Please backup the data by logging in to Safe Mode, please restart and start pressing F8 key to select Safe Mode then re-install the Windows 7 Operating System using the Recovery Disc or recovery Partition of the Hard Drive. The Recovery Partition can be accessed by restarting the computer and try pressing F10 Key. The Windows XP Operating System is displaying an error because it does not have SATA Driver to detect the Hard Drive. As Windows 7 has it, you can re-install it from recovery partition.
A PC/laptop hangs when there is a clash of SW and HW. HW you can do nothing about and hence it is the SW or the operating system, ie, Windows that is at fault. It is just that some parts of the Windows OS hs got corrupted for some reason. Please re install Windows to get rid of the hanging problem. I am giving a link below for you to read, understand and follow if you have Windows XP. If other than Windows XP then you will have to do a fresh reinstall for which there is another link to be followed.
For Windows Xp
http://www.informationweek.com/shared/printableArticle.jhtml;jsessionid=ZC30BJMORZQH5QE1GHPSKH4ATMY32JVN?articleID=189400897
For other Windows
Saving Data After A Crashed Windows On...
If the installation hangs using the setup cd , the best thing that you can do here is to download the printer software from HP site and install it after that and that should correct the problem..
If its hanging during install you need to turn virus protection off in the bios. Have a root around in the bios and you'll see it sooner or later, If you need further help just shout.
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
I think maybe better uninstalling driver, but leave card in and boot system and let windows find the card(hardware) first instead of wot sounds like windows looking for driver and freezing in the boot up process as it will look for a connection to internet for an update or driver.
Normally any usb periferals should be connected after driver installation, but any pci or agp cards inserted first, then driver.
