Question about Dishwashers
My Dishlex Global 300 dishwasher stops mid cycle and the rinse light keeps flashing ?
I think I had the same problem. I don't know much about dishwashers, but the "Flashing Rinse" has something to do with the drain, or the drain pump (which is why the water doesn't drain).
My dishwasher stopped its cycle, after having filled up with water, even though everything else worked fine, because the drain pump was not even turning on. So I guess, the first question I asked was, is the drain blocked? No. When this happened the first time, the flashing rinse cam up. After that, the dishwasher just wouldn't drain, and there was no longer a flashing rinse.
So then, I figured, the drain pump is probably rooted. The drain pump is found underneith the dishwasher, just behind the front panel on the left hand side.You'll need to remove the metal covers from the front and the left.
When this happened to me, I thought I'd need to buy a new pump, so I pulled the other one out (its a bit fiddly, you have to disconnect the two electrical wires, then remove the drain pipe from it, and then wiggle it off. But when I got it out, I unscrewed it (it has the special hexagonal screws, not phillips or flathead), and it turns out, a fairly large fruit seed had got into the drain pump and blocked it, preventing it from spinning. I put it back together again, and it worked.
It so far has beaten paying $100 for a new pump.
If you want a visual of what the drain pump looks like, look up the dishwasher part number #8905912, you should be able to find it on the internet. Hope this helps.
Posted on Sep 17, 2010
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
Dishwasher stops part way through cycle
Sorry I have taken along time to reply but I lost my email access for awhile.Now the fault with your dishwasher is its taking too long to drain.Please reply if you still require help.Once again sorry for not getting back to you sooner.
May 27, 2010 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
Dishwashers Logo
594 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
