Problem: Cannot create file "C:\Windows\system32\IOSUBSYS\PCOUFFIN.VXD". W7 OS Thanks
2 Suggested Answers
angelo_mlc
  • 1035 Answers
SOURCE: I have just upgraded to
Hi. Did you mean upgrade or downgrade? XP is older version than windows 7. Error you are getting means that the system cannot find the path specified. Are you installing the program using the the installer disk?
Posted on Oct 02, 2010
D3dx9_29.dll file not found
d3dx9_29.dllThis is because you are missing a file.Step 1. You can download d3dx9_29-dllStep 2. Paste this file into your system32 and system folder. Also put it in your syswowStep 3. Navigate to your System32(32Bit OS) or SyWOW64(64Bit OS) Folder.Note: The location of System32 or SyWOW64 isC:Windows\System32 (If you are using 32Bit Windows))C:\Windows\SysWOW64 (if you are using 64Bit Windows)Step 4.Paste the d3dx9_29.dll into this folder.Step 5.Run the game. It might work now.
Jan 17, 2012 | Jade Empire - Special Edition for Windows
I loaded Check-it Fastmove on a laptop running windows XP. It will not start up and gives the following message: Could not start communication service. It worked fine on my old Desktop running windows XP.
I struggled with this same problem a few years back. I tried a couple of different compatibility modes for the fastmove.exe file and finally settled on Windows 98/Windows ME mode. When you right click on fastmove.exe and enable this mode in properties, you still aren't all the way there. When you try to run fastmove in this mode you will get another error message. Something about how it could not find a file called paralnk.vxd (actually the error message mispells the file name as paralink.vxd).
Well this file is only necessary for parallel port connections which I don't think anyone uses anymore (everyone should be using USB to sync). So I got to thinking that all the Fastmove program needed to see was a dummy file called "paralnk.vxd." And I was right. So this is what you need to do.
1. Find "fastmove.exe" in your program files, right click on it, click on properties, go to compatibility tab, enable "Windows 98/Windows ME" compatibility mode.
2. Go to your Windows\system32 folder and right click on some empty space. A dialogue box comes up. Mouse over "New" then click on "Text Document." After you have created the new text document, rename it to "paralink.vxd." You will get a warning message about changing the filetype from txt to vxd, but ignore it.
It doesn't matter that the new paralink.vxd is just a dummy text file. Fastmove doesnt use the file for anything. It just wants to see that it is there.
And that is how you get fastmove working on XP. It also works in Vista.
I sure wish they would update this program, but it got discontinued. Best sync program I ever used. I wish I knew who the actually developer was. I would contact them and see if they wanted to update it on an open source project.
Sep 19, 2010 | Smith Micro CheckIt FastMove...
I Unable to access my Laptop please help me out.
hi,
do not choose safe mode,instead choose the start normal, If still you can not load and error exist, there might be missing of your files or your files are corrupted..Format your computer and back your important files then install new (OS) Operating System.I hope this may help you.
best regards,
kaybicks
Feb 27, 2010 | Toshiba Portege 320CT Notebook
When I insert a cd in my player I get this error oe 0028:c182b573
Method ONE Disable the SCSI1HLP.VxD using the Microsoft Configuration Utility:
  1. Restart your computer, press and hold down the CTRL key while Windows is starting, and then choose Safe Mode from the Startup menu.
  2. Click Start, click Run, and then type msconfig in the Open box.
  3. On the Static VxDs tab, click to clear the Scsi1hlp.vxd check box, click OK, and then follow the instructions to restart your computer.
Method Two loadTOCNode(2, 'resolution'); NOTE: By following the steps below, any device that uses the Scsi1hlp.vxd file may not function properly or you may not be able to restart your computer. Some SCSI devices and some ATAPI devices use this file. If you are not sure if your hardware uses this file, check with your hardware manufacturer before you proceed.
Rename the Scsi1hlp.vxd file in the Windows\System\Iosubsys folder:
  1. Restart your computer, press and hold down the CTRL key, and then choose Safe Mode from the Startup menu.
  2. Click Start, point to Find, and then click Files or Folders.
  3. In the Named box, type scsi1hlp.vxd, and then click Find Now.
  4. In the list of found files, right-click the Scsi1hlp.vxd file that is located in the Windows\System\Iosubsys folder, and then click Rename.
  5. Type scsi1hlp.old, press ENTER, and then restart your computer.
Apr 04, 2009 | Microsoft Windows 98 for PC
DVD X Copy Install Problem - Unable to find path
What you would need to do is go to www.driverguide.com and search for pcouffin.vxd and copy it to c:\windows\system32\iosybsys. Then it should install fine.
Jan 31, 2009 | Computers & Internet
Vmm32.vxd problem on windows millennuim edition its saying load windows loader dont knoe it please help have no disc omputer given to me thanks
just go to start button goto run type regedit and press ctrl F and then type vmm32.vxd and press find and if the file that type is showed delete the vmm32.vxd and press F3 to search again the if you find another file like that again just delete it and its finished restart your computer.
Nov 25, 2008 | Computers & Internet
Hi uplate
c:\windows\system32
open up "oemlogo.bmp" using paintbrush and save again as oemlogo.bmp making sure that it is going to be saved in the same place ie c:\windows\system32
once done either edit the oemlogo.bmp file or create a new image file, making sure that your new image file is the same pixle size as the origional oemlogo.bmp file.
my current oemlogo.bmp file is quite small, but experement to see what is best.
I initially found out how to do this from the following link. not all systems have this oemlogo.bmp file but you should be able to create one and save it in the system32 folder without issue.
http://www.windows-help-central.com/xp-system-properties-logo.html
Nov 07, 2008 | Microsoft Windows XP Professional
The following file is missing or corrupted; C:\WINDOWS\SYSTEM\VMM32.VXD type the name of the windows loader (e. g., C:\WINDOWS\SYSTEM\VMM32.VXD)
That is a special file, created during Windows installation. Every computer uses a different VMM32.VXD file, so you can't simply copy one from another system and expect it to work.
If you can't find that file by searching the system in DOS, you could wipe the drive and reinstall Windows again, or do a repair install, installing Windows on top of itself. That should force the creation of a new VMM32.VXD file, and that problem should be history.
If you DO find the file somewhere on the HDD through a DOS search, copy it into the Windows\System folder, then reboot the system.
Jul 23, 2008 | Computers & Internet
98 loading error message
When you format something you WILL lose all of the data that was there. I would also recomend upgradeing to XP, 2000, or NT. You may need to reinstall the OS. If you need instructions ask me and I can help.
RCF
May 29, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
60 people viewed this question
Alun Cox
David Payne
David Payne
