Question about Mastercool 67680 Evaporative Cooler Air Conditioner
How to remove old ac pads from master cool II MC63c
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Evaporator cooler (Master Cool) one of
Hi and welcome to FixYa. I am Kelly.
First off... some thing has cause the vibration to damage the spider brackets to begin with. Could have been an imbalance of dirt build up on the squirrel cage blower, corrosion.. or a bad bearing.
There are few ways to fix this but all require the unit blower assembly to be removed and your still going to have to balance the fan before re-installing the blower.
Here is the parts list:
http://www.searspartsdirect.com/partsdirect/part-model/Adobeair-Parts/Evaporative-cooler-Parts/Model-MC63C/1568/0908000/P9070179/00001
Ths spider is not listed as a replaceable part.
You can have the brackets repaired at a weld shop however... welds have a tendancy to make the parent metal hard and if there is any hint of a vibration post repair the problem will only repeat.
I have never had much luck with a unit that got out of balance and caused support bracket failure.
They always result in call backs. The best remedy is to replace the blower. Good luck finding one as most parts for this unit have been discontinued. I am sure there are heating and airconditioning places that have a viable replacement blower that will most likely be a used one.
The blower wheel is roughly $93.00.
I am just passing on my 40 years experience dealing with swamp cooler issues. Having it welded may get you 2 or 3 more seasons at best but you must deal with the balance problem.
Thanks for choosing FixYa,
Kelly
Posted on May 27, 2011
SOURCE: how to remove algae from master cool pad
It seems like your pad needs replacing if you have a build up of algae
There is no way to wash out the pad properly without destroying it
You have to be careful with cleaners as you will be breathing the residue later
Posted on Jun 13, 2011
How do you replace rear pads 2005 dyna glide
Hi Anonymous, it can be done with out removing the rear wheel or any brake lines, or any bleeding of brakes, all you need is a c-clamp and regular hand tools. First place a drain pan underneath the rear master cylinder, it's likely to overflow during the piston push back procedure, and remove the top and accordion rubber gasket and compress gasket back to it's flatest position then put it back on top of the master cylinder leaving the metal cover off. Next split the caliper halves by removing the 3 bolts and pay close attention to small o-ring so it doesn't get lost and location and orientation of the anti rattle clips. Leave the old brake pads in.Take your c-clamp and position it so that the screw part is dead center of the old pad and slowly tighten the clamp until the old pads have pushed the pistons back into the caliper half and the pad bottoms out. Repeat the process with the other caliper half. Install the new brake pads, replace o-ring and anti rattle clips and bolt the halves back toghther, torque bolts to 20 ft lbs. Check fluid level and replace top cover on master cylinder. Pump the brake by hand until you get a nice strong pedal and your good to go. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 22, 2014 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
My double Cooler Master Cooling Fan R4-S4S-10AK-GP that i use underneath my laptop stopped working even though its not been in use for long time i bought it as part of a cooling pad with removable cooling...
If the fan spins and you find there is power going to it, then likely the electronic drive circuit has failed. You can get replacement fans at stores like Fry's and other sources.
Aug 03, 2011 | Cooler Master R4 Series Silent 140mm Case...
How to remove algae from master cool pad
Jun 10, 2011 | Mastercool 67680 Evaporative Cooler Air...
Need help in replacing front and rear brakes on a 2003 mitsubishi montero full size
The pads are easy to change. You do not need any special tools. If there are no grooves in the rotors I would just put on new pads. Don't get cheap pads or they will squeek. I would strongly suggest that you flush out the old brake fluid. You will be amazed at how brown and gunky the old fluid is. Flushing the fluid regularly will help make your calipers and master cylinder last a long time. I like to use Valvoline Synpower brake fluid, it is a couple bucks more but it is DOT 4.
One last tip. When compressing the brake caliper piston you do not want to push the fluid back up to the system, because you might get some crud into the ABS module. Therefore, when compressing the piston, loosen the bleed screw to let the fluid flow out of the bleed screw.
This is how to get it done:
  • Remove the old fluid from the master cylinder resevior with a turkey baster. Top up master cylinder with fluid.
  • Remove the right rear wheel and bleed/flush the brakes with the old pads on. Top up master cylinder with fluid(important). Remove the caliper, open the bleed screw and compress the piston, close the bleed screw.
  • Install new pad and caliper
  • Bleed again. Top up master cylinder with fluid.
  • Repeat on remaining 4 wheels RR, LR, RF, LF.
Glad to be of help!!!
