Question about ASUS Eee PC 1000H Laptop
Sir pls advise how do i use the key board for the various functions i bought a german version the key boards are a little different expecially wld like to know the usage of all symbols above the figures n etc pls advise my id is swami952@gmail.com also the touch pad does not seem to be working pls advise
    Guru:
  • 689 Answers
What type of key board do you want son?
you are given the choice when you configure the computer
Re-install OS if you need to,they keyboard configuring is a basic function of most pc's
Posted on Sep 04, 2010
Samsung LN46C610N1FXZA SOUND fine no picture.no backlight. flashlight test shows video is fine. voltage test on power board is double on all voltage points,
Sorry to hear that, it seems video processor chip failure on main board and entire main board swapping is needed, please note that there are various different version of main board utilized in this one mode so it is very important to get identical main board as replacement that has same part number.
Jan 07, 2018 | Samsung Televison & Video
Sir. i have symantec mother board, i installed window 7 but audio not supported pl. advise me for n/a
Symantec is antivirus and mother board name will be different which mentioned audio problem is different check wether the driver is properly installed.
Jun 09, 2014 | Symantec Norton Antivirus 2009 1-User -...
Who sells the main board for this T.V.
When something goes wrong with a television set, chances are that a TV circuit boards is to blame. A television functions via a number of circuit boards, which serve different purposes to bring images and sound to a TV. Problems with circuit boards can often be solved by simply replacing the board. This is generally much more cost effective than buying a new TV. There exist several companies which provide the various boards for the various televisions and other related models as well. One may go to any professional related to the TV model and also Google the same for the utmost alternative for the same.
https://www.structuredsettlement-quotes.com/
Sep 08, 2013 | Olevia LT37HVS 37 in. LCD HDTV
Seiko lp1020 led head
Sir..,Not help for local dealears.,
So. pls ur help sir.,
SEIKO LP-1020 Model Machines
MEP Board (PCP) AFXY U00077354803 (Board arjent)
Account No pls send sr.,
waht price sr.,
Pls help sr.,
Aug 08, 2012 | Seiko Teriostar Lp1020 Printer / Copier /...
My LG key board which is only a little over 2 years old has packed up. It shows the part number as R405.Can I buy a new key board for this LG model.Please advise.
why you want the old model now latest and best keyboard from different maker available i suggest logitech brand which may you see at "http://www.logitech.com/en-in/keyboards/keyboards"
you must vote for my suggestion
Aug 23, 2010 | LG Office Equipment & Supplies
Vlc prayer not working
The issue is not clear!! pls be more specific
Aug 17, 2009 | Dell Vostro 1510 Motherboard System Board...
Wii Balance Board thinks I'm on it all the time!
Make sure of a couple of things and try again -
If you are on semi-shag carpet, try using the little foot extenders. They may not seem like much but they can help.
If you are on moderate to thick carpet, you may need a board to set the Wii Fit Balance Board on.
If you are on a wood floor, you can (but don't have to) remove the little foot extenders.
Another little gremlin can be in those silicone covers. If you have one, I'll bet that's the culprit. As nice as they are to keep the board clean, they can actually attach to the non-moving part of the scale (the bottom) to the moving (surface) part. Be sure that your silicone cover is not interfering with the normal movement of the board.
Finally, be sure that you are always using YOUR setting while exercising or it will not be calibrated correctly. Also be sure that when you start, you are not on the board when it calibrates for the first time after turning it on. If the weight on the board differs by about 5 lbs or more than what it thinks you weigh, it will pitch a little wii fit.
I hope you find this advise helpful. If not, though, please don't label this advise as "inappropriate". A "Thanks for Trying" would be just fine.
Thanks for using Fixya.
Mar 23, 2009 | Nintendo Wii Fit for Wii
Version number?
Bios 7N is for the following
  1. Support up to 137GB HDD and above.
  2. HPT 370 RAID BIOS version 1.11.0402. The RAID function is for KT7-RAID / KT7A-RAID only. This BIOS version is also for non RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
Version A9 is the last update
  1. Fix nVidia GeForce4 Ti 4x00 AGP card compatible issue with Windows XP.
  2. HPT 37x BIOS version 1.11.0402.The RAID function is for KT7A-RAID only. This BIOS version is also for non-RAID boards and HPT BIOS will be automatically disabled while RAID controller chip not detected.
  3. BIOS Compile Date: 7/11/2002.
LINK
The above link is for the KT7a with Raid, however the standard KT7a also lists the same bios updates, the KT7a Raid ver1 lists different bios that won't be compatible with your board.
Apr 12, 2008 | Abit KT7A Motherboard
Synch problem with Dell 2005FPW Monitor
Hi...there,
The only place to get replacement parts are for the Dell. Call them up and order the part. The part you will need not the video AD board. What you need it a backlight inverter / power supply. The one you had are busted... or you can repaired yourself...by replaced a few busted capacitors. If you are lucky you can spotted by a bulging on the top of each caps... Not sure, just replaced all the caps... Good lucks!
Nov 23, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
ASUS Eee PC 1000H Laptop Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
