Question about Toys
We have to arrange six matchsticks such that they make nothing
Firing order for rocam1.6
A six cylinder in-line engine has a power impulse every 720 degrees/6 i.e. 120 degrees of crankshaft rotation. The crankshaft has six crank-throws placed at 120 degrees out of phase with one another, which can be arranged only in three planes. Therefore, the crankpin phasing is arranged in pairs. For heavy-duty diesel engines, seven journals and bearings are provided, at each end and between adjacent crankpins. For petrol engines only 4 or 5 main journals are provided. The firing order with the crankshaft arrangement shown in the attached figure is considered. With piston 1 at the top of the compression stroke, its opposite piston 6 is at the top of its exhaust stroke. Rotation of crankshaft through 120 degrees brings pistons 2 and 5 to their TDC and either one of these can be arrangement to complete a compression stroke. If piston 5 is arranged to be at the end of compression and at the start of its power stroke, then piston 2 must be on its exhaust stroke. Rotation of crankshaft through second 120 degrees positions pistons 3 and 4 at the TDC, so either one of these can be on the compression stroke. If piston 3 is made to be on compression, piston 4 must be on its exhaust stroke. A third rotation of 120 degrees brings pistons 1 and 6 back again to TDC, where piston 6 is arranged to be on the compression and piston 1, therefore, be on its exhaust stroke. A fourth 120 degrees rotation brings pistons 2 and 5 to their TDC. Piston 2 is now on its compression and piston 5 on its exhaust stroke. Rotation of crankshaft through fifth 120 degrees brings piston 3 and 4 to TDC. Piston 4 is on compression and piston 3 on its exhaust stroke. Final rotation of 120 degrees completes the 720 degrees displacement of crankshaft and brings the pistons into positions for the next cycle. This cycle provides a firing order of 1, 5, 3, 6, 2, 4. If the phasing of paired crank-throws 3 and 4 and 2 and 5 are interchanged, then a second equally suitable firing-order of 1, 4, 2, 6, 3, 5 is achieved. This arrangement provides excellent dynamic balance and evenness of torque, and is preferred for engines larger than 2.5 liters provided length is not a prime consideration.
Sep 28, 2016 | Cars & Trucks
Matchstick problem, Azada
Make a triangle out of the boxes. One on top and two below.
Apr 05, 2014 | Big Fish Games Video Game Consoles & Games
I need help solving a matchstick puzzle. There are 9 equal squares, in a pyramid shape with 1 on top, 3 under that, and 5 under that. I'm supposed to remove 10 matchsticks and leave 4 equal squares. ...
Good Day!
here is the image where you can remain the 4 squares and removing 10 match sticks. Red sticks here are the ones to be removed.
If this helps, please give some ratings!
Thank you for asking Fixya.
Sep 16, 2011 | Puzzle Toys
In the game hidden secrets their is a segment on matchsticks puzzle you have to move 3 matches and make 4 squares you cannot go to the side or down but can go up.the puzzle looks like a grid of 9 squares...
Matchstick puzzle, 4 squares moving 3 sticks. Move the left side matchstick from the top square that is on the left side of your screen. Place it on top of the square you just took it from. Move top and side stick on the square that is on the right top of your screen. Place them on top of the top square that is on the left side of your screen. You should see 4 squares
May 05, 2011 | Computers & Internet
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Heater stopped working suddenly
In the past I have nothing but problems with DeLonghi heaters. I replaced them with Pelonis heaters and have had no problems since. Pelonis heaters are availible from Home Depot at a very reasonable price. This is based on my experience only. Hope it helps.
Ray
Dec 05, 2008 | DeLonghi Heating & Cooling
Trouble with card cover
I found the same problem posted by another member. Using a bobby pin instead of a matchstick as suggested, (only because I did not have a matchstick) I put one end of it into the hole beside the memory slot and tripped the stuck trigger. Worked perfectly. THANK YOU!
Sep 07, 2008 | Olympus SP-560 UZ Digital Camera
Toys Logo
66 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
