Question about Dell Dimension 4550 P4 Socket 478B Motherboard (2U819)
Dell 4550,wds xp home, my dvd-rom and cd-rw start to soun scratchy, now the pc doesn't show them anymore ,pc doesnt recognoise them .....weird what is the problem ? how do i fix it ?
  • 487 Answers
Hi, sounds like the drive has failed and needs replacing; sorry not good news
Posted on Jul 29, 2010
My cd drive will read cds but wont read as a burner
Not all Inspirons have CD burners (the 4 factory options were CD-ROM, CD-RW, DVD-ROM, and DVD/CD-RW. You can confirm that via Windows Start > Control Panel > System > Hardware > Device Manager and double click on DVD/CD-ROM drives to see what model drive you have, then just Google it to see what it's capable of.
In case you have either a CD-RW type drive or a DVD/ CD-RW drive and it doesn't want to burn CD's , then it's a bad drive.
Sep 08, 2011 | Dell Inspiron 1100 Notebook
When i connect my samsung CD ROM drive (CD-RW/DVD DRIVE SM-332) hard disk doesn't work and it shows an error hard disk drive Emmett failure.but when i disconnect my samsung CD ROM drive (CD-RW/DVD DRIVE...
You will have to chnage the Boot Priority
Go to BOIS setup coniguration option by hiting F2 , F12 or Del key when staring the system
Change the priority to CD ROM as first priority and insert the Windows Disk and reboot the system to Run the Win XP setup
Aug 01, 2010 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
I have a Dell Dimension C521 computer with a LG DVD drive. Trying to send a file to this drive using either a new writable cd or a cd-rw and I get a message that the cd is full and the file cannot be...
Try to check your cd-rw or cd-r that are new and did not use anymore or maybe it was damage. And maybe the files that you copied are exceed the capacity of the cd-r or cd-rw so that they could not write the files. If your using the Nero Burning ROM you just see the capacity of your cd-r or cd-rw before you going to write it to the cd. Just make sure that the files you want to copy are not exceed the capacity of the cd.
May 25, 2010 | Dell Dimension C521 PC Desktop
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Show a blue screen
    You need to go into the Setup Utility or BIOS when the computer boots. You need to enable the computer to boot from the CD drive, and set up boot priority with CD Drive first, then Hard Drive HDD.
    Then it will boot the disc.
    Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
    My cd rom in not on my computer anymore and will not read a cd how can i reinstall it
    Try to visit the dell or cd/dvd manufacturer website and download the proper driver for the model of the cd-rw/dvd-rom drive.
    Sep 26, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
    DELL laptop does not read blank DVDs
    the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
    GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
    Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
    Acer aspire l100 dvd problem
    your DVD ROM's lens has became weak.
    and it cannot be repaired.
    But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
    pls rate me
    thankyou
    Feb 14, 2009 | Acer Aspire L100 PC Desktop
    Computer can't find it
    hi ...
    try to change jumper position to slave or to master and start up you xp pro
    good luck
    Oct 22, 2007 | Samsung SW 240B CD-RW Burner
    Computers & Internet Logo
    255 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
