SOURCE: bottom Freezer of the Amana serial number:
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
SOURCE: I have an older Amana
you have to defrost the freezer and open the back freezer wall with a thin hanger insert it in the drain hole and clean out all the dirt then pour a little water to make sure it goes down the drain, hope that helps, Joel
