What are the standard settings for the monitor, contrast, brightness etc
Someone adjusted the settings on my monitor now i only get a dark screen
dark screen
I have tried the arrow up button along woth function
  • 2 more comments
  • pjmbland Aug 25, 2008
    Where is the contrast and brightness button and how do you use it? My monitor is too dark.
  • tash1982 Sep 08, 2008
    I switch my brand new dell on and the screen is so dark I can barely see anything.
  • tomwoo1 Dec 25, 2008
    my hp pavilion zv6000 functions properly accept for the screen is too dark. you can bearly see. tried changing contrast settings and found no improvement
  • Anonymous Jan 19, 2009
    monitor dark could not see
My screen is to bright i need to adjust it a little
Posted on Jan 24, 2010
My sony vaio has a dark screen. I can just make out my desk top. how do I make my screen bright again?
Posted on Dec 18, 2008
    Genius:
  • 2,785 Answers
Try by using the contrast and brightness button
Posted on Apr 24, 2008
Need the operation manuel for my 22inch Gateway monitor can't change operating language
I have a smaller sized Gateway monitor than yours, but I'm sure the monitor buttons (on the front) perform the same functions on all sizes.
You should have eight control buttons on the front of the bezel (as listed from left to right): source, menu, down arrow, up arrow, left arrow, right arrow, auto/set, and on/off buttons.
Press the menu button, the first dialog screen that appears (at least on mine) is the brightness/contrast function. The screen will show the function to be changed, and a very small picture of what screen you have in view.
Once the first function is listed on the screen, press the down arrow to access the other screens (color, tracking and set-up), each having their own little picture indicating what screen you are looking at.
Brightness/contrast - picture of half light, half dark circle
color - RGB picture
tracking - two squares on top on one another slightly off center
set-up- hand pointing left
You want the set-up screen which shows a picture (I think) of a little hand pointing to the left. Once you are in the set-up screen, press the auto/set button and the first line will be highlighted (usually it is the language choice).
Once highlighted, press the right arrow button until your language name appears (i.e., English, Duetsch, Francais, Espanol Italiano, -there is no choice on mine for Japanese, etc.).
Press the menu button again and that should do it.
Feb 10, 2013 | Gateway HD2201 22" LCD Monitor
My 20 inch dell monitor is only using the left corner the screen and you can only see part of the desktop is visable and the text is upside down.
mcdevito75 here, Press the AUTO button on your monitor, if this does not work, press the MENU button, there you should see a square box with 4 arrows, these are used to center your picture on your monitor, use the left / right arrows also on your monitor to adust the screen picture with this box woth the 4 arrows from Menu.
Jul 16, 2010 | Dell ST2010 20" Monitor
I have problems viewing dark websites. My screen dim's, I can still read everything, it's just very dark. It also makes a humming noise. Is it something I can adjust. Cheers, Michelle
There is a small row of buttons on the bottom right of the front panel of the monitor. From these buttons it's possible to adjust: Gamma correction, Brightness, Color balance, H/V position, Color temperature, and Contrast. By pushing the menu button your choices should be diplayed on screen. If there is a choice of "factory default" try that and it will take all adjustments back to as they were when it was set up when new. You won't find buttons to match the adjustments I mentioned above. There may be just 3 buttons but by way of the on screen menu they are enough to acheive what you want.
From past experience I'd say it's possible someone has been playing around with the buttons and upset it's settings.
If you continue to have problems I can download the manual and guide you from there.
Apr 25, 2010 | Samsung SyncMaster 2253BW LCD Monitor
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
How do I brighten the screen. It is very dark.
Okay on you monitor there is a button there you press its labeled with a little picture of a monitor with a arrow on it or in to that regard you push that button and there should be onscreen menu you use the + and - to scroll to the correct function you want once you done that you should be able to save your settings. This is all done on the monitor!
Please do click the accept button if this helps , Thanks
Nov 05, 2009 | Acer Veriton M410-UD4000C Athlon 64 X2...
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
Laptop screen stays dark. Hve tried the function and arrow buttons but no joy
Press the FN button and hold it down and then press the brightness functions. Most people dont know that also could just be the monitor or you have it on battery saver mode which will make the screen seem dark check the batt icon that might be the problem
Jul 26, 2009 | Acer Computers & Internet
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
Acer Aspire 5630 screen brightness adjustment...
How do I adjust my brightness or contrast on my laptop? See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 5100 Notebook
Compaq Monitor Model 7600
There are usually controls, button or knobs, to "Stretch" "Move" "Pincusion" and others... have you tried this, as this is what it "Sounds" like to me from ya description? If there are NO controls on the front to accomplish this task, at the REAR of the unit there should be controls marked to show the function. Below is a link where ya will find a Manual that may help ya. http://www.retrevo.com/s/HP-7600-Monitors-review-manual/id/281ci552/t/1-2/
Aug 06, 2007 | Compaq FS7600 17" Flat Glass Monitor
Computers & Internet Logo
2,999 people viewed this question
David Payne
David Payne