Jan 21, 2011 | 2003 Mitsubishi Montero Sport
How to remove rear brake caliper to replace pads on 1995 Celica
With the wheel removed, look behind the caliper there are 2 bolts that hold the caliper in place. Completely remove the lower bolt and loosen the top. The caliper will then swing upwards exposing the old pads. Remove cover off master cylider reservior. Leave both old pads in place for now. slide the far side pad over to the near side pad and using a channel-lock wrench, squeeze slowly and steadily. this will cause your brake cylider to retract, pushing the fluid backwards through the line and into the reservior. Once the cylinder is retracted, remove old pads and place new pads on either side. Align caliper and swing it down. Replace lower bolt and tighten upper.
Sep 23, 2010 | 1993 Toyota Celica
How do you replace the front and rear brakes in a 2003 pontiac Grand Prix
Removal & Installation Front To Remove:
  1. Inspect the fluid level in the master cylinder reservoir. Remove fluid from the reservoir until the level is lower then half way between the MAX and MIN levels.
  2. Remove the tire and wheel assembly.
  3. Install 2 wheel nuts to secure the rotor on the hub.
  4. Remove the bottom brake caliper pin bolt.
  5. Pivot the brake caliper body upward and secure out of the way. Do NOT disconnect the hydraulic brake flexible hose from the caliper.
  6. Compress the piston back into the bore using a C-clamp. Figure of brake assembly with caliper raised showing brake pads in mounting bracket gmpc_l4.gif
  7. Remove the inboard and outboard brake pads from the brake caliper bracket.
To Install:
  1. Install the brake pad retainers and both brake pads into the caliper bracket.
  2. Pivot the brake caliper down over the brake pads and into the brake caliper bracket. Insert the lower brake caliper pin bolt and torque bolt to 70 ft-lb. (95 Nm).
  3. Reinstall the tire and wheel assembly.
  4. Lower the vehicle.
  5. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  6. Check the master cylinder level and add fluid as necessary.
Rear To Remove:
  4. Remove the upper caliper mounting bolt.
  5. Pivot the caliper down to access the pads.
  6. Remove the inboard and outboard pads from the caliper bracket.
  7. Remove the brake pad clips from the caliper bracket.
  8. Compress the piston back into the bore using a C-clamp and the old inner pad.
To Install:
  1. Install new brake clips in the caliper bracket.
  2. Install the inboard and outboard pads in the caliper bracket.
  3. Pivot the caliper up over the pads.
  4. Reinstall the upper mounting bolt and tighten to 32 ft. lbs. (44 Nm).
  5. Remove the 2 wheel nuts securing the rotor.
  6. Reinstall the tire and wheel assembly.
  7. Refill the master cylinder. Pump the brake pedal several times to seat the pads against the rotor.
  8. Check the master cylinder level and add fluid as necessary.
Aug 26, 2010 | 2003 Pontiac Grand Prix
How do i change front brake pad on this car merecy sable 1989 -99
Remove the wheel, remove the 2 bolts holding on the caliper to the caliper carrier. You will need a large C-Clamp or a cailper piston tool. Place an old brake pad against the piston in the caliper and use the C-Clamp to push the brake pad against the piston to collapses the piston into the caliper. Also open the master cylinder cap and place a towel around the area to catch any brake fluid that would come out of the master cylinder as you collapes the piston, this is normal, but doesn't always happen, depending on the level of fluid in the master cylinder. Install the new pads and reinstall the caliper and wheel. Make sure you pump the brake pedal a few times before you take off, to get the pads against the rotor.
Mar 16, 2010 | 1999 Mercury Sable
Need a manual for master cool 11 model mc63c serial #k00024682a
Try out this.
www.mastercool.com/media/90060_parts%20list.pdf
Nov 15, 2009 | Heating & Cooling
How to reset the safe house alarm very old style model # 49-470A
i bought house alarm second hand and it has reset it self to factory setting 1234 but on pad its say called engineer to reset can you help
Jun 21, 2009 | Home Security
How to remove front brake pads from a 2004 Diahatsu Charade
what i do is remove fluid from master cyl. in engne bay. jack up front, remove wheels. with decent flat blade push piston back through caliper between inner pad and rotor. remove lower caiper bolt (12mm). pivot caliper up remove old pads, fit new pads. Check inner and outter pads and dont forget the shims!!! refit lower bolt. pump brake pedel. top up fluid in master cyl. refit wheels. go for drive to bed in. accel. to 60kmh brake to 20kmh repeat 5 times.
Aug 09, 2008 | 1988 Daihatsu Charade
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
297 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
acrman404a
Level 1 Expert
Steve F
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
