Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I purchased a side by side SBDT520 in Australia in December 1991. I love this fridge other than it has become much noisier over time. I am guessing this is the compressor. Amana is no longer available in Australia and other models do not measure up in quality - any help?
  • Amana Master
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly. Noise as a Fridge gets older.... 12 years and up are not uncommon. Actually there are little things that cause them to start making noise. The rubber grommets on the compressor are torqued each time the compressor starts and stops so the eventually wear out. They are a cheap repair and if you have even the slightest bit of mechanical ability you can change them yourself. The noise you are hearing is most likely vibration of the compressor against the naked mounting stem because the 3 or 4 isolation grommets are worn out. Also things like the condensor fan and evaporator fan bearings also are worn over that same period. You can get generic fan motors for each application and have them replaced if you suspect either fan. If your electric bill is not climbing little by little each month the compressor itself is probably just fine. If you want to keep your refrigerator and your not capable of "doing it yourself" then by all means have a service person evaluate your machine. Trust me the service call is cheaper than a NEW fridge. I would ask what it would cost to "slience the unit?" My best guess from here is including the service call while replacing both fans, the rubber compressor isolation mount grommets, and cleaning the unit is right around $200.00 USD.
Also in the freezer section there are at lease 2 peices of Styrofoam or in som cases foam rubber that isloate the evaporator coils from the cabinet these too over long periods experience wear just from cooling and thawing (expansion and contraction) via normal use. The service person can replace the foam rubber or install foam rubber where the styrofoam has worn.
Another thing that can cause noise is lint build up in the condenser cooling fins that eventually block the condensor fan air flow or impede fan blade movement. If the uint has been around since Dec 91 then I am certain you have done some basic condenser coil cleaning over the years. If not it sure is time to do so.
Thanks for choosing FixYa.
Kelly
Posted on Jul 29, 2010
    President:
  • 1,796 Answers
Hi!!
The noise may be due to extermal factors, like condenser fan or compressor fastenerrs coming loose. Make sure the compressor and fan/condenser housing on the bottorm back side of the unit is clean and thight. If the unit is working fine. maybe all it needs is a little maintenance.
Don't forget to rate this post! Good Luck!!
Why does belt keep coming off when spinning?
Sadly, this is almost certainly drum bearings worn out and the drum spins off centre, causing the belt to come adrift (I'm guessing your spin cycle has become significantly noisier recently). Worse news I'm afraid, the IWC6125 uses a sealed, non serviceable drum, so this is really an uneconomical repair that will cost around 60%-75% of the cost of the machine when new
Sep 06, 2015 | Indesit IWC6125 Front Load Washing Machine
Just purchased this fridge and the motor appears to be running quite often and loud. Think it is noisier than it should be for a new fridge - is this normal or is there a problem. Had a Kitchen aid...
Normally all what is heard is HUM which needs one to listen. Hiowever is you experience a high noise then being a priviledge customer you need to get a consensus to your viewpoint as the fridge is covered with warranty.
Please check for SYMPATHETIC vibrations on the rear panel due to loose fitting which can happen with transportation.
Your observation is most important.
Thank you for using fixya.
Sep 02, 2011 | Fisher and Paykel Active Smart® E522BR...
I just purchased a new Frididaire side by side. I've had it 4 days. It runs about 13 minutes and is off about 11 minutes. Is this normal? Seems like it shouldn't run so much.
For a new fridge, need more time to maintain the required temperature of the fridge and mainly the goods in it? So everything seems normal. The time will be reduced day by day since the goods will stay for longer time in and door opening will become less and less.
So don't worry everything seems fine.
Oct 16, 2010 | Frigidaire Refrigerators
I have nokia 5800 mobile phone i bought it in december 2009 but on 19 th august in rain fall water enter in my mobile phone. i continue using my phone the battery become very heat and now phone is dead the...
> the phone cannot be repaired for the water damage voids your warranty.
Try this:
Soak your phone in Rice for about 24 hours
rice acts like a sponge that drains the moist inside the phone.
and then if the battery is heating I guess.. moist is still inside of it..
For better battery performance purchase a new battery.
Sep 01, 2010 | Nokia 5800 XpressMusic Smartphone
GE side by side (purchased 2005; don't know exact model)
Defrost timer issue is my guess. It is generally located behind the rear inside panel in the fridge section. I'm guessing about $150-200 or so to fix it.
Jul 24, 2008 | GE Profile PFS22 33" Artica French Door...
Amana Spare Parts
not sure if this will help as they dont have any parts imaging but check here hope this helps..
Dec 18, 2007 | Amana SXD524VW Side by Side Refrigerator
Pink circles and glares with sunset photos
It may have to do with the black ring. (think football players). I'm guessing either that or the more sensitive, noisier CCD is to blame!!! Good Luck!!!
Jul 26, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
137 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
