Question about Nokia E71 Smartphone
No access to network
I have a nokia e71. suddenly today the phone does not allow me to make calls and no incoming calls too.. when i seart for network manually i get services of all the service provider. but when i select my desired network it says NO ACCESS..please give a solution for this...
  • Nokia Master
  • 4,737 Answers
What did the others say when they call on your number? or have you tried yourself using another phone? Seems like you'd hear "Incoming call to this number is not available" or something like that..etc..etc.. The problem is not with your phone if you can get the network and the error is "No Access". It's from the Network Operator, your only solution is to call the customer care of your network operator and ask them what's the matter with your sim card. Tell them your problem and they'll promptly help you. If you are not sure, you can put another working sim card on your phone and try calling using your phone with the other sim card. That should work fine without any problem.
The only solution is from the Network Operator.
Good luck.
Thanks for using FixYa.
Posted on Jul 29, 2010
Have used my Nokia E71 over 2 years. For past 2 days incoming calls do not show cell numbers stored in my sim/ phone memory. It only shows 'call' How can I rectify this problem? Ebow Essandoh
Try to reset your phone to factory settings by dialing *#7370# or manually click on Restore to factory settings options in your phone Settings.
Mar 06, 2011 | Nokia E71 Smartphone
I AM TRYING TO PREVENT MY PHONE NOKIA E71 FROM MAKING INCOMING CALLS IT ASK FOR CALL BARRING CODE
call your customer care nd ask for the call baring code for your network .
Dec 30, 2010 | Nokia E71 Smartphone
I havin nokia e71 and its not showing my network lines ... i cant call n incoming is not also coming...
Only thing I can think of.. is that maybe the phone is set to use UMTS only and not GSM?
Try looking under:
Menu / Tools / Settings / Phone / Network
And see if the option for Network Mode is set to GSM or UMTS or Dual Mode.
If it is set on UMTS try changing it to GSM and see if it will then connect to the network. The Dual Mode option should allow it to switch between the two automatically. I prefer setting my phone to GSM as it will help save on battery power.
Jul 05, 2010 | Nokia E71 Smartphone
How can i barred an incoming call in Nokia E71
Fortunately you CAN!
Since you have an e71, there is a program from Nokia, called Advanced Call Manager. It is enough to install it and it will give you the option to reject calls from a Blacklist. You can define this blacklist of course.
In order to find this application, go to Nokia:
http://europe.nokia.com/support/product-support/nokia-e71/software
Jun 22, 2010 | Nokia E71 Smartphone
A message saying call divert set pops up immediately after dialing a number, why is this and how do I fix it? I have an At&t LG Cf360
The Call Forwarding feature is activated. This feature allows you to direct your incoming calls to another number. Go to Menu>Settings>Call> Forwarding>All voice calls. Select Cancel/Deactivate to disable it. You have also the option to direct incoming calls if you cannot answer it, if the phone is in use, and/or if the phone is switched off or out of coverage.
Jan 24, 2010 | Nokia E71 Smartphone
How to switch nokia e71 from offline mode to online
I couldn't find the above menu items however i found an alternative: press the on/off button on your E71 and select General. The phone will then ask if you want to change from offline mode and allow network access.
Oct 08, 2009 | Nokia E71 Smartphone
No number or contact name on incoming call.
Hi, I had the same problem few days back. I am using Nokia N95 with a Vodafone service. Any call I receive simply showed "Call" and on checking the call log, says "No Number". this problem is not with the phone, but with the network. I checked with the Vodafone customer associate, I got to know I din't submit my documents to them which is required on an yearly basis and so my phone had this problem. So if u r also having same problem as I had, try contacting ur network service associates and they could help you fixing the problem.
Aug 19, 2009 | Nokia E71 Smartphone
My E71 suddenly just stopped sending SMS messages. Check with my network provider and there doesn't seem to be any problem. I can RECIEVE SMS, make calls and receive calls. But not send messages.
restart ur phone. call ur customre care of network provider and ask them for message centre number.. create a new message centre then.. ur probem will be solved. also check tht u have balance in ur phone. if still not able to solve then format ur phone..
Aug 16, 2009 | Nokia E71 Smartphone
Cannot deactivate call divert
Please punch this into your cell and dial it ##002#, this would automatically revert all the diverts.
Kind Regards
John
Jun 06, 2009 | Nokia E71 Smartphone
Nokia E71 Smartphone Logo
494 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
