Question about InFocus ScreenPlay 4805 Multimedia Projector
Reversing the picture on the monitor
I have put the monitor on the roof and i am trying to reverse the picture 180 and i have lost my manual can you help
  • cammy25 Apr 29, 2008
    Thanks This solved the problem
    Great and Thanks again 100%
  • 19,396 Answers
Here is the manual:
ScreenPlay 4805 ScreenPlay 4805
Check page 38 on picture settings, you can revers the image to project from behind a screen (mirror), I don' think you can have picture upside down (180 rotation) using projector settings. You need to reverse image source (eg. picture on computer).
Posted on Apr 24, 2008
Where is reverse button
Depends on the make & model of your machine. Would be best to consult the owner's manual. Mechanical and computerized machines also vary. Mechanical machines usually have a stitch length lever that, when pushed all the way up, will reverse stitch, or there is a button usually marked with an R or an arrow. Computerized machines usually have a button marked by a U-shaped arrow.
Of course, if you have a vintage sewing machine, it may not even have a reverse stitch. Instead, to sew in reverse, one would have to sink the needle into the fabric, raise the presser foot and swivel the fabric 180 degrees, drop the presser foot and stitch.
To find a copy of the owner's manual, search the internet for:
Manufacturer + Model + the word "Manual"
sewing machine reverse Google Search
Dec 04, 2015 | Sewing Machines
How do I free it so it will shred again?
Empty the bin and then put the shredder into reverse. If that doesn't work.
Unplug the unit.
Turn it over.
Remove the clogged paper manually as well as possible.
Put the unit back on the bin and try reverse again.
Oct 25, 2014 | Computers & Internet
After transmission filter replacement the car lost reverse
Loss of reverse is a symptom of a failed transmission.
Oct 22, 2012 | 2006 Chevrolet Impala
Model 385.15718500..machine only goes in reverse
Sounds like the reverse mechanism has jammed...either with lint or lack of use and oil/lint has frozen the mechanism.
Unplug the machine and remove the base. Clean all the lint with small brush and vacuum.
Try the reverse lever to see where the connecting rods are and identify the collar around the bottom shaft....try to move manually, use a little lubricant where the collar moves on the shaft.
In extreme cases it may take several applications over several days to rectify this, but as this is only 3 years old, should respond quickly
Aug 02, 2009 | Sewing Machines
On the jensen vm9022 how do you reverse the subwoofer polarity
CLICK HERE for a copy of your manual in PDF format.
Phase control is featured on page 17 (21 of pdf)
In the Audio Sub-Menu:
Subwoofer Phase Adjustment: Touch the sub.w icon to
access the subwoofer polarity controls and reverse the
subwoofer signal polarity from to 180°. Reversing
polarity can improve bass response related to speaker
configuration.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 06, 2009 | Jensen Car Audio & Video
Manually retract convertible roof on 95 cabriolet
Open roof latch over windshild.
Raise rear of roof off of hatch
Lift little hatch tabs to access lift mechanism
Release latches on each side with fingers
Lift Hatch with free hand
Let roof fall into storage compartment
Click hatch shut.
Reverse proceedure to put back up.
Aug 22, 2008 | 1995 Audi Cabriolet
Reverse image wtih evp-70fh monitor
IN THE SCREEN SETTING TURN OFF MIRROR IMAGE
Feb 12, 2008 | Car Audio & Video
Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Dec 11, 2007 | Kenwood DDX7019 6.95 in. Car Monitor
Picture reversed and upside down on screen????????
just happened to me, phoned customer support and solution is to press the Ctrl key and Alt key and Up arrow together and it should solve the problem
May 02, 2007 | Toshiba SD-P1200 Portable DVD Player
InFocus ScreenPlay 4805 Multimedia Projector Logo
606 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
