Question about DSC Home Security
Have low battery and need to get the beeps to stop. DSC system
I have a low battery and need to get the beeps to stop for the night until I get a chance tomorrow to replace the battery. help... need sleep...
DSC System, but there is not a model number on the cover anywhere. I armed and dis-armed it. I looked thru the trouble shooting area, What next?
    New Friend:
  • 74 Answers
Generally entering your security code will turn it off for 4 hours, but it will reactivate periodically until you replace the battery.
Posted on Aug 23, 2010
  • Joel Lavoie Dec 31, 2010
    press star and 2 and pound on your keypad ,it stop the beeping
Low battery mess changed it and still continues to beep how do i fix
Power your system down first. Plug in the battery, the panel should beep, then plug in the AC power. If the panel doesn't beep you might have a bad battery. If the panel powers up after the battery then AC power reset your time and the beeping should stop.
May 16, 2014 | GE Security Simon 3 Wireless Home Security...
Just moved into new house. Plugged in DSC PC1832 to power outlet. Keypad beeps every 3-5 seconds and yield sign is lit. How do i keep it from beeping, and only beep when doors open?
This means there is a fault on the panel, either something very benign ( like the system clock is not set or a low system battery ) all the way up to a major configuration or communications problem. You can press * + 2 to see the troubles on the panel. If it is the system clock, you can set it from there and be home free. It is probably a good idea to have the local alarm company come by and do an inspection and test, though, as the communications may be down ( last tenant ended the monitoring contract, phone line may be disconnected, etc.) and you probably want to change the user codes.
Jan 03, 2011 | DSC 8 Zone LED Keypad
I have a dsc power 832, and have replaced the battery, but i can not get it returned to the ready state as it shows an alarm memory stating ''panel lid''. How do i reset this alarm message?
An "alarm Memory" indicates that a zone was activated the last time the system was armed. To view what zone caused the problem press the * key (star) + the 3 key. To reset the memory simply arm the system and disarm. Hope this helps.
Apr 21, 2010 | DSC Power Supervision Relay For Smoke And...
Alarm system is not activated we just bought the house and it keeps beeping off and on how do we stop it?
I would try and get the owners manual for the alarm system and see what it says about the beeping. It could be that it is just telling you it needs a new battery installed, something like the battery operated smoke detectors do when the battery is low. There are so many alarm systems out there that it is hard to tell what could be causing the beeping. It could have been configured with a audible alert that when the system is tripped by any motion it beeps when off. It is really hard to say without the manual. You can usually find the manuals on line at the manufacturers website. Good Luck, RAC
Apr 20, 2009 | Computers & Internet
System Low Battery Alarm
You can silence trouble beeps by arming and disarming the system or by pressing status button; however, trouble beeps resume after 4 hours if the trouble condition as not been fixed. You can turn the trouble beeps off in the programming option 40. This should be done by your security professional because any mistake you could change other parameters in the system and the system may not work correctly. Hope this helps
Aug 19, 2008 | GE Security Simon 3 Wireless Home Security...
Simon 3 "System Low Battery" after 3 years use
I install these panels.  For the low battery message to clear you need to power the system down completely.  To do this you need to unplug the battery and also unplug the transformer plugged into an electrical outlet.  When you power the system back up, you need to first plug in the battery leads.  Then the transformer.
Jun 15, 2008 | GE Security Simon 3 Wireless Home Security...
"Low Battery"
Phone starts to beep after ten minutes or so then goes dead. Is there a way to change battery
Aug 25, 2006 | Uniden Cordless Phone exai398i
Home Security Logo
2,651 people viewed this question
Top DSC Home Security Experts
Steve
yobo007
yobo007
don1956
Level 1 Expert
Are you a DSC Home Security Expert? Answer questions, earn points and help others
