Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Electrolux Dishlex DX302WB No display. Seems to be no power. Plug is plugged into the power and power point is switched on. Any clues?
  • Electrolux Master
  • 12,061 Answers
If there is NO display then this is fairly major. Please check, the main Fuse or Circuit breaker. If they are OK, then you have some sort of internal disconnection, usually caused by a faulty. "Brain" or Main Board.
Please find below your service and repair manual, this should help you troubleshoot and hopefully effect a repair.
http://frigidaireservicetips.com/pdfs/467_10.pdf
Below is a self help how to repair your dishwasher between this and the manual, you should have a good shot at repair.
Else call a reputable serviceman and ask for a 'Quote" before proceeding with any repair.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Posted on Jul 29, 2010
  • j_w_hannafor Jul 29, 2010
    For some unknown reason, the display mysteriously came back on and nothing I do makes it go back off again, save pressing the power button. It sounds like one of those bloody intermittent problems!
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Oct 14, 2014 | Washing Machines
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
Electrolux washer dryer EWX14440W. It just seems to have died. No power, noise, lights, error codes or other signs of life. Can anyone advise where to start?
check fuse in plug ,check main circuit breaker tripped also do u have a neon switch on wall in room check this fuse also, to check scoket out let plug some thing else thats works to check out scoket out let
Aug 31, 2013 | Electrolux Washing Machines
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
I have a dishlex Global 500 which runs for 3-5 minutes then displays nF
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Aug 05, 2009 | Dishwashers
Vulcan Dishlex 160 Diswasher
Hello Ranjan_MYD Welcome
You said, You have Vulcan Dishlex 160 Dishwasher which was kept in good conditionafter using for few years, then it was NOT used for few years. When itis installed again in a newly constructed house having 3 phase powersupply, the dishwasher functions well, does the job, but only just atthe end of the drying cycle before completion of the washing job itmakes some click noise and the power trip occurs. When intended to useagain the same event recurs. Any clue please? I can't recall the nameof the manufacturer. Also would it be possible to get an user manualprint out from the web please?
Your machine is and Electrolux Dishwasher.
Here is a site you can get a manual from:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man&cmpid=RegEmail
Let me know how you do!
Huuum
Please remember to leave a rating!
Oct 22, 2008 | Dishwashers
Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Aug 24, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
279 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
