Question about Maytag MAH6700AWW Neptune Front-Load Washer
Washing machine filling with water when switched off
My Indesit WIDL 126 fills with water when the machine is not even on a cycle. If I leave it for long enough it can even spill out of the doorway. I have to bail out the water periodically to stop this from happening.
An engineer came round and said it was because my drainage pipe was positioned wrongly, but the problem persists.
It drains fine after a cycle, but if I don't put a wash on for a few days, it fills up of it's own accord.
Any ideas?
  • Anonymous May 20, 2008
    washing machine fills up with water even when not in cycle but it does however work when you put on a program fills, washes and empties can you
    enlighten me thanks
    Champion:
  • 207 Answers
Electric inlet valve doesn't close properly. You should get it replaced ASAP. It is a cheap part and quite easily replaceable. Turn off water to your machine until you fix this and keep it unplugged.
Posted on Apr 24, 2008
Indesit 1200 widl 126 no lights showing when machine switched on. Checked plug fuse is good
Hi Whalley
Are all fuses ok? kindly check your outlet as your power source and measure the voltage.
Jan 19, 2014 | Car Audio & Video
I have an Indesit Washer/dryer (WIDL 126 S), and it is dot draining the water. I set in on drain or dry and nothing happens, it just fills with more water.
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump needs replaced.
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Washing Machines
I have an Indesit Widl 126 which is about 5 years old. We have just moved house and there is no hot water connection for the machine in the kitchen, there is just a cold. The machine has hot and cold...
Asuming the water is in the washer, then it sounds like the element could be faulty, to be certain, you would need to test it with a meter, and don't forget it is filling with cold water, so will take a lot longer to get hot.
Mar 03, 2010 | Washing Machines
Washingmachine error
Looks like some electric breakdown. Major repairs is requied; probably a new machine. It is now a case for the insurance company.
Sincerely Michael
Dec 03, 2009 | Indesit Washing Machines
I do i stop the indesit widl 126 mid cycle?
Open the door - or press stop/cancel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 28, 2009 | Washing Machines
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit widl 126-problem with the drum,moving back and forth to much and noisy.
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Apr 27, 2008 | Indesit Washing Machines
Indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Jan 25, 2008 | Indesit WA 115 Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
480 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
