My monitor flashes on and off and my programs are sticky could it be the monitor drive or what????
I did not understand what u meant by "my programs are sticky".
The monitor flashes could be because the display cable which is connected to the CPU is damaged or loose.
Posted on Jul 29, 2010
What do the buttons on the bpr 40 do?
Both buttons have a short and a long press function. The button right below the PTT button is typically programmed to short press Monitor, long press Sticky Monitor. The bottom button comes from the factory on scan/nuisance channel delete. The buttons can be custom programmed when the dealer is programming the radio, so these are just a general guess based on the factory default setting. Other options include repeater talkaround, high/low power, volume set, and maybe tight loose squelch.
Best regards.
Oct 07, 2012 | Motorola Mag One BPR40 Two Way Radio
My bpr 40 all time have a green light on in a scan mode how i can block the scan mode
In order for your radio to scan, it would need one of the side buttons programmed to scan. Usually the top side button is programmed for monitor/sticky monitor, and the bottom button can be programmed to any of a number of features, one of them being scan. These buttons have both a long press selection and a short press selection. All this being said, it is possible the bottom button is programmed for scan. Try pressing it a short press and/or a long press and see if it shuts off your scan. To remove scan completely from your radio it would need ot be reprogrammed by an authorized Motorola dealer.
Best regards.
Jun 17, 2012 | Motorola Mag One BPR40 Two Way Radio
What do I use to remove sticky adhesive from my plastic hp monitor?
You can use a thinner to remove it. Put some thinner on a piece of cloth and rub the place which has sticky adhesive. Rub it hard!
Good Luck!
Aug 27, 2010 | HP w2558hc 25.5" Widescreen LCD Monitor
How to set the time on my GE 27958GE1 Cordless Phone
1) press FLASH/PROGRAM until SET DAY shows
2) use MESSAGES/CID or the arrow buttons to select current day
3) press FLASH/PROGRAM until set time shows
4) use touch-tone pad to enter 1st, 2nd, 3rd, & 4th digits
5) use MESSAGES/CID or the arrow buttons to scroll to AM or PM
6) press FLASH/PROGRAM again to store your selection
7) press FLASH/PROGRAMrepeated to exit
I copied this from my manual onto a sticky label & have it stuck on the bottom of my phone for future reference.
May 21, 2010 | GE 27958GE1 Cordless Phone
Cd drive won't open and cds are very sticky
Yes without doubt. If alcohol hasnt fixed it try a little liquid detergent. otherwise you may want to copy the CD's onto new disks and keep the problem ones as backups
Aug 01, 2009 | Electronics - Others
Radius CP200 is in monitor mode I think and i can't get it out of that mode by pushing the programable buttons
Your programmable buttons can be programmed to a number of options. Typically the first button is programmed to monitor and sticky monitor. If this button has been held in a long press you can clear the setting by holding it in another long press to shut it off, or by simply shutting the radio off and turning it back on.
Your second programmable button could be set for an number of features, but like the above description, simply pressing it again or shutting off the radio will turn the feature off.
When you refer to Monitor Mode, we assume your are indicating the radio is operating open squelch, with no private line code. This is when you can hear ALL transmissions on your frequency. If this does not describe the problem you are having please repost another question.
Jul 16, 2009 | Motorola Radio Communications
OSD Main Menu appears randomly and uncontrollably /flashing. Power Button does not always work. Need to keep clicking unti works.
hello..the problem is just sticky tack switch's so try to clean or re-align the frame/body of LCD..Thanks.Good Luck..^_^
May 08, 2009 | Dell E207WFP LCD Monitor
HP Pavilion 17" screen flashes on and off
Try reinstalling your monitor. You should have a disc that came with all of your equipment.Make sure it is a clean install and there are no other programs running. Also check all connections to make sure they are tight.
If this does not help, do you have another monitor you can install temporarily so that you can work on this problem?
Is this a new monitor installation? You might want to check your hardware compatibility list which you will find under Start>Programs>accessories>compatibility wizard.
Aug 21, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor Problem VS. Windows XP Problem
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Mag Innovision LT776s 17" LCD Monitor
Compaq Presario 5000 shuts down after a few minutes
ITS PROBLEM WITH SPYWARE IF U UNINSTALL SPYWARE SOME PART OF THE SPYWARE WILL NOT GET UNINSTALLED TRY TO FORMAT THE DRIVE AND RELOAD THE OS IT MIGHT SOLVE THE PROBLEM I HAD SAME PROBLEM WITH ONE MY CLIENTS COMPUTER I FORMATED THE DRIVE AND INSTALLED THE OS NOW THE COMPOUTER IS WORKING FINE
Dec 03, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
