Question about Frigidaire Electric Dryer
The inside do not spin
The inside of the dryer stop spinnig and a funny quite sound comes out of it the light still comes on an the bottons still work what is the problem?
  • 1,998 Answers
You have a broken belt most likely as long as you can hear the motor working it is most likely the belt
Posted on Jul 29, 2010
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
Dryer stopped drying yesterday.
www.RepairClinic.com
Sounds like the heating element quit.
Jan 25, 2012 | Splendide 2100XC
How do you use the traction control system. should the dashboard light be on or off
how the tcs works is when active light on dash will be on you will only feel it working tcs uses wheel speed sensors that when your tire slips and spins faster than other wheel like spinnig out on on ice snow gravel the tcs unit will use a controlled misfire that will **** or jolt giving traction and will stay engaged until spinnig stops or you let off gas basicaly it uses the engine to **** not allowing wheels to spin out to get a feel turn on tcs find a gravel or snowy road accelerate trying to make the car slip you will feel car start to **** it works well try it so you get a feel incase you trigger tcs and catches you off guard
hope this helped
plz vote comment if any more questions reply
Jan 18, 2011 | Saturn Aura Cars & Trucks
I'VE WF8550NGW, THE START/PAUSE BOTTON NOT WORKING while washing for the first time, during spinnig it was making loud noise n moving a lot. so i tried to pause, it dint so i switched off (power off...
did u level the machine before you started it with a level? if you did not then u would need to level the machine because this would throw off how the machine spins which also on a samsung would cause it to not to start up again. If your machine is 3-4 days old then it is also under warranty and you can easily call for them to come fix the machine. Please right back if you do not have the warranty on your machine and ill instruct you how to get to the technical manual located on the inside of the machine thanks again.
Rick
Nov 07, 2010 | Samsung Washing Machines
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
I have a Whirlpool dryer...Mod nu# WED5800SQ0,
Sounds like your capacitor has stopped functioning. Most dryers have capacitors ranging from 8 to 10 ohms which store energy and give the drum the initial energy boost to start it turning. Unplug the machine and take off the side that contains the motor. in there you will find a small cylindrical object with two connections, thats your capacitor, replace it
May 24, 2010 | Whirlpool Dryers
The drum won't spin.
It sounds like the belt tensioner is bad. To look and see it the front panel must be removed for inspection. The belt wraps completely around the dryers drum with the belt running through a belt tensioner at the botton. The bearing and roller assembly should be checked thoroughly to see if its worn bad
Feb 06, 2010 | Amana ALG331RAW Gas Dryer
Dryer starts, sounds funny, then stop spinning and stops
Please do the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
If this is tough,then call the technician for he might solve the problem.
Apr 10, 2009 | Kenmore Dryers
Frigidaire  Electric Dryer Logo
52 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
