Question about Gateway FPD1975W 19" LCD Monitor
Unable to remove LCD screen from back cover to get to capacitors
My Gateway FPD1975W 19" monitor stopped working, and I just read about how to fix it by replacing the capacitors, so I thought I'd give it a try. The problem is, I am unable to reach them, as I cannot remove all the components blocking the way. So far, I have managed to remove the base, pry open the front cover, unscrew the power button from the front cover, and unscrew the LCD screen from the back cover. However, I can't completely remove the LCD screen to get to (where I'm guessing) the capacitors are because the screen is attached to part of the back cover by four little connectors with short wires (colored blue, black, pink, and orange), and a mass of tiny wires (green, white, and red) that are even shorter. I have tried removing the all of these, but I am afraid if I pull too hard, they might snap. How do I get past the LCD screen and get to the capacitors? Any help would be appreciated.
I just disassembled one of these this afternoon. They don't seem to have been built to take apart.
I removed the connectors from the display panel end.
The small connectors are designed so that you push down on the little tab while pulling to remove, but when you push the tab the connector drops below the edge of the frame which prevents it from coming out. I had to gently pry out the connectors with a small flat screwdriver from each corner of the frame.
Once you get the small connectors out you can get a better look at
the larger connector. It is glued to the frame. When you pry the glue to break it free do it so you are moving the connector to come away from the edge of the board. It will come off with the glue. On mine it peeled away a section of one side of the connector but I think will still work.
I'm not happy with the way this monitor comes apart. Even after taking this one apart I doubt I could take another one apart without the same kind of butchery.
Posted on Aug 08, 2010
  • zanonymous22 Aug 11, 2010
    Thanks very much! I appreciate the advice. I saw the tabs on the small connectors and thought they were removed much like ethernet cables were, but it they seemed to be pushed too far in to get a grip on. I will try it the way you describe.
Gateway FPD1975W Monitor Vertical lines in the right side of the screen
Open the unit back up and check the cable that goes from the control board to the LCD panel and make sure it is plugged in securely. If this cable is not connected all the way it can cause lines on the display. Also while you are inside the unit check the capacitors on the power supply board. The tops should be flat, if you have any with bulging tops then you need to replace all of the ones on the power supply board. This can also cause display issues if the power supply is not putting out the correct voltages because of bad capacitors.
Jul 17, 2012 | Gateway FPD1975W 19" LCD Monitor
My moitor fpd1975w blinks blue power button and a white screen but does not turn on ?
The blinking power light is a good indication of a failed power supply board and the white screen backs that diagnosis up. Here is a link to information show what to look for and replace on the power supply board to get the monitor back up and running again. The repair involves replacing parts called capacitors on the power supply board and can be done in less than 20 minutes once you have the parts needed.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
My gateway fpd1975w monitor will no longer turn on. The first couple of times, I unplugged the power supply to the monitor and then plugged it back in after 1-2 minutes and the monitor worked fine. Now...
The power supply may have finally died, I would inspect it for bad DC filter caps with leaking/bulging top/bottm seals first, then check for cold solder joints, burnt parts.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 11, 2010 | Gateway FPD1975W 19" LCD Monitor
The monitor (Gateway FPD1975W) turns itself off after a couple of seconds. I have tried rebooting a number of times - same problem. When I turn the monitor off and then on again it works for a second or...
This sounds like the monitors power supply is failing. (if the monitor is truly right off) Use a flashlight to verify the back-light is not just the culprit. If you can see faint image in the monitor with the flashlight, then this would point tothe LCD inverter is failing. Its most likely the power supply board within the monitor itself. Typically It takes 3 35v 470uf capacitors to fix and a little patience to get apart. Do a bit of googling on "replacing the caps in a FPD1975W" and youll see what i mean. Cheers.
Sep 01, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor comes on with a good picture but after about 15 seconds the screen goes blank.
Most probably a failing capacitor, if you can, unplug it, leave it for 12 hours or so and remove the back cover carefully and check for bulging or blowing capacitors.
Feb 09, 2010 | Gateway FPD1975W 19" LCD Monitor
My gateway FPD1975W 19 INCH LCD MONITOR DOEN'T TURN ON, THE SCREEN IS BLACK
First place to check will be the power supply, look for bad caps with bulging tops or bottom seall first and report back what you find then we can guide you futher, see what bad caps look like here:
Jan 27, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
Power supply for Gateway FPD1975W 19 inch LCD
try replacing the crystal on the power supply 8 out of 10 times it is the problem
Apr 02, 2008 | Gateway FPD1975W 19" LCD Monitor
The FPD1975w
Replacing the lcd screen more than likely. Problem in the PCB thats built onto the lcd itself.
They are rather inexpensive these days to replace. I would just buy a new one. Check warranties offered before buying, some manufacturers offer 3 years. ;)
Oct 24, 2007 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
325 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
