Question about Advanced Graphics Programming Using OpenGL
Twenty-five numbers are entered from the keyboard into an array.The number to be searched is entered through the keyboard by user.Write a program to find if the number to be searched is present in the array and if it is present,display the number of times it appears in the array.
  • 27 Answers
Pseudo is
-> integer type count =0;
->Take input from user 'Number'
->loop from 0th to 24th element
->Compare each element with user entered number and if it matches then do count++.
finally display the count.
Posted on Aug 10, 2010
Write a program that accept a number and output its equivalent in words.
Below is the program written in Turbo C.
#include<stdio.h>
void pw(long,char[]);
char *one[]={" "," one"," two"," three"," four"," five"," six"," seven","
eight"," Nine"," ten"," eleven"," twelve"," thirteen"," fourteen","
fifteen"," sixteen"," seventeen"," eighteen"," nineteen"};
char *ten[]={" "," "," twenty"," thirty"," forty"," fifty"," sixty","
seventy"," eighty"," ninety"};
void main()
long n;
clrscr();
printf("
Enter any 9 digit no: ");
scanf("%9ld",&n);
if(n<=0)
printf("Enter numbers greater than 0");
else
pw((n/10000000),"crore");
pw(((n/100000)%100),"lakh");
pw(((n/1000)%100),"thousand");
pw(((n/100)%10),"hundred");
pw((n%100)," ");
getch();
void pw(long n,char ch[])
(n>19)?printf("%s %s ",ten[n/10],one[n%10]):printf("%s ",one[n]);
if(n)printf("%s ",ch);
Aug 06, 2010 | Borland Turbo C++ Suite 1.0...
Tip
HOW TO COUNT THE OCCURRENCES OF A TEXT STRING
In the cell that you want the result to appear in, enter the appropriate formula from the following examples.
How to Count the Occurrences of a Number
Use this formula
=SUM(IF(range=number,1,0))
where range is the range that you want to search, and number is the number that you want to count.
NOTE: This formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
How to Count the Occurrences of a Text String
Method 1
Use this formula
=SUM(IF(range="text",1,0))
where range is the range that you want to search, and text is the text that you want to find (the text must be enclosed in quotation marks).
NOTE: The above formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
Method 2
Use the COUNTIF() function to count the occurrences of a text string. For example, use the formula
=COUNTIF(range,"text")
where range is the range of cells that you are evaluating, and text is the text string that you want to count instances of (note that text must be enclosed in quotation marks).
Wildcard characters can be used within the COUNTIF function.
The asterisk character (*) represents more than one character. For example, to count all the cells in the range a1:a10 that contain an "x," you can use the following formula:
=COUNTIF(a1:a10,"*x*")
The question mark character (?) can also be used to represent one wildcard character -- for example, to count all cells in the range whose second character is the letter, such as "ax" or "bx."
=COUNTIF(a1:a10,"?x*")
on Nov 11, 2013 | Microsoft Excel Computers & Internet
Hwo can i solved a bineary search problam in c++
first arrange your array in ascending order.and keep the two variables one for starting index and one for last index
then check your number with center(center = (first index + last index))/2 element of array.
if it is lager then center element then set first index = center,
if smaller then last index = center
else you got the number..
Jul 25, 2010 | Borland Turbo C++ Suite 1.0...
Make a program that will accept tthe size of an array (number must be greater than). Enter and fill the array with numbers then sort in descending order (largest to smallest). Display the unsorted and...
coding in C++
#include<iostream.h>
#include<conio.h>
#define max 50
void main()
clrscr();
int arr[max],size=0;
int i=0,j=0,temp;
do
cout<<"Enter the size of array(less than or equal to 50)";
cin>>size;
} while(size>50);
for(i=0;i<size;i++){
cout<<"Enter a number";
cin>>arr[i];
for( i=1;i<size;i++){
for(j=0;j<size;j++){
if(arr[j+1]>arr[j]){
temp = arr[j];
arr[j] = arr[j+1];
arr[j+1] = temp;
cout<<”Array in descending order”;
cout<<arr[i]<<"\n";
getch();
return 0;
Mar 09, 2010 | Computers & Internet
C++ poker program
Hi.
