Width problem i have microtek 14" monitor 1470uf which have width problem unable to expand & less by the switch while i have changed all parts of of horizotal section
  • 36 Answers
Your monitor comes with an internal program that will adjust the monitor. You might just need to update your video drivers, but if all else fails, just get it repaired by the manufacturer.
Posted on Apr 24, 2008
I am not able to expand the screen
Did you try to adjust with front pannel switch?
If the switch not working then change the micro switches.
Check the width boost capacitor (Polyster cap. 1.5Kv / 1.8kv / 2kv etc) in Horz. section
Check the SMPS voltage for Horz.
May 02, 2011 | LG Flatron F700P 17" CRT Monitor
Sometime red colour is missing in my monitor philips 106E6 15 in. another is horizontal is less than screen it does not incres.
most probable chance is the difective VGA cable for color problem..
if required change the cable
The control pannel switches may be difective, change the switch and try to adjust the width.
Apr 16, 2011 | Computers & Internet
Although display for width is visible 0 - 100 % but actual width is not changing
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
don
Feb 28, 2011 | Computers & Internet
Microtek flatvision display horizontal continuous moving.
that is problem of diode near EHT that diode connected to big heat sink having three leads two series diodes in one diode replace it even meter shows ok .If persists then check mosfet irf 630 and path of its gate touch heat sink if it overheats then yoke is faulty replace it
Mar 17, 2010 | LG 500LC Monitor
Microtek c593 monitors. Out of Range
Your Minotor not support windows 7 frequincy or resulation.please open your computer safe mode, and set monitor frequincy only 60Hz. Resulation less area .Then solve your problem.
Dec 27, 2009 | Microtek C593 15" Flat Panel LCD Monitor
Monitor screen is vibrat left-right & up-down side
just go to the menu of your monitor then try to reset the setting so it will set the factory default value
hope this will help u
May 29, 2009 | Computers & Internet
C593 Microtek
If it has speakers it wil have a female jack for you to connect the sound from your computer audio out(usually the green jack) to the monitor. It if does not have sound you can buty extenal speakers most places limke wal and k marts
Jan 13, 2009 | Microtek C593 15" Flat Panel LCD Monitor
Less H-width for higher resolutions
this is not the electronic problem, this monitor is made to support such (800x600) resolution.
Dec 17, 2008 | Compaq 7500 17" CRT Monitor
MICROTEK 19 "C783
19" LCD comes on and goes out right away
Sep 06, 2008 | HP vs19 (Silver) 19" LCD Monitor
Color of monitor
change the moniter is the best solution, coz repair could be cost more than its worth
Jul 21, 2008 | HP CD-Writer Plus 7570i (C4411A#ABA) CD-RW...
Computers & Internet Logo
413 people viewed this question
David Payne
David Payne
