Question about Whirlpool ACQ062XJ Air Conditioner
I have the air conditioner in full blast and it sounds like it's only in fan mode and it doesn't have the heavy sound and my room doesn't get as cold as it used to
    President:
  • 1,796 Answers
Hi!!
It seems the compressor is not kicking in, this could be due to:
Thermostat settings,
Faulty thermostat
Low on R-22 freon gas
Faulty compressor or Relay.
Faulty wiring
Don't forget to rate this post!! Good luck!!
Posted on Jul 29, 2010
Why isn't it cooling the room?
A few months ago my air conditioning unit was having cooling issues too. However, the mechanic that came and fixed it said that it was because we constantly blasted it and kept the temperature really low. How cold are you trying to keep your room? Sometimes it has to do with the system freezing up from trying to keep it too cold. Air Conditioning in Chetek WI Stellar Heating Solutions
Dec 17, 2015 | Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Is it normal for the outdoor unit on my coleman h/p to make a surging humming noise? the fan does not run during this period, approx. temp. is 28 degrees F. the fan runs 30 seconds befor the unit...
Sounds like your unit is going into defrost mode. When this happens the fan in the outdoor unit shuts off so you get more heat in the outdoor unit to defrost the coils. The heatpump is basically in A/C mode during defrost and the electric heat strips will kick in so you don't feel a cold blast of air in the house.
Jan 03, 2011 | Heating & Cooling
Ac turns on and the fan blows air but not cold air. When switching from fan to ac mode i hear a buzz sound like it had switch to ac but still its not blowing out cold air. Any suggestions?
mcdevito75, Needs service either a chrge of freon or the need for a new thermostat and That is what it sounds like to me, (the compressor could be bad also, the buzzing sound) hope not expensive repair.
Jun 23, 2010 | Amana PBC101A00A Air Conditioner
Indoor fan blowing cold air when on heating
The indoor fan will continue to run. When heat pump goes into defrost the outdoor fan stops, the reversing valve switches and the unit is basically working in the cooling mode. In order for you not to feel a blast of cold air in the winter the electric strip heat also comes on so the indoor fan must run while the strip heaters are on.
Jun 03, 2010 | Heating & Cooling
Fan Coil Unit is Cycling on and off. But the room is still hot.
Check electrical connection at the T'stat and the indoor blower . Sounds like a loose connection.
Sep 11, 2009 | Cfm Daikin R410a Split System Air...
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Amcor 12000-E air conditioner will not emit cold air. all filters are clear and hose is vented to outside. I'm about to boil
Hi, I'm new here but have the same model. Is your A/C new? Is your "Mode" set to "Cool" rather than "Fan"? Is the temperature set below room temperature? If not it will just run as fan. Lastly is your water reservoir full? Probably not the problem as the unit will shut off. Looks like you posted this a couple weeks ago, hope you figured it out.
Tim
May 07, 2009 | Amcor ALTL-12000E Portable Air Conditioner
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Jul 30, 2008 | Heating & Cooling
Whirlpool ACQ062XJ Air Conditioner Logo
53 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
