Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Keeps coming up with fault "F1" - Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
Is that in one drawer or both?
Generally it means the flood switch under the drawer (inside the housing is activated). This means water is leaking from somewhere - foam in detergent, cracked or crinked hoses, door seal leak etc.
To fix, take the drawers out from housing and dry the flood switch located in the centre of the housing base. Need towels and hair dryer.
Make sure the power is turned off.
Posted on Jul 30, 2010
What is f1 mean
sadly with no MAKE,MODEL , we can not look for any fault errors try Google
Nov 09, 2015 | Kitchen Ranges
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
Jan 24, 2013 | Fisher DD603FCSS Dishwasher
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 fault when oven is just sitting.
There are several sufix numbers after your model number so I just picked one, They are often the same as they usually keep the same wiring harness and circuitry through out many.Here's what I've found, Electronic control has detected a fault
condition. Press CLEAR/OFF to clear the display and stop the
beeping. Reprogram oven. If fault remains, record fault number.
Press CLEAR/OFF and contact a Service Professional. See:
https://www.searspartsdirect.com/partsdirect/user-manuals/GLEF396ABA-Frigidaire-Parts-Range-Parts-manual#
or choose from your complete model number:
https://www.searspartsdirect.com/model/search.html?q=GLEF396
Good luck
Oct 30, 2017 | Frigidaire GLEF396 Electric Kitchen Range
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 on the read out comes up and the oven well knot work it keeps comeing up f1 on read out it is a maytag rang mer5770aab sel.no.13196174uu
Hi martysherrip,
The F1 fault code description is a defective touch pad or clock (ERC). Please refer to the steps below for additional information.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back.
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Jan 02, 2010 | Maytag MER5775Q Electric Kitchen Range
Our magic chef oven f1 code keeps coming on
MAGIC CHEF
Range/Stove/Oven Fault Codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Feb 07, 2009 | Magic Chef 31000 Gas Kitchen Range
I have a whirlpool "cabrio" washer and dryer set the washer keeps coming up with an F1 code and the dryer has a AF code. I cannot locat my factory books on these appliances. Can you tell me what...
an f1 code on your washer is a fault in the electronic controls, as far as the AF on the dryer, its an AIR FLOW issue, you need to check your venting its restricted
Jul 23, 2008 | Whirlpool Washing Machines
Maytag Electric range F1-1 persistant fault code
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
#$%^Y
Jun 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
211 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
