posted by Wychie on Apr 24, 2008
Our machine takes outgoing faxes into memory but no longer sends them automatically. They remain in the memory with no action taken.
What do you think the problem is and is there a solution??
Comment by Wychie, posted on Apr 24, 2008
Thank you for your comments and yes we can send faxes without memory use.
But because of the great number of faxes sent per day we like to use the memory which has suddenly stopped working
Still struggling
Still struggling
1 Other User Has The Same Problem
Comment by 4321fc, posted on Jun 04, 2008
massage in memory, but nothing print and can't sent fax and rec.
How to clean memory?
Best Solution
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
press the monitor button and check for a dial tone thats the first step. have you had any changes to phone system or internet recently. you could also prees the memory button and try to send a fax directly without memory use, you should hear it dial then connect and send.
Rating Locked! (?) Wychie has rated this solution as Thanks for Trying
Suggest a new solution for this problem
Post a New problem for Panasonic Panafax UF-595 Plain Paper
Email this problem
Email this problem
Can you Help with these Fax Machines problems?
Panasonic Panafax UF-595 Plain Paper Laser...
panafax uf-s10
panafax uf-s10
check pswd. 406 having trouble... Answer This...
panafax uf s1
panafax uf s1
incoming fax was asked to check... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
