Question about Handmark Software MobileLists (950142) for PC, Mac
G-FIVE X33+ MOBILE SHOWS LOW battary
My g-fivex33+ mobile showslow battary even if i load a fully charged battary
X33+low batary problem
Posted on Mar 31, 2011
Mobile phone battery goes flat after five minute call even tho it is fully charged ... what to do
Each battery type has their service / time limit . It may the time to replace your battery pack with new one. But before decide to replace the battery, make sure your charger is working properly while charging your battery.
Aug 24, 2011 | Motorola Mobility W510 Mobile Phone
Tip
IS YOUR MOBILE PHONE IS SAFE TO USE ?
Mobile have become a part in our life as mobile technology is developing day by day new mobiles are arriving in the market day by day
Have you ever checked that is it safe to use ?
Beacuse their are incidents like exploding mobile phone
mobile phone emits radiation etc
a simple mobile phone does not make such severe problems
All the problems are coming from the Battery of the mobile phone
they are responsible for emitting radiation and exploding and also over heating
and not mobile device or not the tower of service provider is emmiting radiation
If you wants to remain healthy Keep the mobile phone away from you and reduce the usage of it
when you talk or send SMS or using internet the mobile will take power from battery and
the battery produce charge with some chemical reaction
so when this chemical reaction takes place it emits radiation which cause cancer etc
Tips to make your phone safe to use
1) Dont talk or use mobile phone when the phone is charging its battery
2) Hold Your phone in hands or keep it inside bag don't put any where else
3) Only Charge your mobile when it shows " LOW BATTERY "
4) dont use mobile if any water particals get inside the phone
5) use only orginal battery
6) Dont over charge your mobile
7) Dont talk more than five mintues in your mobile phone
8) Use the mobile to talk only when the network signal is high else use sms facility to communicate
9) Change the mobile battery as soon as possible if it damaged
10) Use only original charger to charge the battery
11) when you try to remove battery make sure that the phone off
12) if the phone is not using in long time remove battery and keep it safe
13) Dispose the battery safely if its life is over
on Feb 02, 2010 | Cell Phones
My mobile always shows low battery even when fully charged.
You have a bad battery, which means you'll need to get it replaced.If it's not holding a charge that indicates dead battery.
Jan 06, 2011 | Cell Phones
Nokia 1100 shows battery low even after full
your mobile battery is dull check battery first by using another mobile
Jan 18, 2010 | Nokia 1100
NO MENU SHOWN
The only way to reset your phone is by pressing the center button key (in the middle of the navigation keys) while turning the phone on.
Dec 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Actually my mobile battery is draining very fast even i am not using my mobile just except accepting the calls on my phone Even im closing all the applications properly im fully charging my mobile it shows...
Does the phone usually gets hot before the battery runs down?
Try changing the battery, maybe the battery cell is weak.
Let me know what happens after changing the battery, so that I might direct you further.
Take care.
Nov 20, 2009 | Sony Ericsson W700i Cellular Phone
Nokia E71 power on / off issue
i think that you might have not properly charged your batterry before first use it is being noted that all mobile manufacture recommends at least 10- 15 hrs of continus charging of the battery with the phone swtiched off is needed to work effectively in the future if you do so life of the battery will incress and you can incresse the back up of the battery and it is proven also so charge the battery well and try and remeber only recharge the battery agin when a battery low signal is shown
these are some tips :
Dont talk or use mobile phone when the phone is charging its battery,
Only Charge your mobile when it shows " LOW BATTERY ",
dont use mobile if any water particals get inside the phone ,
use only orginal battery ,
Dont over charge your mobile,
Use the mobile to talk only when the network signal is high else use sms facility to communicate,
Change the mobile battery as soon as possible if it damaged,
Use only original charger to charge the battery,
when you try to remove battery make sure that the phone off,
if the phone is not using in long time remove battery and keep it safe,
Oct 20, 2009 | Nokia E71 Smartphone
Nokia 3230 Restart Problem
just format your mobile
to format your mobile fistly switch off you mobile then press
3, * , dail key and switch on key at once don't release your hand unless mobile say's formating
Nov 19, 2008 | Nokia 3230
Re: mobile
take the phone to a mobile servioce center and have them try to service the phone for you.
Apr 05, 2008 | Sony Ericsson K750i Cellular Phone
Key pad mafuntioning
Hi, there is your mobile dialing fault there may be inner keypad is demages. so if you can chang it, pl chang and check it. For ur second problem is phone not go on when fully discharges, at this time you have to put your mobile under charging for three or four hour, dont worry when u put mobile in charging mobile will not shows charging but there is a charging is on in mobile after one hour mobile will shows charging automatically. ok. test this and pl.reply earliest.
Oct 17, 2007 | Nokia N70 Cellular Phone
Handmark Software MobileLists (950142) for PC, Mac Logo
158 people viewed this question
Top Handmark Software Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Alun Cox
Tarpan Shrivastava
Tarpan Shrivastava
Are you a Handmark Software Computer and Internet Expert? Answer questions, earn points and help others
