Question about RCA Audio Players & Recorders
I have a HDLP50W TV(2004) and recently obtained a keyboard for the TV. I connected the cable modem to the web browser which is showing the green light at the ethernet cable. On screen message "cannot connect to server". I was reading in the manual about a router. I saw a product online called Roku which I think is a router?? It also said in manual when connecting for the first time the browser would go to a RCA web sight for set up?? Does anyone have any ideas?? I also have a dark shadow on the right side of the screen. Picture is fine through the shadow. A video tech told me the light tube has an inspection port on it for a light meter probe and the cover on that post has popped open?? I see a bright light in the middle of the screen and through the middle of the speaker grille?? It looks as if I can remove the speaker grille to investigate?? Anyone have ideas?? Thanks for your time!!
    Brigadier General:
  • 3,917 Answers
Hi ,
For a detailed set of instruction on how to connect your cable modem to Roku routers please refer to the official site:
http://soundbridge.roku.com/support/ts_uwf.php
Also you can contact their customer service if the router cannot go to the rca websight.
As far as the dark shadow is concerned , please open the back off the tv and find for a loose connection or a fried soldering.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 29, 2010
I want to install D-Link DU-562M External Modem 64 bit for windows 7. Please inform web site whwrefrom I can installed it from in my Computer.
Typically visit 192.168.0.1 or 192.168.1.1 in your web browser..
If neither page brings up anything, Press the windows key on your keyboard, hold it and press R (the win key is between ctrl and alt and has a flag on it), In the run menu, Type cmd and then click OK
it will pop up a dos style box, In that box type ipconfig /all and press enter..
The following dialogue will tell you the routers ip (assuming your connected to it and your network card is obtaining from it) The routers ip should be listed under the Gateway or DNS server.
Type that number ex: 192.168.2.1 into your web browser if the above numbers did not work.
The d-link will have a web based configuration page on it.
If it asks for a username and password the default for dlink are usually
admin
password
or
admin
1234
or
(leave username blank)
password
Aug 29, 2011 | D-Link DU-562M Modem
For diagnostic purpases I need to obtain the IP adrress of my Zoom 5241 cable modem. My Asus router IP is 192.168.1.1. I recently purchased this modem to save rental fees on the modem that Comcast...
Just use command prompt, at the 1st moment when you connect your router, no matter LAN, USB or wireless/blue tooth or even HDSPA modems connection it will assign itself a port on your machine, to check what ip adress your Zoom 5241 cable modem got, go to Start, then run then type CMD for command prompt screen and in the console, type ipconfig/all on list you will find your router, simply find "default gateway" part and use that local adress xxx.xxx.xyz.xyz.
Please rate my solution :)
Apr 13, 2011 | Computers & Internet
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have...
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Dec 29, 2010 | Belkin F5D8236-4 Router
    I changed my router wep key password code and now I cannot connect to the internet; how do I fix this problem? It does not recognize the connection now and I cannot go back in to change it back to the...
    This is how you reset your router.....
    Reset the router to factory default With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings.
    How to setup new router:
  • 1 Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • 2 Unplug your router and your cable or DSL modem.
  • 3 Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • 4 Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • 5 Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • 6 Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • 7 Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1.
  • Read more: How to Set Up a Belkin Router ' eHow.com http://www.ehow.com/how_2292408_set-up-belkin-router.html#ixzz19MK9oA2A
    Dec 27, 2010 | Belkin Computers & Internet
    Hi! im having a problem on connecting via wi-fi using this router, my iphone3gs is connecting but theres no internet connection. please help me...
    The main problem is with the Internet port connection on this router.
    Make sure that the internet port is connected to your DSL modem, or Cable modem. The 3rd light from the left on the front panel is the WAN (Internet) light. It should be solid green or blinking.
    You should also be able to connect into the router using a web browser.
    http://192.168.0.1
    enter the username and password.
    If it has never been configured before: username (admin) / password (leave it blank)
    Try running the setup wizard in the web browser.
    Dec 10, 2010 | D-Link DIR-300 Wireless Router
    From PC to Laptop
    Reboot the modem (unplug power, replug) each time you switch from one to the other. Make sure the "Local Area Connection" is enabled on the laptop and the Yellow activity light on the bottom should blink steadily.
    Mar 13, 2009 | Arris SURFboard SB5120 Modem
    Network and router issue.
    Go to the properties of each wireless network card in network connections in your control panel and click on the TCP/IP line and click properties again and ensure obtain ip address automatically is selected and click ok, restart pc. Next, reset the router at the rear if possibe with a pointed implement, then you need to get into the routers settings (192.168.2.1 in your web browser) and look for DHCP, and enable it so as to give your pc's there automatic ip addresses, also check in the general settings if it's a modem router that you have got a internet connection from your ISP and all the dns and ip addresses are showing. Restart all pc's if neccasary and refresh your web browser when trying to get online.
    Sep 07, 2007 | Belkin (F5D5231V4-SN-PD) Router...
    Wireless G Router
    you should have the cable modem connected to your routers WAN port, using the lan connector cable (RJ45 plug), then using another lan cable from the router number 1 port to your pc's network lan card, making sure the uplink button is not pressed in as this is if you wish to use more than one router on your network. Go to control panel, network connections, right click on your network card>properties, then click the TCP/IP line and again click properties, then select 'obtain ip address automatically'. go to your web browser then type in 192.168.2.1 which should take you into the router settings and look for DHCP clients and make sure DHCP is enabled and save settings. Restart the pc and it should now connect.
    Sep 01, 2007 | Belkin (F5D5231-4) Router
    Router as cable modem
    This answer is for a Dynamic and Static Cable connection (I.E. ATnT-BI, Cox, Adelphia, Rogers, Roadrunner, Charter, and Comcast). Note: Please configure the router with the computer that was last connected directly to the cable modem. Step 1: Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click on the Basic Setup tab. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Save and Restart. Step 3: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4: Follow Step 1 again and log back into the web configuration. Click the Device Status tab . If you do not already have a public IP address under the WAN Ethernet heading, click on the DHCP Release and Renew buttons. Setup Static Cable Connection Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click the Basic Setup tab. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. Note: If you do not know your settings, you must contact your ISP. Step 3: Click on Save and Restart. Step 4: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Power cycle the cable modem and router. # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes.
    Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
    Cable modem connection
    Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router. Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes. Step 3 Power cycle the cable modem and router: Turn the cable modem off (first) Turn the router off Leave them off for 2 minutes** Turn the cable modem on (first) Wait until you get a solid cable light on the cable modem Turn the router on Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address. Static Cable Connection The instructions below are for users who were given a static IP address from their ISP (Cox Business, TDS DSL, PacBell Business, Interbaun, InReach, Inficad, FlashCom, DCAnet, and Cavalier). Step 1 Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Home tab and click the WAN button. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. If you do not know your settings, you must contact your ISP. Step 3 Click on Apply and then click Continue to save the changes. Step 4 Click the Status tab and click the Device Info button. Your IP Address information will be displayed under the WAN heading.
    Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
    20 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