I suggest creating an Array of Cards (cardOne,cardTwo,etc. to five)
If you can enter them in one at a time, after declaring the array, assign the values to the array.
cin < cardOne; (Psuedo code by the way, hope you don't mind)
Afterwards, you'll have an array with 5 cards.
Declare what full houses, flushes, etc would require.
Use an if statement (If you don't mind lots of code) to compare the entered Array against possible hands.
I didn't necessarily give you any specific C++ code. However, if you Google C++ user input, you should find plenty of commands that may help you.
Good Luck
(And not sure about Linear search to be honest, you can use a Linear search, but if you did it the way I explained, you just have to compare hand to a series of conditionals.)
Sep 23, 2009 | Computers & Internet
C++
http://www.cplusplus.com/doc/tutorial/
May 01, 2009 | Computers & Internet
Keyless entry on door 2003 ford f-150
this is from the Ford owners manual.
Programming a personal entry code
To create your own personal entry code:
1. Enter the factory set code.
2. Within five seconds press the 1 • 2 on the keypad.
3. Enter your personal 5-digit code. Each number must be entered
within five seconds of each other.
4. The doors will again lock then unlock to confirm that your personal
keycode has been programmed to the module.
Tips:
• Do not set a code that uses five of the same number.
• Do not use five numbers in sequential order.
• The factory set code will work even if you have set your own personal
code.
• If you set a second personal code it will erase your first personal code.
Mar 30, 2009 | 2003 Ford F150 Regular Cab
Please Solve this C++ Program
Write a program to prompt the user to input several lines of input. A line of inputs is terminated by '*'. For each readline of input the program should output:(use pointer notation for the array) . The total # of words . The lenght of the longest word in the line At the end the program should output: . The total number of words read in all lines of input . The lenght of the longest word read in all lines of input
Jan 19, 2009 | Computers & Internet
Open Questions:
my code in opengl does not work can any one help me #include <string.h> #include <GL/glut.h> #include "math.h" float rotate =0.0; float start = 0.0; float z_dep = 0.0; int poi_size = 0; int poi_arr[100][2]; float rad_arr[50]; int m_x = 0; int m_y = 0; int rubber_band_on = 0; int down_flag = 0; #define MENU1 10 #define MENU2 11 #define MENU3 12 #define MENU4 13 #define MENU5 14 GLfloat r,g,b; GLint t=0 ; void sel(int item) { switch(item) { case MENU1: {r=1 , g=0 , b=0;} break; case MENU2: {r=0 , g=0 , b=1;} break; case MENU3: {r=0 , g=1 , b=0;} break; case MENU4: {t=1;} break; case MENU5: {t=2;} break; } glutPostRedisplay(); } void menu(void) { int MainMenu, SubMenu1,SubMenu2; SubMenu1=glutCreateMenu(sel); glutAddMenuEntry("red", MENU1); glutAddMenuEntry("bule", MENU2); glutAddMenuEntry("green", MENU3); SubMenu2=glutCreateMenu(sel); glutAddMenuEntry("line", MENU4); glutAddMenuEntry("circle", MENU5); MainMenu=glutCreateMenu(sel); glutAddSubMenu("Color", SubMenu1); glutAddSubMenu("Shap", SubMenu2); glutAttachMenu(GLUT_RIGHT_BUTTON); }void drawCircle(float radius, float x1, float y1) { float angle = 0; float x2,y2,cx,cy,fx,fy; int cache = 0; glBegin(GL_LINES); for (angle = 0; angle < 360; angle+=1.0) { float rad_angle = angle * 3.14 / 180; x2 = x1+radius * sin((double)rad_angle); y2 = y1+radius * cos((double)rad_angle); if (cache) { glVertex2f(cx,cy); glVertex2f(x2,y2); } else { fx = x2; fy = y2; } cache = 1; cx = x2; cy = y2; } glVertex2f(x2,y2); glVertex2f(fx,fy); glEnd(); } void tick(void) { glutPostRedisplay(); } void display1(void) { glClear(GL_COLOR_BUFFER_BIT); // Draw the lines created by user glBegin(GL_LINES); for(int i=0; i<poi_size; i++) { glVertex2f(poi_arr[i][0],poi_arr[i][1]); } if (rubber_band_on && (poi_size%2==1)) { glVertex2f(m_x,m_y); } glEnd(); glutSwapBuffers(); } void handleKeypress(unsigned char key, int x, int y) { switch (key) { case 27: //Escape key exit(0); } } void reshape(int w, int h) { glViewport(0, 0, w, h); glMatrixMode(GL_PROJECTION); glLoadIdentity(); gluOrtho2D(0, w, h, 0); glMatrixMode(GL_MODELVIEW); } void mouse_move1(int x, int y) { m_x = x; m_y = y; display1(); } void mouse1(int button, int state, int x, int y) { m_x = x; m_y = y; switch (button) { case GLUT_RIGHT_BUTTON: if (state == GLUT_DOWN) { // glutIdleFunc(spinDisplay); } if (state == GLUT_UP) { if (poi_size>0) { poi_size-=2; } rubber_band_on = 0; glutIdleFunc(NULL); } break; case GLUT_LEFT_BUTTON: rubber_band_on = 1; if (state == GLUT_DOWN) { down_flag = 1; } if (state == GLUT_UP) { if(down_flag) { poi_arr[poi_size][0]=x; poi_arr[poi_size][1]=y; poi_size++; down_flag = 0; } glutIdleFunc(NULL); } break; default: break; } display1(); } float calculate_radius(int x1,int y1) { int x_diff = m_x - x1; int y_diff = m_y - y1; if(x_diff<0) { x_diff *= -1; } if(y_diff<0) { y_diff *= -1; } float mag = x_diff*x_diff + y_diff*y_diff; float rad = sqrt(mag); return rad; } void display2(void) { glClear(GL_COLOR_BUFFER_BIT); for(int i=0; i<poi_size; i+=2) { int rad_index = (int)(i/2); float rad = rad_arr[rad_index]; if (rad>1) { drawCircle(rad,poi_arr[i][0],poi_arr[i][1]); } } glutSwapBuffers(); } void mouse_move2(int x, int y) { m_x = x; m_y = y; if (rubber_band_on) { float rd = calculate_radius(poi_arr[poi_size-1][0],poi_arr[poi_size-1][1]); rad_arr[poi_size/2] = rd; } display2(); } void mouse2(int button, int state, int x, int y) { m_x = x; m_y = y; switch (button) { case GLUT_RIGHT_BUTTON: if (state == GLUT_DOWN) { // glutIdleFunc(spinDisplay); } if (state == GLUT_UP) { glutIdleFunc(NULL); } break; case GLUT_LEFT_BUTTON: if (state == GLUT_DOWN) { down_flag = 1; } if (state == GLUT_UP) { if(down_flag) { poi_arr[poi_size][0]=x; poi_arr[poi_size][1]=y; poi_size++; down_flag = 0; rubber_band_on = !rubber_band_on; } glutIdleFunc(NULL); } break; default: break; } if (rubber_band_on && poi_size>0) { float rd = calculate_radius(poi_arr[poi_size-1][0],poi_arr[poi_size-1][1]); rad_arr[poi_size/2] = rd; } display2(); } int main(int argc, char **argv) { glutInitDisplayMode(GLUT_DOUBLE | GLUT_RGB); glutInitWindowSize(1000, 800); glutCreateWindow("OPENGL LINE DRAWING"); glClearColor(0.0, 0.0, 0.0, 1.0); menu(); if (t=1) { glutDisplayFunc(display1); glutReshapeFunc(reshape); glutIdleFunc(tick); glutKeyboardFunc(handleKeypress); glutMouseFunc(mouse1); glutMotionFunc(mouse_move1); glutPassiveMotionFunc(mouse_move1); glutMainLoop(); } if (t=2) { glutDisplayFunc(display2); glutReshapeFunc(reshape); glutIdleFunc(tick); glutKeyboardFunc(handleKeypress); glutMouseFunc(mouse2); glutMotionFunc(mouse_move2); glutPassiveMotionFunc(mouse_move2); glutMainLoop(); } return 0; /* ANSI C requires main to return int. */ }
Jun 22, 2013 | Advanced Graphics Programming Using OpenGL...
See all Advanced Graphics Programming Using OpenGL Questions
Advanced Graphics Programming Using OpenGL  Logo
972 people viewed this question
Top Advanced Graphics Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Advanced Graphics Computer and Internet Expert? Answer questions, earn points and help others
