Question about Microsoft Windows XP Professional
When i was instaliing the microsoft word 2007 in my pc there is a problem. the problem is the specified program requires a new version of window. how can i install that?
    Brigadier General:
  • 4,090 Answers
This is possibly asking for WINDOWS Installer Go to microsoft downloads and get it
Please rate my help++++Thanks for using FIXYA
Posted on Jul 29, 2010
Need to fix office 2007 from compatability
Windows 7 Office 2007 Minimum Requirements b> Microsoft Office 2007 isn't the latest version of the Office suite, but it is still useful for a variety of tasks. The software package includes programs for editing spreadsheets, working with documents, creating presentations and more. Office 2007 also includes a redesigned user interface that is more intuitive than previous versions. Chances are good your computer can run Office 2007 if you already have Windows 7 installed, but you should check the system requirements anyway to ensure a trouble-free installation.
Processor and Memory Your computer needs a 500MHz or faster processor plus at the very least 256MB RAM. You may need more memory if you wish to run multiple Office applications simultaneously. The Business Contact Manager in some versions of Office requires a 1GHz processor and 512MB RAM. Turning on the grammar checker in Word requires 1 GB of RAM. Hard Drive and Optical Drive b> Make sure you have at least 1.5GB of available space on your hard disk to install Office 2007 standard and 2GB for other versions. You also need a CD-ROM or DVD-ROM drive for installation. Monitor b> Your display should have a 1024x768 resolution or higher. Older 800x600-resolution monitors are not compatible with Office 2007. 64-bit Compatibility and Windows Updates b> Note that you may run the 32-bit version of Office 2007 on 64-bit versions of Windows 7, but you cannot run Office 2007 64-bit on 32-bit editions of Windows 7. Make sure your copy of Windows 7 is up-to-date for best results. Microsoft releases fixes and other updates periodically that address stability issues and other known bugs. You can use Windows Update, on your "Start" menu, to check for updates.
Compatibility center http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=Microsoft%20Office%202007%20Professional%20Plus&v=Microsoft&uid=12&pf=0&pi=0&s=office&os=32-bit b> 2007 Microsoft Office System Requirements http://www.microsoft.com/officebusiness/products/technical-requirements.aspx
Feb 26, 2013 | Microsoft Office Professional 2007 Full...
My micro soft office home 2007 whats me to enter a product key I lost mine . i had it for 2 yrs only
Hi try this.
Converting Microsoft Office 2007 to Full Version:
This requires that Microsoft Office 2007 has been installed without the product key in the first place.
Once Microsoft Office 2007 has been installed with no product key, proceed as follows:
1. In Windows Explorer of your pc, browse to the following folder:
C:Program FilesCommon FilesMicrosoft SharedOFFICE12Office Setup ControllerProof.en
2. Right click on Proof.XML file, select Open With in the right click menu.
3. In the Open With window, select Notepad to be used to open the XML file.
[Note: In Windows Vista, if you can't see the Notepad option, simply double click the "Other Programs" to unhide it.]
4. Scroll down to the bottom of the Proof.XML to locate the following lines:
<feature Id=SetupXmlFiles Cost=1248><optionref Id=AlwaysInstalled/></feature>
5. Change the AlwaysInstalled to NeverInstalled so that the line looks like following:
<optionref Id=NeverInstalled/>
6. Save the Proof.xml file.
[In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
7. You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation.
Oct 11, 2012 | Microsoft Office Professional 2007 Full...
Error 25004.config.xml not specified; A valid config.xml file must be authored when deploying '(null)'. i am installing microsoft office enterprise 2007 and i enounter this problem..how will i
If the version of windows installed on your computer is not activated you would face issues to use any applications once the product is expired.
But if you have an issue with office programs with an error 25004 on an activated version of windows
Then the reason might be corrupted installation of office 2007 on the computer.
Uninstall office 2007 manually from the computer then
re-install it and check if it helps.
Apr 25, 2012 | Microsoft Office Professional 2007 Full...
My excel files are corupted it opens in run position and not in the save file position what can be done to undo this?
Lets resolve the condition according to step by step processes.
1. New computers are acquired with a trial version on the microsoft office productivity program package. once acquired, a new retail version of office productivity softwares is required for resource processing. For example, the prior trial version of the software would have functioned momentarily until the expiration causing least displays. Available solution is acquiring from retailers the most up to date office productive software to produce results. \
2. office productivity softwares are avialable in various formats, microsoft office, microsoft development, micorsoft productive bundle all similar in functionality however not possible to intercommunicate. For example, a computer that has microsoft office software documents may least interprete resources mailed from another computer with microsoft windows lotus a similar productive resource.
How to solve the condition
1. ascertain that new computers require new bundle softwares to provide resourcefully. visiting a computer devices retailer should provide the complimentary programs.
2. computers that already have documents however have encountered malfunctions would require examination to ascetain what was the prior version before visiting the retailers to acquire compliments. The aim is to acquire what the computer in question most desires. For example, newer version computers can function with all available programs on the market. However older computer may have required compartibility checks to capture satisfactory functionality.
