD system, I'm not 100% sure on which chips are compatible, as for the wattages, that's the thermal design power (TDP) or heat output so the PSU won't need to be changed out, heck, I have a 192.1W psu on a system that needs a 300W PSU, my CPU TDP is 110W, no issues there apart from energy efficiency of the PSU under full load!, your PSU should be fine, they're normally rated higher than the system needs under a load to improve efficiency, the load is best optimized at 50% but the PSU on your system under an intense load should be around 60% with the new chip which is pretty good if you ask me :)
    in other words, go for the upgrade, get a chip that works from Amazon or EBay for a low price, then, if it isn't compatible, it won't be much of a a big loss... anyway, there's always overclocking, just get a more powerful cooler and crank that clock speed up, the chip should handle up to 2.08GHZ which is a really good overclock for a chip like that!, remember to stress test the system for at least 24 hors on an overclock with Prime95 (from Mersenne Prime search)
    Good luck :)
    Jun 24, 2013 | HP Pavilion AllinOne MS214 185" Desktop PC...
    Audio drivers for a1710n
    You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
    http://welcome.hp.com/country/au/en/cs/support.html
    Feb 12, 2013 | HP Pavilion a1710n (RK573AA#ABA) PC...
    My hp Pavilion G7 notebook PC core i3 is hot in the left hand side shift and control key area. Please find a solution.
    This is pretty normal because under those areas is where your processor installed. For modern processor, on high resources application the processor will load and cpu cooler will work and heat will spread on the area nearby, otherwise on low resources application the processor will using an idle process...
    To reduce it you can use notebook cooler..
    Aug 10, 2011 | HP Pavilion dv7-1132nr Notebook PC
    Hi! My Hp Pavillion a1710n desktop emits a series of never ending beeps every time I turn it on, and nothing appears on the monitor. I checked and the monitor is plugged in. I dont know what's going on.
    The problem with RAM or DISplay card(It can be Moisture problem) or Processor Fan is not working properly. Open the CPU case, locate RAM, remove the ram by opening the both side clips. and put the RAM back as it is. If you have Graphics card on your CPU then remove the Graphics Card also and put it back as it is. Start the PC with opened case to check Processor Fan is Rotating or not. If Fan is not working properly then you have to replace the Processor FAN. Fan ok but same problem persists. you have to replace RAM with new one. as well as Graphics (Display) card.
    Jan 19, 2011 | HP Pavilion A1710N Desktop PC
    My HP Pavilion tx 1000 continues to freeze every few minutes.
    it is a 2 posibility problem: 1)driver problem;
    2) cpu to hot , you must check if the cooler work;if yes you must open the case take out the whole cooler and clean the radiator wings(a lot of dust) and then apply new termal paste , the old is crusty.
    That must solve your problem.
    Jan 08, 2009 | HP Pavilion dv1000 Notebook
    Cpu fan mount
    goto: www.geekscomputer.com
    or Ebay and search your motherboard model #. Boards are pretty cheap, but difficult to find those specific parts sometimes.
    Good Luck,
    Mark
    Dec 30, 2008 | HP Pavilion a1710n (RK573AA#ABA) PC...
    HP Pavilion a1710n (RK573AA#ABA) PC Desktop Logo
    97 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
