Question about Jenn-Air JCB2280HES Side by Side Refrigerator
I have a Jenn-Aire side-by-side refrigerator Model #JCB2280HES, Serial #10024253EP. The warranty expired in February 2010. The food in the bottom half of both the freezer and refrigerator is frozen and the food in the top half of both parts of the side-by-side is neither frozen (in the freezer part) nor cold (in the refrigerator part). I removed the faceplate below both doors and vacuumed and dusted the coils. It made no difference.
    President:
  • 1,796 Answers
Hi!!
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Good Luck!!
Posted on Jul 29, 2010
IMO, Rene's answer is the most likely cause of this problem. I posted a few tips for DIY'ers under "Jenn-air side-by-side: freezer & frig cold on the bottom not top!" thread.
Posted on May 02, 2012
I have an older Jenn-Air fridge model # (P) JCB2280HES. We recently moved and now it is warm. not cool at all
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Jun 24, 2011 | Jenn-Air JCB2280HES Side by Side...
Water leaking from bottom of freezer side
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Jenn-Air JCB2280HES Side by Side...
The refrigerator just stopped working,the interior lights still o
http://www.repairclinic.com/Appliance-Parts?s=t-JCB2280HES-%3d%3dc212
this is the problem because it control the compressor and fans
but to be sure and on the safe side if the thermosat is bad it wont work either. there are two wires that go to the t'stat (http://www.repairclinic.com/Appliance-Parts?s=t-JCB2280HES-%3d%3dc214temperature control) jump them or put them together if it goes on replace if it doesnt go on replace the timer control board (the first link i gave you)
Mar 27, 2010 | Jenn-Air JCB2280HES Side by Side...
My Jenn-air refrigerator is freezing up everything
You can set the temperature to a lower position. Sounds like the thermostat is broken.
Oct 30, 2009 | Jenn-Air JCB2280HES Side by Side...
How do I remove the ice maker from Jenn Air ref
The ice maker hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it.
Jul 01, 2009 | Jenn-Air JCB2280HES Side by Side...
Side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
Jun 17, 2009 | Jenn-Air JCB2280HES Side by Side...
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Feb 02, 2009 | Jenn-Air JCB2280HES Side by Side...
Jenn-Aire Refrigerator Shutting Down
sounds as if the control board has gone bad unless you have an extended warranty that you purchased extra this will probably not be covered, but check with jenn-aire to be sure. I dont think I would worry about a 3rd compressor being bad but I would unplug the unit to prevent any further damage to it. good luck peyton
Jan 30, 2009 | Jenn-Air JCD2295KE Side by Side...
Jenn-Air side by side won't give water
hi thanks for the question yes the small tube that enters the ice maker can freeze up stopping the water flow check this thanks the appliance doc
Sep 16, 2008 | Jenn-Air JCB2280HES Side by Side...
Jenn-Air JCB2280HES Side by Side Refrigerator Logo
188 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