Jul 20, 2011 | Microsoft Office Excel 2007 Full Version...
I want to update microsoft office 2003 to microsoft office xp 2007 professional edition full & final version
You can download the full version of microsoft office professional full version with keys via torrents.just add torrent downloads to the software name and search in google.
May 10, 2011 | Microsoft Office Professional 2007 Full...
I'm taking a college computer class on Windows Office 2007 & now entering into the section on Microsoft Office Access 2007, BUT I can not find it on my computer under the Microsoft Office Home &...
Unfortunately, the Home and student version of MS Office both 2007 and 2010 do not contain Access.
I looked a at new box on amazon to confirm..
http://www.amazon.com/Microsoft-Office-Home-Student-2007/dp/B000HCZ8EO
You might be able to send me a e-mail to resolve this problem.
Sep 27, 2010 | Microsoft Office Professional 2007 Full...
I tried to install office 2007 on windows 2000 professional with service pack 4. Following error was prompted. "THE SPECIFIED PROGRAM REQUIRES A NEWER VERSION OF WINDOW"
The message is clear: Microsoft Office 2007 cannot refuses to install on Windows 2000 Pro. You need a newer version of Windows (Windows XP or newer) to have MS Office 2007 work properly.
Alternatively you can install Office 97 on Windows 2000 Pro.
Aug 13, 2010 | Microsoft Office Professional 2007 Full...
When i click autorun i get "windows cannot access the specified device, path, or file. You may not have the appropriate permission to access the item
probably you had a trial version which expired already and some features of the program aren-t available anymore ...reinstall the program ..or better look for a 2003 version cause in my opinion has all it needs to be a great program and I always found it enough for my needs...
Sep 26, 2009 | Microsoft Office Professional 2007 Full...
I have word2000 and i want to open a word 2oo7 document how can i
Download this tools for Microsoft:
http://www.microsoft.com/downloads/details.aspx?familyid=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
Please note that:
Overview Users of the Microsoft Office XP and 2003 programs Word, Excel, or PowerPoint—please install all High-Priority updates from Microsoft Update before downloading the Compatibility Pack.
By installing the Compatibility Pack in addition to Microsoft Office2000, Office XP, or Office 2003, you will be able to open, edit, andsave files using the file formats new to Word, Excel, and PowerPoint 2007.The Compatibility Pack can also be used in conjunction with theMicrosoft Office Word Viewer 2003, Excel Viewer 2003, and PowerPointViewer 2003 to view files saved in these new formats. For moreinformation about the Compatibility Pack, see Knowledge Base article 924074.
Note: If you use Microsoft Word 2000 or Microsoft Word 2002 to read or write documents containing complex scripts, please see http://support.microsoft.com/kb/925451 for information to enable Word 2007 documents to be displayed correctly in your version of Word.
Administrators: The administrative template for the Word, Excel, and PowerPoint converters contained within the Compatibility Pack is available for download.
Update: The Microsoft Office Compatibility Pack Service Pack 1 (SP1) is available here.
arrow_px_up.gif Top of page
System Requirements
  • Supported Operating Systems: Windows 2000 Service Pack 4; Windows Server 2003; Windows Vista; Windows XP Service Pack 1; Windows XP Service Pack 2
  • Recommended Microsoft Office programs:
    • Microsoft Word 2000 with Service Pack 3, Microsoft Excel 2000with Service Pack 3, and Microsoft PowerPoint 2000 with Service Pack 3
    • Microsoft Word 2002 with Service Pack 3, Microsoft Excel 2002 withService Pack 3, and Microsoft PowerPoint 2002 with Service Pack 3
    • Microsoft Office Word 2003 with at least Service Pack 1, MicrosoftOffice Excel 2003 with at least Service Pack 1, and Microsoft OfficePowerPoint 2003 with at least Service Pack 1
    • Microsoft Office Word Viewer 2003
    • Microsoft Office Excel Viewer 2003
    • Microsoft Office PowerPoint Viewer 2003
InstructionsTo install this download:
  1. Ensure your system is up to date by installing all High-Priority/Required updates on Microsoft Update (required for Microsoft Office XP and 2003 users).
  2. After installing all High-Priority/Required updates with Microsoft Update, download the Compatibility Pack by clicking the Download button above and saving the file to your hard disk.
  3. Double-click the FileFormatConverters.exe program file on your hard disk to start the setup program.
  4. Follow the instructions on the screen to complete the installation.
To remove this download:
  1. On the Windows Start menu, click Control Panel.
  2. Select Add/Remove Programs.
  3. In the list of currently installed programs, select Compatibility Pack for the 2007 Office system and then click Remove or Add/Remove. If a dialog box appears, follow the instructions to remove the program.
  4. Click Yes or OK to confirm that you want to remove the program.
P.S.: If this information was helpful, please rate this solution.
Mar 23, 2009 | Microsoft Office Professional 2007 Full...
Microsoft Windows XP Professional Logo
19 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
