Question about Fedders X Chassis A6X08F2A Air Conditioner
My air conditioner is spitting water inside my house
  • 92 Answers
The drain hole is probably clogged up
Posted on Jul 29, 2010
    President:
  • 1,796 Answers
Hi!!
Condensed water from the evaporator coil is not draining.
Make sure the unit is tilted back about 1/2", if it is, check the bottom of the outsde part of the unit, it should have a 1/4" hole near one of the corners, that's the drain hole, use a piece of wire to unclogg it.
If no hole is present, dirll one around that area, making sure to clear eveything inside.
Don't forget to rate this Post!!
Why is my air conditioner spitting water back in the house. These do not have ourside drains on them?
Take the front cover off and use a shop vac to suck the water out, check filter while you do this see if the evap coil is dirty the one on the inside. sounds like it maybe freezing up. check for air flow.
Sep 06, 2014 | Haier Heating & Cooling
Haier 5500 window unit, spits water into the room sometimes. Also, water "sloshes" around inside the fan area & is quite noisy sometimes. ? Thankyou for your assistance...
You will need to reposition the unit to where it will be tilted downwards slightly outside.
The water will then flow out the back and not spit into the room.
Jul 16, 2011 | Haier hwr10xc6 Air Conditioner
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Droplets of water are coming from the vents and it's making a noise like something is rattling around inside. What could this be?
The problem with this unit is that the evaporator, or the part of the air conditioner that 'creates' the colder air is not draining correctly. Pertaining to a window unit, it needs to be installed correctly with the correct amount of tilt toward outside, to allow the evaporator condensation water to drain. You may also want to check to make sure there aren't any plugged drain holes in the air conditioner housing.
The rattling you hear is most likely the blower fan spinning against the held water inside the unit.
I hope this helps! :)
Sep 01, 2009 | Heating & Cooling
Window unit just started spitting a little water and making a noise like when something is too tight a fit, a rubbing noise. just started minutes ago. it's raining but, what could of happened?
Make sure the window unit is evenly placed inside the window frame.Just a slight twisting of the housing will cause the fan blade to scrape the housing. Make sure that the fan blade has no come loose from the fan motor shaft if that does not solve the problem. Also make sure the window unit tilts slightly downward so that any water from the condensate produced inside the home on the condenser coil can drain down the slope to the outsidelike the way explained. I have also seen units that were positioned correctly but the drain trough is blocked and will not allow the water to drain outside the house. Let Me Know, Thanks, Sea Breeze
May 15, 2009 | Haier hwr10xc6 Air Conditioner
My Lg split system air con spits water
Make sure the unit is tilted downward at the back. About 1" lower than the front is good. Even with a drain, the water will pool inside if it doesn't have a slope for drainage.
Feb 19, 2009 | LG LB1200ER Air Conditioner
Why does my window air conditioner in my house spit water out of the front of it and i can also hear the fan blowing water around the inside of the AC?
It is freezing up. Change or clean the filter(s) and turn it off until it thaws. If this doesn't work the problem may be more serious. Usually this means it is low on freon. A technician will have to do this repair due to EPA restrictions on the refrigerant
Jul 08, 2008 | Heating & Cooling
Fedders X Chassis A6X08F2A Air Conditioner Logo
307 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
