Question about Campbell Hausfeld PW1750 Electric Pressure Washer
Campbell hausfeld 1750 psi pressure washer won't turn on at all? no light up on the test or reset buttons when plugged in. Is there A fuse on these things that I can replace? or does anybody have A quick fix?
3 Suggested Answers
  • 251 Answers
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Posted on Nov 19, 2009
  • 420 Answers
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
Campbell Hausfeld 2200 psi pressure washer doesn't build up pressure
2 possibilities. It is not getting enough water from the hose or your pressure regulator is bad. Does it sound like the engine is developing full RPM? Could be and engine problem if not coming up to full speed.
May 04, 2015 | Campbell Hausfeld Garden
My electric Campbell hausfeld 1750 psi won,t always start when I pull the trigger .sometimes it will quit while running. the motor and pump seem to be free. it works good while it is running. CR
Hi , i'm not familiar with the machine so without model numbers it is hard to diagnose.
if it is a trapped pressure unloader valve, ie the motor turns off when you let go of the trigger , then it is possible for it to be a pressure switch causing problems. the pressure switch may turn it off immediately you let go of the trigger or it may have a delay stop on it, where it will turn it off after a predetermined time interval. it is quite common for springs to break or microswitches to fail in these switches.
Oct 15, 2013 | Garden
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Campbell Hausfeld 13 gal air copressor, when I trun it on it won't build up max pressure and won't shut-off One of the gauges reads 40 PSI the other reads 60 PSI.
Your problem is most likely because of damage to the valve plate or piston & cylinder. If one or both of these are not working properly you'll get partial pressure and the unit won't turn off because the tank never comes up to full pressure. Things to check for are damage to the reeds on the valve plate, they could be bent from overheating or broken from use or wear or damage to the piston seal which can cause damage to the cylinder. If any of these aren't sealing properly the air pressure will come up to a point where the air leaks out faster than it goes into the tank. Without your particular model number I don't know which parts to recommend but if you contact Campbell Hausfeld they'll help you get the right parts.
May 12, 2011 | Campbell Hausfeld 13 - Gallon Air...
Gun
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
My electric pressure washer's motor will not start. the 110 plug has a test/reset fuse on it. when i plug it in the light comes on. i push test- it turns off but motor does not run. i push reset and...
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up.
Apr 15, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
My 1750 psi campbell hausfeld pressure washer will operate at first until I release the trigger on the wand. Then it won't restart. If I wait for a while it will run again. Sounds like the pressure switch.
Common with that washer...it has a wabble pump. Release the trigger, if by pass does not engage, stalls engine. You can however keep using it, all you have to do is keep trigger pressed, and when you are cranking engine, depress trigger with the free hand. Can be repaired, but the fix probably will cost more than a new pump.
Oct 18, 2009 | Garden
Campbell Hausfeld 1750 Pressure Washer Won't Start
throw it away seems to be the only solution since no one has a clue in what there talking about, nothing froze always cleaned out system and still wont start, campbell hausfeld does not have a clue neither, they told me you got to check this one out, drop unit about a foot off the ground and yea i tried it about 8 times then almost threw it across the yard, oh well i hate being negative and love to fix whats broke but the hours spent i could be making money and just buy another, thank you
Feb 26, 2009 | Garden
Campbell Hausfeld PW1750 Electric Pressure Washer Logo
335 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Steve
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
